Small doubt in RTEMS testsuite codes
Richi Dubey richidubey at gmail.com
Thu May 14 12:55:01 UTC 2020
Hii ,
Thanks for the help. I am going through the docs you referred and have
submitted a patch for the scheduler's doc, please have a look.
Could you please tell me how do I set up a test environment with GDB
support? Does it just mean running the applications with rtems5-gdb?
On Tue, May 12, 2020 at 1:35 PM Sebastian Huber
> On 12/05/2020 09:48, Richi Dubey wrote:
> > Heyy Everyone,
> > When I am opening testsuites/sptests/sp01/init.c , I can see the
> > following function definition:
> > rtems_task Init(  rtems_task_argument argument )
> > and when I open testsuites/sptests/sp01/task1.c ( which is
> > compiled(linked) together with init.c in the makefile in build of
> > bsp), I can see the following function:
> > rtems_task Task_1_through_3(  rtems_task_argument index).
> > Can someone please tell me how do the sp01 testsuite run without a int
> > main? If Init() is the start point then where does it gets it argument
> > 'argument' from?
> You may have a look at:
> https://docs.rtems.org/branches/master/c-user/initialization.html
> https://docs.rtems.org/branches/master/c-user/config/index.html
> I think your question is not really well answered by our current
> documentation set. While you read the documentation please always try to
> improve it. I you think something is missing or could be better
> explained, then just send patches.
> Independent of the documentation you should set up a test environment
> with GDB support. You can set a break point to Init(). This points you
> to the code which determines the argument value.
