Odd Behavior on Cygwin
Chris Johns
chrisj at rtems.org
Sat May 9 00:38:19 UTC 2020
On 8/5/20 11:14 pm, Joel Sherrill wrote:
> On Wed, May 6, 2020 at 12:49 AM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 6/5/20 3:46 am, Joel Sherrill wrote:
> > I have a test sweep going on Cygwin and there are a couple of
> oddities I
> > would like some advice on:
> > 1. It appears that the same command I used on Linux and FreeBSD
> is not
> > managing to get mail to the build@ list. Any ideas?
> What is the detailed error reported in the log or output? What does the
> mail server think is happening?
> > ../source-builder/sb-set-builder --mail --mail-to=build at rtems.org
> <mailto:build at rtems.org>
> > <mailto:build at rtems.org <mailto:build at rtems.org>>
> --mail-from=joel at rtems.org <mailto:joel at rtems.org>
> > <mailto:joel at rtems.org <mailto:joel at rtems.org>> --keep-going
> --log=l-aarch64-5.txt
> > --prefix=/home/jrs007/rtems-cron-5.0.0-m2005-1/tools/5
> 5/rtems-aarch64
> It is a python only SMTP client and should be portable.
> Hmm... this is interesting. If this was a Windows firewall issue, I
> assume my
> Virtualbox Linux wouldn't be able to send these reports.
Windows like to block outgoing to port 25. Maybe the VM is under the
Windows firewall. I have no idea.
> Mailing report: build at rtems.org <mailto:build at rtems.org>
> Mail Send Failure: error: sending mail: [Errno 111] Connection refused
> Build Set: Time 1:34:28.269299
> Any idea what host/port I should telnet to to test this?
I do not know, it depends on your system set up and what ever else
Python does on Windows.
> I think I will message Amar for an idea as well.
Are you sending directly to RTEMS's mail server?
