Odd Behavior on Cygwin
Joel Sherrill
joel at rtems.org
Fri May 8 13:14:52 UTC 2020
On Wed, May 6, 2020 at 12:49 AM Chris Johns <chrisj at rtems.org> wrote:
> On 6/5/20 3:46 am, Joel Sherrill wrote:
> > I have a test sweep going on Cygwin and there are a couple of oddities I
> > would like some advice on:
> > 1. It appears that the same command I used on Linux and FreeBSD is not
> > managing to get mail to the build@ list. Any ideas?
> What is the detailed error reported in the log or output? What does the
> mail server think is happening?
> > ../source-builder/sb-set-builder --mail --mail-to=build at rtems.org
> > <mailto:build at rtems.org> --mail-from=joel at rtems.org
> > <mailto:joel at rtems.org> --keep-going --log=l-aarch64-5.txt
> > --prefix=/home/jrs007/rtems-cron-5.0.0-m2005-1/tools/5 5/rtems-aarch64
> It is a python only SMTP client and should be portable.
Hmm... this is interesting. If this was a Windows firewall issue, I assume
my
Virtualbox Linux wouldn't be able to send these reports.
Mailing report: build at rtems.org
Mail Send Failure: error: sending mail: [Errno 111] Connection refused
Build Set: Time 1:34:28.269299
Any idea what host/port I should telnet to to test this?
I think I will message Amar for an idea as well.
> > 2. $HOME in a script being nohup'ed was being replaced with
> > c:/msys64/.... and not /home/... . Any idea what this was an indication
> > of? When I ran the script directly, the expansion was as expected. I
> > can't seem to reproduce this in a small test case. Any suggestions?
> Not really, this is the sort of stuff that makes using cygwin hard. Is
> your path clean and only using cygwin executables?
> > The build sweep is going (slowly as expected) and it is on the second
> > tool target. It will take a long time (as in days) to finish.
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200508/b484c522/attachment-0001.html>
