Adding fenv support for ARM
Sat May 16 14:39:00 UTC 2020
On Fri, May 15, 2020, 5:59 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> On Fri, May 15, 2020 at 2:22 AM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> On Wed, May 13, 2020 at 7:40 PM Joel Sherrill <joel at rtems.org> wrote:
>>> National free hint day!!!
>>> Look above the line that is reported. You will see __BEGIN_DECL. It
>>> isn't defined. It is intended to expand to the __cplusplus wrapper.
>>> After you fix this, you will sequentially find 2 other things to change
>>> in this file.
>>> I have made those changes when a new error occurs from the assembler in
>> arm thumb mode
>> There is no support for vfp instructions in arm thumb.
>> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html
>> So in which file will the compiler instructions given in the page
>> <http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html>
>> added?
> FreeBSD has added file and architecture-specific flags in their
> makefile.inc
> https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/Makefile.inc
> How will it be added in newlib
> I tried adding the flags -mfpu=vfp -mfloat-abi=softfp (used in FreeBSD) to
> makefile.in but no effect.
This isn't going to work with newlib. They don't specify CPU flags that way.
The fenv code is going to have to compile for every multilib variant built
by arm-rtems and arm-eabi. You will have to use conditionals based on the
flags gcc uses to indicate the various cpu features. This command should be
close to how you you dump them.
gcc -dM -E - </dev/null
Add a CPU flag and see how the setting change.
You can also look in rtems score cpu arm for examples since the core arm
code will be dealing with these.
--joel
> thanks
> -Eshan
>> Errors :
>> make[9]: Entering directory
>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine/arm'
>> arm-rtems5-gcc
>> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/
>> -isystem
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include
>> -isystem /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include
>>  -mthumb -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
>> -DPACKAGE_VERSION=\"3.3.0\" -DPACKAGE_STRING=\"newlib\ 3.3.0\"
>> -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -I.
>> -I../../../../../../../newlib-cygwin/newlib/libm/machine/arm -I
>> ../../../../../../../newlib-cygwin/newlib/libm/machine/arm/../../../../newlib/libm/common
>> -fno-builtin -mfpu=vfpv2 -ffunction-sections -fdata-sections
>>  -D_COMPILING_NEWLIB -DCLOCK_PROVIDED -DMALLOC_PROVIDED -DEXIT_PROVIDED
>> -DSIGNAL_PROVIDED -DGETREENT_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED
>> -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL -DHAVE_ASSERT_FUNC
>> -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET
>> -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI      -g -O2
>>  -mthumb -c -o lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo
>> '../../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-vfp.c
>> /tmp/ccEHiFws.s: Assembler messages:
>> /tmp/ccEHiFws.s:37: Error: selected processor does not support `vmrs
>> r3,fpscr' in Thumb mode
>> /tmp/ccEHiFws.s:48: Error: selected processor does not support `vmsr
>> fpscr,r3' in Thumb mode
>> /tmp/ccEHiFws.s:81: Error: selected processor does not support `vmrs
>> /tmp/ccEHiFws.s:119: Error: selected processor does not support `vmrs
>> /tmp/ccEHiFws.s:134: Error: selected processor does not support `vmsr
>> /tmp/ccEHiFws.s:169: Error: selected processor does not support `vmrs
>> /tmp/ccEHiFws.s:182: Error: selected processor does not support `vmsr
>> /tmp/ccEHiFws.s:217: Error: selected processor does not support `vmrs
>> /tmp/ccEHiFws.s:251: Error: selected processor does not support `vmrs
>> r0,fpscr' in Thumb mode
>> /tmp/ccEHiFws.s:288: Error: selected processor does not support `vmrs
>> /tmp/ccEHiFws.s:303: Error: selected processor does not support `vmsr
>> fpscr,r0' in Thumb mode
>> /tmp/ccEHiFws.s:340: Error: selected processor does not support `vmrs
>> /tmp/ccEHiFws.s:374: Error: selected processor does not support `vmrs
>> /tmp/ccEHiFws.s:390: Error: selected processor does not support `vmsr
>> /tmp/ccEHiFws.s:424: Error: selected processor does not support `vmsr
>> /tmp/ccEHiFws.s:457: Error: selected processor does not support `vmrs
>> r1,fpscr' in Thumb mode
>> /tmp/ccEHiFws.s:466: Error: selected processor does not support `vmsr
>> /tmp/ccEHiFws.s:478: Error: selected processor does not support `vmrs
>> r2,fpscr' in Thumb mode
>> /tmp/ccEHiFws.s:503: Error: selected processor does not support `vmsr
>> /tmp/ccEHiFws.s:543: Error: selected processor does not support `vmrs
>> /tmp/ccEHiFws.s:559: Error: selected processor does not support `vmsr
>> /tmp/ccEHiFws.s:595: Error: selected processor does not support `vmrs
>> /tmp/ccEHiFws.s:612: Error: selected processor does not support `vmsr
>> fpscr,r2' in Thumb mode
>> /tmp/ccEHiFws.s:647: Error: selected processor does not support `vmrs
>> Makefile:476: recipe for target 'lib_a-fenv-vfp.o' failed
>> make[9]: *** [lib_a-fenv-vfp.o] Error 1
>> make[9]: Leaving directory
>> Makefile:324: recipe for target 'all-recursive' failed
>> make[8]: *** [all-recursive] Error 1
>> make[8]: Leaving directory
>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine'
>> Makefile:553: recipe for target 'all-recursive' failed
>> make[7]: *** [all-recursive] Error 1
>> make[7]: Leaving directory
>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm'
>> Makefile:641: recipe for target 'all-recursive' failed
>> make[6]: *** [all-recursive] Error 1
>> make[6]: Leaving directory
>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib'
>> Makefile:452: recipe for target 'all' failed
>> make[5]: *** [all] Error 2
>> make[5]: Leaving directory
>> Makefile:1260: recipe for target 'multi-do' failed
>> make[4]: *** [multi-do] Error 1
>> make[4]: Leaving directory
>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib'
>> Makefile:1176: recipe for target 'all-multi' failed
>> make[3]: *** [all-multi] Error 2
>> make[3]: Leaving directory
>> make[2]: *** [all] Error 2
>> make[2]: Leaving directory
>> Makefile:8491: recipe for target 'all-target-newlib' failed
>> make[1]: *** [all-target-newlib] Error 2
>> make[1]: Leaving directory
>> '/home/eshan/development/newlib/c-arm-rtems5-newlib'
>> Makefile:878: recipe for target 'all' failed
>> make: *** [all] Error 2
>> -Eshan
>>> Then we need to make a decision whether the static inline versions of
>>> the methods in sys/fenv.h are appropriate for newlib or not.
