m2005 untar error on msys2 (tar01 directory)
Tue May 5 07:53:41 UTC 2020
On 05/05/2020 09:48, Chris Johns wrote:
>>>> It is currently busy building the 5/rtems-sparc build set (without
>>>> GDB) in a mingw64 shell. Is a build in the msys shell something
>>>> useful/supported?
>>> Yes, we have valid users. Plus building on Windows is valid for the
>>> same reasons we build from source on all hosts maybe more so.
>> If I install msys/mingw I get an msys, mingw32 and mingw64 shell.
>> They are all somewhat different. Are all of them supposed to be
>> supported?
> They are different in a subtle way, they set different paths so you
> get a different set of native executables and DLLs in your path. Run:
>  `set | grep ^PATH`
> in each instance and compare. On top of that the mingw native tools
> are specifically named, something I completely agree with.
> MSYS2 is well thought out, the pacmac tools is great. Like cygwin a
> rolling release makes baselining for deployment or a product hard.
Yes, but should RTEMS build on all three shells? Which one is recommended?
