Small doubt in RTEMS testsuite codes
Gedare Bloom
gedare at rtems.org
Fri May 15 22:31:19 UTC 2020
On Fri, May 15, 2020 at 4:22 PM Richi Dubey <richidubey at gmail.com> wrote:
> Hii ,
> Thanks for the help. I am going through the docs you referred and have
> submitted a patch for the scheduler's doc, please have a look.
> Could you please tell me how do I set up a test environment with GDB
> support? Does it just mean running the applications with rtems5-gdb?
It means running a BSP that you are able to debug using gdb. The erc32
running on sis can be debugged using gdb. Couple of other simulated
targets can also.
> On Tue, May 12, 2020 at 1:35 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > On 12/05/2020 09:48, Richi Dubey wrote:
> > > Heyy Everyone,
> > > When I am opening testsuites/sptests/sp01/init.c , I can see the
> > > following function definition:
> > > rtems_task Init( rtems_task_argument argument )
> > > and when I open testsuites/sptests/sp01/task1.c ( which is
> > > compiled(linked) together with init.c in the makefile in build of
> > > bsp), I can see the following function:
> > > rtems_task Task_1_through_3( rtems_task_argument index).
> > > Can someone please tell me how do the sp01 testsuite run without a int
> > > main? If Init() is the start point then where does it gets it argument
> > > 'argument' from?
> > You may have a look at:
> > https://docs.rtems.org/branches/master/c-user/initialization.html
> > https://docs.rtems.org/branches/master/c-user/config/index.html
> > I think your question is not really well answered by our current
> > documentation set. While you read the documentation please always try to
> > improve it. I you think something is missing or could be better
> > explained, then just send patches.
> > Independent of the documentation you should set up a test environment
> > with GDB support. You can set a break point to Init(). This points you
> > to the code which determines the argument value.
> devel mailing list
> devel at rtems.org
