Small doubt in RTEMS testsuite codes
Sebastian Huber
Tue May 12 08:05:20 UTC 2020
On 12/05/2020 09:48, Richi Dubey wrote:
> Heyy Everyone,
> When I am opening testsuites/sptests/sp01/init.c , I can see the
> following function definition:
> rtems_task Init( rtems_task_argument argument )
> and when I open testsuites/sptests/sp01/task1.c ( which is
> compiled(linked) together with init.c in the makefile in build of
> bsp), I can see the following function:
> rtems_task Task_1_through_3( rtems_task_argument index).
> Can someone please tell me how do the sp01 testsuite run without a int
> main? If Init() is the start point then where does it gets it argument
> 'argument' from?
You may have a look at:
https://docs.rtems.org/branches/master/c-user/initialization.html
https://docs.rtems.org/branches/master/c-user/config/index.html
I think your question is not really well answered by our current
documentation set. While you read the documentation please always try to
improve it. I you think something is missing or could be better
explained, then just send patches.
Independent of the documentation you should set up a test environment
with GDB support. You can set a break point to Init(). This points you
to the code which determines the argument value.
