[PATCH] libtests/tar01: Remove files of tar01.tar archive
Fri May 8 13:13:05 UTC 2020
Update #3968.
 testsuites/libtests/tar01/home/abc/def/test_script | 2 --
 testsuites/libtests/tar01/home/test_file           | 2 --
 testsuites/libtests/tar01/symlink                  | 1 -
 3 files changed, 5 deletions(-)
 delete mode 100755 testsuites/libtests/tar01/home/abc/def/test_script
 delete mode 100644 testsuites/libtests/tar01/home/test_file
 delete mode 120000 testsuites/libtests/tar01/symlink
diff --git a/testsuites/libtests/tar01/home/abc/def/test_script b/testsuites/libtests/tar01/home/abc/def/test_script
deleted file mode 100755
index 884924820b..0000000000
--- a/testsuites/libtests/tar01/home/abc/def/test_script
+++ /dev/null
@@ -1,2 +0,0 @@
-#! joel
-ls -las /dev
diff --git a/testsuites/libtests/tar01/home/test_file b/testsuites/libtests/tar01/home/test_file
deleted file mode 100644
index 1a9e0f656f..0000000000
--- a/testsuites/libtests/tar01/home/test_file
+++ /dev/null
@@ -1,2 +0,0 @@
-This is a test of loading an RTEMS filesystem from an
-initial tar image.
diff --git a/testsuites/libtests/tar01/symlink b/testsuites/libtests/tar01/symlink
deleted file mode 120000
index 1f10c8dabe..0000000000
--- a/testsuites/libtests/tar01/symlink
+++ /dev/null
@@ -1 +0,0 @@
-home/test_file
\ No newline at end of file
2.16.4