>>> --joel
>>> On Tue, May 12, 2020 at 5:20 PM Joel Sherrill <joel at rtems.org> wrote:
>>>> Gedare is right but one more piece of information is needed. When
>>>> newlib is being built, it lays target dependent files on top of generic
>>>> ones. So the default sys/fenv.h is replaced with something like
>>>> libc/machine/arm/sys/fenv.h. Make sure that
>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h is
>>>> in fact the file you think it should be.
>>>> Also look at what is supposed to be in the generic fenv.h and
>>>> <sys/fenv.h>. You will probably have to tweak it some.
>>>> Check out what is in x86_64/fenv.h and riscv/fenv.h with respect to the
>>>> default environment variable. It looks to be declared differently in the
>>>> other ports so you may have to make it match.
>>>> But more output does help.
>>>> --joel
>>>> On Tue, May 12, 2020 at 4:53 PM Gedare Bloom <gedare at rtems.org> wrote:
>>>>> Take the first error reported, and show what is being compiled. You've
>>>>> trimmed off too much preceding this to know what is being compiled and
>>>>> how this might be influencing your error.
>>>>> The specific error you're getting is often due to some syntax errors
>>>>> preceding the line shown.
>>>>> On Tue, May 12, 2020 at 2:59 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>>> wrote:
>>>>> > Hello everyone,
>>>>> > After adding the files and compiling. I am
>>>>> > getting a few errors which I am not able to rectify.
>>>>> > If you could take a look and tell how to sort them.
>>>>> > link to newlib's git repo:
>>>>> https://github.com/eshandhawan51/newlib-cygwin/tree/add_fenv_support
>>>>> > errors :
>>>>> > In file included from
>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:15:0,
>>>>> >                  from
>>>>> ../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:
>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include/sys/fenv.h:82:1:
>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'extern'
>>>>> >  extern const fenv_t *_fe_dfl_env;
>>>>> ../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:0:
>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:22:1:
>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'int'
>>>>> >  int feclearexcept(int excepts);
>>>>> > thanks
>>>>> > -Eshan
>>>>> > On Sat, May 9, 2020 at 2:53 AM Joel Sherrill <joel at rtems.org> wrote:
>>>>> >> On Thu, May 7, 2020 at 1:33 PM Eshan Dhawan <
>>>>> >>> Hello everyone,
>>>>> >>> This the tread to discuss adding fenv support for ARM architecture
>>>>> in newlib.
>>>>> >>> Link to previous thread:
>>>>> https://lists.rtems.org/pipermail/devel/2020-March/058473.html
>>>>> >>> ---FreeBSD Source
>>>>> >>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
>>>>> https://github.com/freebsd/freebsd/blob/master/sys/arm/include/ieeefp.h
>>>>> >>> ---NetBSD Source
>>>>> >>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
>>>>> >>> --- Musl has no implementation for fenv support for ARM  in it
>>>>> >>> After going through the implementations both FreeBSD and NetBSD
>>>>> have a stub implementation.
>>>>> >>> But then FreeBSD implementation seems to be more portable compared
>>>>> to that in NetBSD.
>>>>> >>> Should I start porting it from FreeBSD?
>>>>> >>> And which ARM BSP should I use for testing the changes?
>>>>> >>> Currently, I have xilinx_zynq_a9_qemu build
>>>>> >> I think the FreeBSD implementation is the one to use. It looks to
>>>>> support hard and soft floating point implementations.
>>>>> >> I think the fenv.h file there will have to be worked on so some of
>>>>> the contents go into sys or machine/fenv.h. There is a portable fenv.h.
>>>>> >>> There would also be a requirement to discuss where to place the
>>>>> files in Newlib.
>>>>> >> Not much to discuss. It should go into
>>>>> newlib-cygwin/newlib/libm/machine/arm.
>>>>> >>> Thanks
>>>>> >>> -Eshan
>>>>> > _______________________________________________
>>>>> > devel mailing list
>>>>> > devel at rtems.org
>>>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200516/30a4f6da/attachment-0001.html>
