Adding fenv support for ARM
Eshan Dhawan eshandhawan51 at gmail.com
Tue May 19 18:48:08 UTC 2020
Hello
I have encountered a new error
the error is coming from libm/fenv
link to GitHub repository:
https://github.com/eshandhawan51/newlib-cygwin/tree/add_fenv_support
Make file log:
eshan at EDs-pc:~/development/newlib/c-arm-rtems5-newlib$ make -k
make[1]: Entering directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib'
make[2]: Entering directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib/etc'
make[2]: Nothing to be done for 'all'.
make[2]: Leaving directory
Checking multilib configuration for newlib...
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib'
make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2" "CCASFLAGS=-g -O2"
"CFLAGS_FOR_BUILD=-g -O2" "CFLAGS_FOR_TARGET=-g -O2"
"INSTALL=/usr/bin/install -c" "LDFLAGS=" "LIBCFLAGS=-g -O2"
"LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make" "MAKEINFO=makeinfo
--split-size=5000000 --split-size=5000000 " "PICFLAG="
"PICFLAG_FOR_TARGET=" "SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest"
"RUNTESTFLAGS=" "exec_prefix=/usr/local" "infodir=/usr/local/share/info"
"libdir=/usr/local/lib" "prefix=/usr/local" "tooldir=/usr/local/arm-rtems5"
"top_toollibdir=/usr/local/arm-rtems5/lib" "AR=arm-rtems5-ar"
"AS=arm-rtems5-as" "CC=arm-rtems5-gcc
-B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/
-isystem
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include
-isystem /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include
" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2" "NM=arm-rtems5-nm" "PICFLAG="
"RANLIB=arm-rtems5-ranlib" "DESTDIR=" all-recursive
make[3]: Entering directory
-isystem
"RANLIB=arm-rtems5-ranlib" "DESTDIR=" DO=all multi-do # make
make[4]: Entering directory
if [ -z "thumb vfp/hard thumb/armv6-m thumb/armv7-a thumb/armv7-r
thumb/cortex-m3 thumb/cortex-m4 thumb/armv7-a/neon/hard
thumb/armv7-r/vfpv3-d16/hard thumb/cortex-m4/fpv4-sp-d16/hard
thumb/cortex-m7/fpv5-d16/hard eb/thumb/armv7-r
eb/thumb/armv7-r/vfpv3-d16/hard" ]; then \
  true; \
else \
  rootpre=`${PWDCMD-pwd}`/; export rootpre; \
  srcrootpre=`cd ../../../newlib-cygwin/newlib; ${PWDCMD-pwd}`/; export
srcrootpre; \
  lib=`echo "${rootpre}" | sed -e 's,^.*/\([^/][^/]*\)/$,\1,'`; \
  compiler="arm-rtems5-gcc
-isystem
  for i in `${compiler} --print-multi-lib 2>/dev/null`; do \
    dir=`echo $i | sed -e 's/;.*$//'`; \
    if [ "${dir}" = "." ]; then \
      true; \
    else \
      if [ -d ../${dir}/${lib} ]; then \
flags=`echo $i | sed -e 's/^[^;]*;//' -e 's/@/ -/g'`; \
if (cd ../${dir}/${lib}; make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g
-O2" "CCASFLAGS=-g -O2" "CFLAGS_FOR_BUILD=-g -O2" "CFLAGS_FOR_TARGET=-g
-O2" "INSTALL=/usr/bin/install -c" "LDFLAGS=" "LIBCFLAGS=-g -O2"
-isystem
"RANLIB=arm-rtems5-ranlib" "DESTDIR=" \
CFLAGS="-g -O2 ${flags}" \
CCASFLAGS="-g -O2 ${flags}" \
FCFLAGS=" ${flags}" \
FFLAGS=" ${flags}" \
ADAFLAGS=" ${flags}" \
prefix="/usr/local" \
exec_prefix="/usr/local" \
GCJFLAGS=" ${flags}" \
GOCFLAGS="-O2 -g ${flags}" \
CXXFLAGS="-g -O2 ${flags}" \
LIBCFLAGS="-g -O2 ${flags}" \
LIBCXXFLAGS="-g -O2 -fno-implicit-templates ${flags}" \
LDFLAGS=" ${flags}" \
MULTIFLAGS="${flags}" \
DESTDIR="" \
INSTALL="/usr/bin/install -c" \
INSTALL_DATA="/usr/bin/install -c -m 644" \
INSTALL_PROGRAM="/usr/bin/install -c" \
INSTALL_SCRIPT="/usr/bin/install -c" \
all); then \
 true; \
else \
 exit 1; \
fi; \
      else true; \
      fi; \
    fi; \
  done; \
fi
make[5]: Entering directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib'
make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mthumb"
"CCASFLAGS=-g -O2  -mthumb" "CFLAGS_FOR_BUILD=-g -O2" "CFLAGS_FOR_TARGET=-g
-O2" "INSTALL=/usr/bin/install -c" "LDFLAGS=-mthumb" "LIBCFLAGS=-g -O2
 -mthumb" "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make" "MAKEINFO=makeinfo
"top_toollibdir=/usr/local/arm-rtems5/lib/thumb" "AR=arm-rtems5-ar"
-B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/
-isystem
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include
 -mthumb" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2  -mthumb" "NM=arm-rtems5-nm"
"PICFLAG=" "RANLIB=arm-rtems5-ranlib" "DESTDIR=" all-recursive
make[6]: Entering directory
true "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mthumb"
-isystem
"PICFLAG=" "RANLIB=arm-rtems5-ranlib" "DESTDIR=" DO=all multi-do # make
Making all in libc
make[7]: Entering directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc'
Making all in argz
make[8]: Entering directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/argz'
