Help RTEMS 5
Vijay Kumar Banerjee
vijay at rtems.org
Sat May 16 14:24:18 UTC 2020
(Adding Devel back to CC)
On Sat, May 16, 2020 at 6:22 AM Daniela Oliveira <oliveiradad at gmail.com>
wrote:
> >Vijay
> > Here is a print of the command and error, the package I am using is
> rtems 4.11.2 and I am following the rtems.org tutorial
The commands shown in the picture are for RTEMS 5
For 4.11.2, please follow the documentation here:
https://docs.rtems.org/releases/rtems-docs-4.11.2/user/start/index.html
There's a typo in your command, the option to enable erc32 BSP would be
--enable-rtemsbsp=erc32
I hope it helped.
Best regards,
Vijay
> >Best regards,
> >Daniela
> Enviado do Email <https://go.microsoft.com/fwlink/?LinkId=550986> para
> Windows 10
> *De: *Vijay Kumar Banerjee <vijay at rtems.org>
> *Enviado:*quinta-feira, 14 de maio de 2020 11:09
> *Para: *Daniela Oliveira <oliveiradad at gmail.com>
> *Assunto: *Re: Re: Help RTEMS 5
> On Thu, May 14, 2020 at 1:13 AM Daniela Oliveira <oliveiradad at gmail.com>
> wrote:
> > >Hi Vijay,
> > >This is the error that I saw:
> > >checking wether build enviroment is sane...yes
> > >checking for sparc-rtems5-strip.. no
> Can you please post the command you're using to build the sparc
> toolchain from RSB?
> Also, please attach the log files form sparc toolchain build and the
> RTEMS configuration command, this will help understand what's going on
> there with the sparc-rtems5 toolchain.
> Please also Check your PATH to ensure that the rtems bin path is added
> correctly.
> Best regards,
> Vijay
> > >checking for strip...strip
> > >configure: WARNING: using cross tools not prefixed whit host triplet
> > >checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
> > >Tks
> > Enviado do Email para Windows 10
> > De: Vijay Kumar Banerjee
> > Enviado:terça-feira, 12 de maio de 2020 11:14
> > Para: Daniela Oliveira
> > Cc:users at rtems.org
> > Assunto: Re: Help RTEMS 5
> > Hi Daniela
> > On Tue, May 12, 2020 at 7:24 PM Daniela Oliveira <oliveiradad at gmail.com>
> wrote:
> > > >Hi,
> > > > I'm installing rtems 5 and came across the following error: checking
> for sparc-rtems 5-strip ... no
> > There is a space in "sparc-rtems 5-strip" if this is not a typo that
> > seeped in while pasting here, then
> > this might be the source of the error. If that's not the case then
> > please check that you have
> > sparc-rtems5-strip in your PATH.
> > > > when I create the makefile.
> > > > I saw some reports of this same error and I couldn't find the
> solution.
> > Did the sparc-rtems5 toolchain build complete successfully?
> > > > I would appreciate a help, as this is the first time I install rtems.
> > > >Tks
> > > >Daniela
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200516/87478cf6/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200516/87478cf6/attachment-0001.png>
