Small doubt in RTEMS testsuite codes
Richi Dubey
richidubey at gmail.com
Tue May 12 07:48:01 UTC 2020
Heyy Everyone,
When I am opening testsuites/sptests/sp01/init.c , I can see the
following function definition:
rtems_task Init( rtems_task_argument argument )
and when I open testsuites/sptests/sp01/task1.c ( which is
compiled(linked) together with init.c in the makefile in build of
bsp), I can see the following function:
rtems_task Task_1_through_3( rtems_task_argument index).
Can someone please tell me how do the sp01 testsuite run without a int
main? If Init() is the start point then where does it gets it argument
'argument' from?
Thanks,
Richi.