make[8]: Nothing to be done for 'all'.
make[8]: Leaving directory
Making all in stdlib
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/stdlib'
Making all in ctype
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/ctype'
Making all in search
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/search'
Making all in stdio
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/stdio'
Making all in string
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/string'
Making all in signal
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/signal'
Making all in time
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/time'
Making all in locale
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/locale'
Making all in sys
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/sys'
Making all in rtems
make[9]: Entering directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/sys/rtems'
make[9]: Nothing to be done for 'all'.
make[9]: Leaving directory
Making all in .
make[9]: Nothing to be done for 'all-am'.
Making all in reent
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/reent'
Making all in errno
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/errno'
Making all in misc
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/misc'
Making all in machine
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/machine'
Making all in arm
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/machine/arm'
Making all in .
Making all in unix
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/unix'
Making all in posix
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/posix'
Making all in ssp
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/ssp'
Making all in .
make[8]: Nothing to be done for 'all-am'.
make[7]: Leaving directory
Making all in libm
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm'
Making all in math
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/math'
Making all in common
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/common'
Making all in complex
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/complex'
Making all in fenv
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/fenv'
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine'
Making all in arm
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine/arm'
Making all in .
Making all in .
rm -f thumb/crt0.o
ln libc/crt0.o thumb/crt0.o >/dev/null 2>/dev/null || cp libc/crt0.o
thumb/crt0.o
rm -f thumb/libc.a ./thumb/libg.a
ln libc.a thumb/libc.a >/dev/null 2>/dev/null || cp libc.a thumb/libc.a
ln libg.a ./thumb/libg.a >/dev/null 2>/dev/null || \
cp libg.a ./thumb/libg.a
rm -f thumb/libm.a
ln libm.a thumb/libm.a >/dev/null 2>/dev/null || cp libm.a thumb/libm.a
make[6]: Leaving directory
make[5]: Leaving directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib'
make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mfpu=vfp
-mfloat-abi=hard" "CCASFLAGS=-g -O2  -mfpu=vfp -mfloat-abi=hard"
"INSTALL=/usr/bin/install -c" "LDFLAGS=-mfpu=vfp -mfloat-abi=hard"
"LIBCFLAGS=-g -O2  -mfpu=vfp -mfloat-abi=hard" "LIBCFLAGS_FOR_TARGET=-g
-O2" "MAKE=make" "MAKEINFO=makeinfo --split-size=5000000
--split-size=5000000    " "PICFLAG=" "PICFLAG_FOR_TARGET="
"SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest" "RUNTESTFLAGS="
"top_toollibdir=/usr/local/arm-rtems5/lib/vfp/hard" "AR=arm-rtems5-ar"
-B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/
-isystem
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include
 -mfpu=vfp -mfloat-abi=hard" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2
 -mfpu=vfp -mfloat-abi=hard" "NM=arm-rtems5-nm" "PICFLAG="
true "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mfpu=vfp
-isystem
Making all in libc
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc'
Making all in argz
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/argz'
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/stdlib'
Making all in ctype
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/ctype'
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/search'
Making all in stdio
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/stdio'
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/string'
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/signal'
Making all in time
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/time'
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/locale'
Making all in sys
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/sys'
Making all in rtems
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/sys/rtems'
Making all in .
