GSoC 2020: Implementation of OFW functions
Niteesh G. S. niteesh.gs at gmail.com
Fri May 8 15:26:24 UTC 2020
On Fri, May 8, 2020 at 11:43 AM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 07/05/2020 17:19, Niteesh G. S. wrote:
> > On Thu, May 7, 2020 at 4:07 PM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >     On 07/05/2020 12:28, Niteesh G. S. wrote:
> >     > On Thu, May 7, 2020 at 1:21 PM Sebastian Huber
> >     <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> >     >     On 07/05/2020 09:35, Niteesh G. S. wrote:
> >     >     > This is what I was trying to convey in one of the previous
> >     mails.
> >     >     > https://lists.rtems.org/pipermail/devel/2020-May/059717.html
> >     >     > But in that mail, I was planning to replace KOBJLOOKUP.
> >     >     > Should I start working on it? From the top of my mind, the
> >     >     following has
> >     >     > to be done.
> >     >     > 1) Import openfirm.c openfirm.h, ofw_fdt.c
> >     >     > 2) Add ofw_fdt.h since all the functions in ofw_fdt are
> static.
> >     >     > Should we also import ofw_if.h? Because that is where OFW_*
> >     >     functions
> >     >     > are defined or just add a ofw_rtems_map.h which redefines
> them,
> >     >     instead
> >     >     > of importing ofw_if.h?
> >     >     The KOBJ stuff in the OFW support enables FreeBSD to have three
> >     >     different implementations of the OFW API which can be selected
> at
> >     >     runtime:
> >     >     sys/powerpc/ofw/ofw_real.c
> >     >     sys/dev/ofw/ofw_standard.c
> >     >     sys/dev/ofw/ofw_fdt.c
> >     >     In libbsd this is already short cut to the FDT implementation:
> >     >     #ifndef __rtems__
> >     >     static ofw_def_t    *ofw_def_impl = NULL;
> >     >     #else /* __rtems__ */
> >     >     #define    ofw_def_impl (&ofw_fdt)
> >     >     #endif /* __rtems__ */
> >     >     To me this looks like the KOBJ stuff was just used to enable
> some
> >     >     sort
> >     >     of object oriented programming. Do we need this flexibility at
> >     >     runtime
> >     >     in RTEMS? I would say no. I would hard wire this to the FDT
> >     >     implementation. If someone has a problem with it in the
> >     future, this
> >     >     decision can be readdressed.
> >     > Ok. But what is the neatest way to hardwire this to the FDT
> >     > implementation?
> >     > One way as Christian mentioned would be to redefine OFW_*
> functions to
> >     > call the functions in ofw_fdt.c directly. Is there any other way?
> >     I would try to replace the function declarations in openfirm.h with
> >     inline functions which call the ofw_fdt.c functions.
> > Should I proceed with the above method? or should I wait for others
> > to comment?
> > If I can proceed, the following is what I will be doing.
> > 1) import openfirm.h and ofw_fdt.c into RTEMS.
> > 2) Add ofw_fdt.h with functions declarations for functions in ofw_fdt.c
> > 3) Add necessary compile-time guards. This would include using __rtems__
> > preprocessor directive to avoid FreeBSD stuff and change the function
> > definitions in ofw_fdt.c from static to non-static.
> > Am I missing something? or is there any other way to do this?
> Maybe wait one or two more days for others to comment. For me the
> direction sounds OK.
> You maybe can start thinking about where you want to import the files to.
Since this has scope for future development. I think we should put it in a
separate directory under cpukit/include/ofw for header files and cpukit/ofw
for the source files. What do you think?
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200508/95b674eb/attachment.html>
