[PATCH 4/6] testsuite: Add expected-fail to psim
Sebastian Huber
Tue May 12 07:15:45 UTC 2020
Hello,
On 09/05/2020 03:30, Gedare Bloom wrote:
>>>> Without these tests being tagged this way the user would have no idea where the stand after a build and test run and that would mean we would have to make sure a release has no failures. I consider that as not practical or realistic.
>>> Maybe we need another state, e.g. something-is-broken-please-fix-it.
>> I do not think so, it is implicit in the failure or the test is broken. The only change is to add unexpected-pass, that will be on master after the 5 branch.
> I disagree with this in principle, and it should be reverted after we
> branch 5. It's fine for now to get the release state sync'd, but we
> should find a long-term solution that distinguishes the cases:
> 1. we don't expect this test to pass on this bsp
> 2. we expect this test to pass, but know it doesn't currently
> They are two very different things, and I don't like conflating them
> into one "expected-fail" case
originally, I had the same point of view. What I didn't take into
account was the perspective of the tester. Now, I think it is perfectly
fine to flag these tests as expected failure test states. Because right
now, due to some known bugs such as https://devel.rtems.org/ticket/3982
and probably also some more issues, these tests fail. On this BSP and
this RTEMS version, they will always fail. This is not some sort of
random failure. When we change test states to expected failure I think
we should make sure that a ticket exists, which captures that there are
some test results which indicate issues (expected failure test state).
The ticket system is the better place to manage this. We should not use
the test states for this. The test states should be used to figure out
changes between different test runs. They should enable also to quickly
check if the outcome of a test run yields the expected results for a
certain RTEMS version and BSP.