Making all in reent
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/reent'
Making all in errno
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/errno'
Making all in misc
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/misc'
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/machine'
Making all in arm
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/machine/arm'
Making all in .
Making all in unix
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/unix'
Making all in posix
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/posix'
Making all in ssp
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/ssp'
Making all in .
Making all in libm
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm'
Making all in math
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/math'
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/common'
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/complex'
Making all in fenv
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/fenv'
arm-rtems5-gcc
-isystem
 -mfpu=vfp -mfloat-abi=hard -DPACKAGE_NAME=\"newlib\"
-DPACKAGE_TARNAME=\"newlib\" -DPACKAGE_VERSION=\"3.3.0\"
-DPACKAGE_STRING=\"newlib\ 3.3.0\" -DPACKAGE_BUGREPORT=\"\"
-DPACKAGE_URL=\"\" -I.
-I../../../../../../../newlib-cygwin/newlib/libm/fenv -fno-builtin
-ffunction-sections -fdata-sections  -D_COMPILING_NEWLIB -DCLOCK_PROVIDED
-DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED -DGETREENT_PROVIDED
-DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL
-DHAVE_ASSERT_FUNC -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS
-D_NO_SIGSET -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI
  -fbuiltin -fno-math-errno  -g -O2  -mfpu=vfp -mfloat-abi=hard -c -o
lib_a-feclearexcept.o `test -f 'feclearexcept.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feclearexcept.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:64:5:
error: redefinition of 'feclearexcept'
 int feclearexcept(int excepts)
In file included from
/home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:15:0,
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:126:1:
note: previous definition of 'feclearexcept' was here
Makefile:347: recipe for target 'lib_a-feclearexcept.o' failed
make[8]: *** [lib_a-feclearexcept.o] Error 1
arm-rtems5-gcc
-isystem
lib_a-fegetenv.o `test -f 'fegetenv.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetenv.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetenv.c:64:5: error:
redefinition of 'fegetenv'
 int fegetenv(fenv_t *envp)
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetenv.c:29:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:198:1:
note: previous definition of 'fegetenv' was here
Makefile:359: recipe for target 'lib_a-fegetenv.o' failed
make[8]: *** [lib_a-fegetenv.o] Error 1
arm-rtems5-gcc
-isystem
lib_a-fegetexceptflag.o `test -f 'fegetexceptflag.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetexceptflag.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetexceptflag.c:65:5:
error: redefinition of 'fegetexceptflag'
 int fegetexceptflag(fexcept_t *flagp, int excepts)
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetexceptflag.c:29:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:137:1:
note: previous definition of 'fegetexceptflag' was here
Makefile:365: recipe for target 'lib_a-fegetexceptflag.o' failed
make[8]: *** [lib_a-fegetexceptflag.o] Error 1
arm-rtems5-gcc
-isystem
lib_a-fegetround.o `test -f 'fegetround.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetround.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetround.c:63:5:
error: redefinition of 'fegetround'
 int fegetround(void)
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetround.c:29:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:177:1:
note: previous definition of 'fegetround' was here
 fegetround(void)
Makefile:371: recipe for target 'lib_a-fegetround.o' failed
make[8]: *** [lib_a-fegetround.o] Error 1
arm-rtems5-gcc
-isystem
lib_a-feholdexcept.o `test -f 'feholdexcept.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feholdexcept.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/feholdexcept.c:67:5:
error: redefinition of 'feholdexcept'
 int feholdexcept(fenv_t *envp)
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/feholdexcept.c:29:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:206:1:
note: previous definition of 'feholdexcept' was here
Makefile:377: recipe for target 'lib_a-feholdexcept.o' failed
make[8]: *** [lib_a-feholdexcept.o] Error 1
arm-rtems5-gcc
-isystem
