[PATCH 1/7] Use rtems_get_version_string()
Sebastian Huber
Tue May 5 14:23:26 UTC 2020
Update #3970.
bsps/powerpc/beatnik/start/bspstart.c | 2 +-
bsps/powerpc/motorola_powerpc/start/bspstart.c | 2 +-
bsps/powerpc/mvme3100/start/bspstart.c | 2 +-
bsps/powerpc/mvme5500/start/bspstart.c | 2 +-
cpukit/libmisc/shell/shell.c | 6 +++---
5 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/bsps/powerpc/beatnik/start/bspstart.c b/bsps/powerpc/beatnik/start/bspstart.c
index 4e0f007d41..520d908930 100644
--- a/bsps/powerpc/beatnik/start/bspstart.c
+++ b/bsps/powerpc/beatnik/start/bspstart.c
@@ -207,7 +207,7 @@ static void bsp_early( void )
/* Make sure we detect a known host bridge */
BSP_getDiscoveryVersion(/* assert detection */ 1);
- printk("Welcome to RTEMS %s\n", _RTEMS_version );
+ printk("Welcome to RTEMS %s\n", rtems_get_version_string() );
/* Leave all caches as MotLoad left them. Seems to be fine */
diff --git a/bsps/powerpc/motorola_powerpc/start/bspstart.c b/bsps/powerpc/motorola_powerpc/start/bspstart.c
index c28d5d21b5..e74b02c446 100644
--- a/bsps/powerpc/motorola_powerpc/start/bspstart.c
+++ b/bsps/powerpc/motorola_powerpc/start/bspstart.c
@@ -219,7 +219,7 @@ static void bsp_early( void )
myBoard = getMotorolaBoard();
printk("-----------------------------------------\n");
- printk("Welcome to %s on %s\n", _RTEMS_version,
+ printk("Welcome to %s on %s\n", rtems_get_version_string(),
motorolaBoardToString(myBoard));
#ifdef SHOW_MORE_INIT_SETTINGS
diff --git a/bsps/powerpc/mvme3100/start/bspstart.c b/bsps/powerpc/mvme3100/start/bspstart.c
index f20a40fed1..0ec215e33b 100644
--- a/bsps/powerpc/mvme3100/start/bspstart.c
+++ b/bsps/powerpc/mvme3100/start/bspstart.c
@@ -231,7 +231,7 @@ VpdBufRec vpdData [] = {
myCpu = get_ppc_cpu_type();
myCpuRevision = get_ppc_cpu_revision();
- printk("Welcome to %s\n", _RTEMS_version);
+ printk("Welcome to %s\n", rtems_get_version_string());
printk("BSP: %s, CVS Release ($Name$)\n", "mvme3100");
diff --git a/bsps/powerpc/mvme5500/start/bspstart.c b/bsps/powerpc/mvme5500/start/bspstart.c
index 90fc8cf961..3a9ef69f0f 100644
--- a/bsps/powerpc/mvme5500/start/bspstart.c
+++ b/bsps/powerpc/mvme5500/start/bspstart.c
@@ -227,7 +227,7 @@ static void bsp_early( void )
* More PCI1 memory mapping to be done after BSP_pgtbl_activate.
- printk("Welcome to %s on MVME5500-0163\n", _RTEMS_version );
+ printk("Welcome to %s on MVME5500-0163\n", rtems_get_version_string() );
BSP_mem_size = probeMemoryEnd();
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index f00ae54b49..79c1afcb5a 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -683,7 +683,7 @@ static bool rtems_shell_login(rtems_shell_env_t *env, FILE * in,FILE * out)
fprintf(out,"RTEMS");
break;
case 'V':
- fprintf(out,"%s\n%s",_RTEMS_version, _Copyright_Notice);
+ fprintf(out,"%s\n%s",rtems_get_version_string(), _Copyright_Notice);
break;
case '@':
fprintf(out,"@");
@@ -735,10 +735,10 @@ static bool rtems_shell_login(rtems_shell_env_t *env, FILE * in,FILE * out)
fprintf(out,"(" CPU_NAME "/" CPU_MODEL_NAME ")");
break;
case 'r':
- fprintf(out,_RTEMS_version);
+ fprintf(out,rtems_get_version_string());
break;
case 'v':
- fprintf(out,"%s\n%s",_RTEMS_version,_Copyright_Notice);
+ fprintf(out,"%s\n%s",rtems_get_version_string(),_Copyright_Notice);
break;
case '%':fprintf(out,"%%");
break;
2.16.4
