GSoC 2020: Implementation of OFW functions
Christian Mauderer
oss at c-mauderer.de
Fri May 8 15:34:04 UTC 2020
On 08/05/2020 17:26, Niteesh G. S. wrote:
> On Fri, May 8, 2020 at 11:43 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
> On 07/05/2020 17:19, Niteesh G. S. wrote:
> > On Thu, May 7, 2020 at 4:07 PM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>
> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> > On 07/05/2020 12:28, Niteesh G. S. wrote:
> > > On Thu, May 7, 2020 at 1:21 PM Sebastian Huber
> <mailto:sebastian.huber at embedded-brains.de>>>> wrote:
> > > On 07/05/2020 09:35, Niteesh G. S. wrote:
> > > > This is what I was trying to convey in one of the previous
> > mails.
> https://lists.rtems.org/pipermail/devel/2020-May/059717.html
> > > > But in that mail, I was planning to replace KOBJLOOKUP.
> > > > Should I start working on it? From the top of my mind, the
> > > following has
> > > > to be done.
> > > > 1) Import openfirm.c openfirm.h, ofw_fdt.c
> > > > 2) Add ofw_fdt.h since all the functions in ofw_fdt
> are static.
> > > > Should we also import ofw_if.h? Because that is where
> OFW_*
> > > functions
> > > > are defined or just add a ofw_rtems_map.h which
> redefines them,
> > > instead
> > > > of importing ofw_if.h?
> > > The KOBJ stuff in the OFW support enables FreeBSD to
> have three
> > > different implementations of the OFW API which can be
> selected at
> > > runtime:
> > > sys/powerpc/ofw/ofw_real.c
> > > sys/dev/ofw/ofw_standard.c
> > > sys/dev/ofw/ofw_fdt.c
> > > In libbsd this is already short cut to the FDT
> implementation:
> > > #ifndef __rtems__
> > > static ofw_def_t *ofw_def_impl = NULL;
> > > #else /* __rtems__ */
> > > #define ofw_def_impl (&ofw_fdt)
> > > #endif /* __rtems__ */
> > > To me this looks like the KOBJ stuff was just used to
> enable some
> > > sort
> > > of object oriented programming. Do we need this
> flexibility at
> > > runtime
> > > in RTEMS? I would say no. I would hard wire this to the FDT
> > > implementation. If someone has a problem with it in the
> > future, this
> > > decision can be readdressed.
> > > Ok. But what is the neatest way to hardwire this to the FDT
> > > implementation?
> > > One way as Christian mentioned would be to redefine OFW_*
> functions to
> > > call the functions in ofw_fdt.c directly. Is there any other
> way?
> > I would try to replace the function declarations in openfirm.h
> with
> > inline functions which call the ofw_fdt.c functions.
> > Should I proceed with the above method? or should I wait for others
> > to comment?
> > If I can proceed, the following is what I will be doing.
> > 1) import openfirm.h and ofw_fdt.c into RTEMS.
> > 2) Add ofw_fdt.h with functions declarations for functions in
> ofw_fdt.c
> > 3) Add necessary compile-time guards. This would include using
> __rtems__
> > preprocessor directive to avoid FreeBSD stuff and change the function
> > definitions in ofw_fdt.c from static to non-static.
> > Am I missing something? or is there any other way to do this?
> Maybe wait one or two more days for others to comment. For me the
> direction sounds OK.
> You maybe can start thinking about where you want to import the
> files to.
> Since this has scope for future development. I think we should put it in a
> separate directory under cpukit/include/ofw for header files and cpukit/ofw
> for the source files. What do you think?
If you plan to prepare a FreeBSD sync (regardless whether you implement
it or someone else) another possibility could be to create a similar
directory structure like in libbsd.
Another directory could be ./cpukit/libmisc/rtems-fdt.
But your suggestion is also possible.
Maybe wait for some further input.
Best regards
Christian
