m2005 untar error on msys2 (tar01 directory)
Tue May 5 07:25:42 UTC 2020
On 5/5/20 5:01 pm, Sebastian Huber wrote:
> On 05/05/2020 08:57, Chris Johns wrote:
>> On 5/5/20 4:05 pm, Sebastian Huber wrote:
>>> On 05/05/2020 08:01, Chris Johns wrote:
>>>>>> What does `os.uname()` return?
>>>>> In the msys shell:
>>>>> $ python
>>>>> Python 3.7.4 (default, Jul 11 2019, 09:35:14)
>>>> That is what I have installed.
>>>>> [GCC 9.1.0] on msys
>>>>> Type "help", "copyright", "credits" or "license" for more information.
>>>>>  >>> import os
>>>>>  >>> os.uname()
>>>>> posix.uname_result(sysname='MSYS_NT-6.1-7601', nodename='Blub',
>>>>> release='3.0.7-338.x86_64', version='2019-07-11 10:58 UTC',
>>>>> machine='x86_64')
>>>> I have ...
>>>> >>> os.uname()
>>>> posix.uname_result(sysname='MINGW64_NT-10.0-18362', nodename='weng',
>>>> machine='x86_64')
>>>> I have never seen `MSYS_NT` before.
>>>> I am running Window-10 on real hardware running Version 1903, OS
>>>> build 18362.778. I have not picked up the feature update yet. I am
>>>> remote to the machine and do not want to try.
>>> I did the testing on a more or less retired Windows 7 VM. I will
>>> setup a Windows 10 VM.
>> Oh OK, maybe keep it? Could you patch the RSB and see if it works?
> I removed the GDB from the build set.
I am pretty sure it would work with a patched windows.py.
> It is currently busy building the
> 5/rtems-sparc build set (without GDB) in a mingw64 shell. Is a build in
> the msys shell something useful/supported?
Yes, we have valid users. Plus building on Windows is valid for the same
reasons we build from source on all hosts maybe more so.
> I normally build the mingw64 tools on Linux.
There is Cxc support in the RSB but I have not maintained it recently, I
see it as a dead end. I would not use those tools in a production
environment unless I checked every aspect of them so the runtimes are
aligned. It is easy to become wedged in dll hell. I learnt this lesson
on Fedora decades ago and gave up.
