[PATCH 2/2] Spelling/Grammar Mistakes
Richi Dubey
richidubey at gmail.com
Thu May 14 12:50:02 UTC 2020
c-user/scheduling_concepts.rst | 50 +++++++++++++++++-----------------
1 file changed, 25 insertions(+), 25 deletions(-)
diff --git a/c-user/scheduling_concepts.rst b/c-user/scheduling_concepts.rst
index dac39a8..d329bc4 100644
--- a/c-user/scheduling_concepts.rst
+++ b/c-user/scheduling_concepts.rst
@@ -16,7 +16,7 @@ Introduction
The concept of scheduling in real-time systems dictates the ability to provide
-immediate response to specific external events, particularly the necessity of
+an immediate response to specific external events, particularly the necessity of
scheduling tasks to run within a specified time limit after the occurrence of
an event. For example, software embedded in life-support systems used to
monitor hospital patients must take instant action if a change in the patient's
@@ -38,7 +38,7 @@ The directives provided by the scheduler manager are:
- rtems_scheduler_get_maximum_priority_ - Get maximum task priority of a scheduler
- rtems_scheduler_map_priority_to_posix_ - Map task priority to POSIX thread
- prority
+ priority
- rtems_scheduler_map_priority_from_posix_ - Map POSIX thread priority to task
prority
@@ -58,8 +58,8 @@ The directives provided by the scheduler manager are:
Scheduling Algorithms
-RTEMS provides a plugin framework which allows it to support multiple
-scheduling algorithms. RTEMS includes multiple scheduling algorithms and the
+RTEMS provides a plugin framework that allows it to support multiple
+scheduling algorithms. RTEMS includes multiple scheduling algorithms, and the
user can select which of these they wish to use in their application at
link-time. In addition, the user can implement their own scheduling algorithm
and configure RTEMS to use it.
@@ -69,8 +69,8 @@ select the algorithm which is most appropriate to their use case. Most
real-time operating systems schedule tasks using a priority based algorithm,
possibly with preemption control. The classic RTEMS scheduling algorithm which
was the only algorithm available in RTEMS 4.10 and earlier, is a fixed-priority
-scheduling algorithm. This scheduling algoritm is suitable for uniprocessor
-(e.g. non-SMP) systems and is known as the *Deterministic Priority
+scheduling algorithm. This scheduling algorithm is suitable for uniprocessor
+(e.g., non-SMP) systems and is known as the *Deterministic Priority
Scheduler*. Unless the user configures another scheduling algorithm, RTEMS
will use this on uniprocessor systems.
@@ -87,7 +87,7 @@ in time is the one with the highest priority among all tasks in the ready
state.
When a task is added to the ready chain, it is placed behind all other tasks of
-the same priority. This rule provides a round-robin within priority group
+the same priority. This rule provides a round-robin within a priority group
scheduling characteristic. This means that in a group of equal priority tasks,
tasks will execute in the order they become ready or FIFO order. Even though
there are ways to manipulate and adjust task priorities, the most important
@@ -100,7 +100,7 @@ rule to remember is:
Priority scheduling is the most commonly used scheduling algorithm. It should
be used by applications in which multiple tasks contend for CPU time or other
-resources and there is a need to ensure certain tasks are given priority over
+resources, and there is a need to ensure certain tasks are given priority over
other tasks.
There are a few common methods of accomplishing the mechanics of this
@@ -127,7 +127,7 @@ algorithm. These ways involve a list or chain of tasks in the ready state.
the ready queue.
RTEMS currently includes multiple priority based scheduling algorithms as well
-as other algorithms which incorporate deadline. Each algorithm is discussed in
+as other algorithms that incorporate deadline. Each algorithm is discussed in
the following sections.
Uniprocessor Schedulers
@@ -142,13 +142,13 @@ Deterministic Priority Scheduler
This is the scheduler implementation which has always been in RTEMS. After the
-4.10 release series, it was factored into pluggable scheduler selection. It
+4.10 release series, it was factored into a pluggable scheduler selection. It
schedules tasks using a priority based algorithm which takes into account
preemption. It is implemented using an array of FIFOs with a FIFO per
priority. It maintains a bitmap which is used to track which priorities have
ready tasks.
-This algorithm is deterministic (e.g. predictable and fixed) in execution time.
+This algorithm is deterministic (e.g., predictable and fixed) in execution time.
This comes at the cost of using slightly over three (3) kilobytes of RAM on a
system configured to support 256 priority levels.
@@ -167,7 +167,7 @@ determine where to insert the newly readied task.
This algorithm uses much less RAM than the Deterministic Priority Scheduler but
is *O(n)* where *n* is the number of ready tasks. In a small system with a
small number of tasks, this will not be a performance issue. Reducing RAM
-consumption is often critical in small systems which are incapable of
+consumption is often critical in small systems that are incapable of
supporting a large number of tasks.
