[PATCH 2/7] rtems: Deprecate use of _RTEMS_version
Sebastian Huber
Tue May 5 14:23:27 UTC 2020
Close #3970.
cpukit/include/rtems/system.h | 9 ++++-----
cpukit/sapi/src/getversionstring.c | 2 ++
testsuites/sptests/spsize/size.c | 2 ++
3 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/cpukit/include/rtems/system.h b/cpukit/include/rtems/system.h
index c72859195c..2fb5e8add7 100644
--- a/cpukit/include/rtems/system.h
+++ b/cpukit/include/rtems/system.h
@@ -35,12 +35,11 @@ extern "C" {
#ifndef ASM
- * The following is the extern for the RTEMS version string.
- * @note The contents of this string are CPU specific.
+ * The use of this variable is deprecated, use rtems_get_version_string()
+ * instead.
-extern const char _RTEMS_version[];
+extern RTEMS_DEPRECATED const char _RTEMS_version[];
* The following is the extern for the RTEMS copyright string.
diff --git a/cpukit/sapi/src/getversionstring.c b/cpukit/sapi/src/getversionstring.c
index 2222e9ef50..f3fada9c48 100644
--- a/cpukit/sapi/src/getversionstring.c
+++ b/cpukit/sapi/src/getversionstring.c
@@ -19,6 +19,8 @@
#include "config.h"
#endif
+#pragma GCC diagnostic ignored "-Wdeprecated-declarations"
const char *rtems_get_version_string(void)
diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
index 578576cba7..d26e34f51d 100644
--- a/testsuites/sptests/spsize/size.c
+++ b/testsuites/sptests/spsize/size.c
@@ -18,6 +18,8 @@
#include "config.h"
#endif
#include <rtems/config.h>
#include <rtems/score/copyrt.h>
#include <rtems/rtems/clock.h>
2.16.4
