[PATCH 4/6] testsuite: Add expected-fail to psim
Chris Johns
chrisj at rtems.org
Tue May 12 09:11:08 UTC 2020
On 12/5/20 5:15 pm, Sebastian Huber wrote:
> Hello,
> On 09/05/2020 03:30, Gedare Bloom wrote:
>>>>> Without these tests being tagged this way the user would have no
>>>>> idea where the stand after a build and test run and that would mean
>>>>> we would have to make sure a release has no failures. I consider
>>>>> that as not practical or realistic.
>>>> Maybe we need another state, e.g. something-is-broken-please-fix-it.
>>> I do not think so, it is implicit in the failure or the test is
>>> broken. The only change is to add unexpected-pass, that will be on
>>> master after the 5 branch.
>> I disagree with this in principle, and it should be reverted after we
>> branch 5. It's fine for now to get the release state sync'd, but we
>> should find a long-term solution that distinguishes the cases:
>> 1. we don't expect this test to pass on this bsp
>> 2. we expect this test to pass, but know it doesn't currently
>> They are two very different things, and I don't like conflating them
>> into one "expected-fail" case
> originally, I had the same point of view. What I didn't take into
> account was the perspective of the tester. Now, I think it is perfectly
> fine to flag these tests as expected failure test states. Because right
> now, due to some known bugs such as https://devel.rtems.org/ticket/3982
> and probably also some more issues, these tests fail. On this BSP and
> this RTEMS version, they will always fail. This is not some sort of
> random failure. When we change test states to expected failure I think
> we should make sure that a ticket exists, which captures that there are
> some test results which indicate issues (expected failure test state).
> The ticket system is the better place to manage this. We should not use
> the test states for this. The test states should be used to figure out
> changes between different test runs. They should enable also to quickly
> check if the outcome of a test run yields the expected results for a
> certain RTEMS version and BSP.
Thanks. It is clear to me we lack documentation on this topic and this
is an oversight on my part which I will attempt to correct.
I have reviewed Dejagnu and considered other things like the withdrawn
IEEE 1003.3 standard and there are states we have that need to change
but I think the original intent is the right path.
The Dejagnu states are documented here:
https://www.gnu.org/software/dejagnu/manual/A-POSIX-Conforming-Test-Framework.html#A-POSIX-Conforming-Test-Framework
And the exit codes are:
https://www.gnu.org/software/dejagnu/manual/Runtest.html#Runtest
For me they define the goal and intent.
The test states are metadata for the tester so it can determine the
result of any given set of tests in relation to the expected state of
the test when it was built. You need to detach yourself from being a
developer and put yourself in the position of a tester who's task is to
give an overall pass or fail for a specific build of RTEMS without
needing to consider the specifics of any test, bug or feature.
The primary requirement is to allow machine check of the results to
determine regressions. A regression is a failure, pass or unresolved
result that was not expected.
My current thinking for test states are:
PASS:
The test has succeeded and passed without a failure.
UNEXCEPTED-PASS:
The test has succeeded when it was expected to fail.
FAIL:
The test has not succeeded and has failed when it was expected to pass.
The failure can be a failed assert, unhandled exception, resource
constraint, or a faulty test.
EXCEPTED-FAIL:
The test has not succeeded and has failed and this is expected.
UNRESOLVED:
The test has not completed and the result cannot be determined. The
result can be unresolved because the test did not start or end, test
harness failure, insufficient computing resources for the test harness
to function correctly.
EXCEPTED-UNRESOLVED:
The test has not completed and the result cannot be determined and this
is expected.
INDETERMINATE:
The test has succeeded, has failed or in unresolved. The test is an edge
case where the test can pass, can fail, can be unresolved and this is
expected.
USER-INPUT:
The test has not completed and the result is unresolved because it
requires user intervention that cannot be provided.
BENCHMARK:
The test performs a performance type test. These are currently not
supported.
UNTESTED:
The test has not run and is a place holder for a real test that is not
yet provided.
UNSUPPORTED:
The test is not supported for this build of RTEMS, BSP or architecture.
Note:
1. Any expected failures, unresolved, or indeterminate test results are
considered faults and require fixing.
2. The nature of a failure cannot be inferred from the test's metadata
state.
3. The timeout and invalid states will be merged into UNRESOLVED.
4. The excluded state will be changed to UNSUPPORTED.
5. The metadata is placed in each test because is it an effective way to
capture the state. Tests can be run as a group, stand alone or at
different location and the test results can determine a regression. The
version of the test harness does not need to match the RTEMS build.
This list of test states account for some missing states. It also adds
some states I do not see being available until we move to a new build
system. For UNTESTED and UNSUPPORTED I see a template test being built
and run and does nothing. This is important because it means we get a
complete set of test results that are complete and consistent for all BSPs.
I can attend to this change before releasing 5.1 or it can be done on
master and we can determine if it is back ported to 5.2[34..].
The change will come with documentation to explain thing a little better.
I hope this addresses the issues we have and I am sorry for creating a
disturbance so close to a release.