This scheduler is only aware of a single core.
@@ -179,23 +179,23 @@ This scheduler is only aware of a single core.
Earliest Deadline First Scheduler
-This is an alternative scheduler in RTEMS for single core applications. The
+This is an alternative scheduler in RTEMS for single-core applications. The
primary EDF advantage is high total CPU utilization (theoretically up to
100%). It assumes that tasks have priorities equal to deadlines.
This EDF is initially preemptive, however, individual tasks may be declared
-not-preemptive. Deadlines are declared using only Rate Monotonic manager which
-goal is to handle periodic behavior. Period is always equal to deadline. All
+not-preemptive. Deadlines are declared using only Rate Monotonic manager whose
+goal is to handle periodic behavior. Period is always equal to the deadline. All
ready tasks reside in a single ready queue implemented using a red-black tree.
This implementation of EDF schedules two different types of task priority types
while each task may switch between the two types within its execution. If a
task does have a deadline declared using the Rate Monotonic manager, the task
-is deadline-driven and its priority is equal to deadline. On the contrary if a
+is deadline-driven and its priority is equal to deadline. On the contrary, if a
task does not have any deadline or the deadline is cancelled using the Rate
Monotonic manager, the task is considered a background task with priority equal
to that assigned upon initialization in the same manner as for priority
-scheduler. Each background task is of a lower importance than each
+scheduler. Each background task is of lower importance than each
deadline-driven one and is scheduled when no deadline-driven task and no higher
priority background task is ready to run.
@@ -203,7 +203,7 @@ Every deadline-driven scheduling algorithm requires means for tasks to claim a
deadline. The Rate Monotonic Manager is responsible for handling periodic
execution. In RTEMS periods are equal to deadlines, thus if a task announces a
period, it has to be finished until the end of this period. The call of
-``rtems_rate_monotonic_period`` passes the scheduler the length of oncoming
+``rtems_rate_monotonic_period`` passes the scheduler the length of an oncoming
deadline. Moreover, the ``rtems_rate_monotonic_cancel`` and
``rtems_rate_monotonic_delete`` calls clear the deadlines assigned to the task.
@@ -214,7 +214,7 @@ deadline. Moreover, the ``rtems_rate_monotonic_cancel`` and
Constant Bandwidth Server Scheduling (CBS)
CBS is a budget aware extension of EDF scheduler. The main goal of this
scheduler is to ensure temporal isolation of tasks meaning that a task's
execution in terms of meeting deadlines must not be influenced by other tasks
@@ -258,7 +258,7 @@ active deadline are background tasks. In case deadlines are not used, then the
EDF scheduler behaves exactly like a fixed-priority scheduler. The tasks with
an active deadline have a higher priority than the background tasks. This
scheduler supports :ref:`task processor affinities <rtems_task_set_affinity>`
-of one-to-one and one-to-all, e.g. a task can execute on exactly one processor
+of one-to-one and one-to-all, e.g., a task can execute on exactly one processor
or all processors managed by the scheduler instance. The processor affinity
set of a task must contain all online processors to select the one-to-all
affinity. This is to avoid pathological cases if processors are added/removed
@@ -431,7 +431,7 @@ directive. While a task occupies this state it does not have a TCB or a task
ID assigned to it; therefore, no other tasks in the system may reference this
task.
-When a task is created via the ``rtems_task_create`` directive it enters the
+When a task is created via the ``rtems_task_create`` directive, it enters the
dormant state. This state is not entered through any other means. Although
the task exists in the system, it cannot actively compete for system resources.
It will remain in the dormant state until it is started via the
@@ -457,10 +457,10 @@ of the following conditions:
- The running task issues a ``rtems_barrier_wait`` directive.
- The running task issues a ``rtems_message_queue_receive`` directive with the
- wait option and the message queue is empty.
+ wait option, and the message queue is empty.
-- The running task issues an ``rtems_event_receive`` directive with the wait
- option and the currently pending events do not satisfy the request.
+- The running task issues a ``rtems_event_receive`` directive with the wait
+ option, and the currently pending events do not satisfy the request.
- The running task issues a ``rtems_semaphore_obtain`` directive with the wait
option and the requested semaphore is unavailable.
@@ -498,7 +498,7 @@ conditions:
waiting.
- A running task issues an ``rtems_event_send`` directive which sends an event
- condition to a task which is blocked waiting on that event condition.
+ condition to a task that is blocked waiting on that event condition.
- A running task issues a ``rtems_semaphore_release`` directive which releases
the semaphore on which the blocked task is waiting.
2.17.1