lib_a-feraiseexcept.o `test -f 'feraiseexcept.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feraiseexcept.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/feraiseexcept.c:64:5:
error: redefinition of 'feraiseexcept'
 int feraiseexcept(int excepts)
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/feraiseexcept.c:29:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:159:1:
note: previous definition of 'feraiseexcept' was here
Makefile:383: recipe for target 'lib_a-feraiseexcept.o' failed
make[8]: *** [lib_a-feraiseexcept.o] Error 1
arm-rtems5-gcc
-isystem
lib_a-fesetenv.o `test -f 'fesetenv.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetenv.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetenv.c:69:5: error:
redefinition of 'fesetenv'
 int fesetenv(const fenv_t *envp)
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetenv.c:29:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:218:1:
note: previous definition of 'fesetenv' was here
Makefile:389: recipe for target 'lib_a-fesetenv.o' failed
make[8]: *** [lib_a-fesetenv.o] Error 1
arm-rtems5-gcc
-isystem
lib_a-fesetexceptflag.o `test -f 'fesetexceptflag.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetexceptflag.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetexceptflag.c:70:5:
error: redefinition of 'fesetexceptflag'
 int fesetexceptflag(const fexcept_t *flagp, int excepts)
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetexceptflag.c:29:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:147:1:
note: previous definition of 'fesetexceptflag' was here
Makefile:395: recipe for target 'lib_a-fesetexceptflag.o' failed
make[8]: *** [lib_a-fesetexceptflag.o] Error 1
arm-rtems5-gcc
-isystem
lib_a-fesetround.o `test -f 'fesetround.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetround.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetround.c:64:5:
error: redefinition of 'fesetround'
 int fesetround(int round)
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetround.c:29:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:186:1:
note: previous definition of 'fesetround' was here
Makefile:401: recipe for target 'lib_a-fesetround.o' failed
make[8]: *** [lib_a-fesetround.o] Error 1
arm-rtems5-gcc
-isystem
lib_a-fetestexcept.o `test -f 'fetestexcept.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fetestexcept.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/fetestexcept.c:65:5:
error: redefinition of 'fetestexcept'
 int fetestexcept(int excepts)
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/fetestexcept.c:30:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:168:1:
note: previous definition of 'fetestexcept' was here
Makefile:407: recipe for target 'lib_a-fetestexcept.o' failed
make[8]: *** [lib_a-fetestexcept.o] Error 1
arm-rtems5-gcc
-isystem
lib_a-feupdateenv.o `test -f 'feupdateenv.c' || echo
'../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feupdateenv.c
../../../../../../../newlib-cygwin/newlib/libm/fenv/feupdateenv.c:69:5:
error: redefinition of 'feupdateenv'
 int feupdateenv(const fenv_t *envp)
                 from
../../../../../../../newlib-cygwin/newlib/libm/fenv/feupdateenv.c:29:
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:226:1:
note: previous definition of 'feupdateenv' was here
Makefile:413: recipe for target 'lib_a-feupdateenv.o' failed
make[8]: *** [lib_a-feupdateenv.o] Error 1
make[8]: Target 'all' not remade because of errors.
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/machine'
Making all in arm
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/machine/arm'
Making all in .
rm -f libm.a
rm -rf tmp
mkdir tmp
cd tmp; \
  for i in math/lib.a common/lib.a complex/lib.a fenv/lib.a machine/lib.a;
do \
    arm-rtems5-ar x ../$i; \
done; \
arm-rtems5-ar rc ../libm.a *.o
arm-rtems5-ar: ../fenv/lib.a: No such file or directory
arm-rtems5-ranlib libm.a
rm -rf tmp
Makefile:553: recipe for target 'all-recursive' failed
make[7]: *** [all-recursive] Error 1
make[7]: Target 'all' not remade because of errors.
Making all in .
rm -f libm.a
ln libm/libm.a libm.a >/dev/null 2>/dev/null || cp libm/libm.a libm.a
rm -rf libc.a libg.a tmp
mkdir tmp
cd tmp; \
 arm-rtems5-ar x ../libm.a lib_a-s_fpclassify.o lib_a-sf_fpclassify.o
lib_a-s_isinf.o lib_a-sf_isinf.o lib_a-s_isnan.o lib_a-sf_isnan.o
lib_a-s_isinfd.o lib_a-sf_isinff.o lib_a-s_isnand.o lib_a-sf_isnanf.o
lib_a-s_nan.o lib_a-sf_nan.o lib_a-s_ldexp.o lib_a-sf_ldexp.o
lib_a-s_frexp.o lib_a-sf_frexp.o lib_a-s_modf.o lib_a-sf_modf.o
lib_a-s_scalbn.o lib_a-sf_scalbn.o lib_a-s_finite.o lib_a-sf_finite.o
lib_a-s_copysign.o lib_a-sf_copysign.o ; \
 arm-rtems5-ar x ../libc/libc.a ; \
 arm-rtems5-ar rc ../libc.a *.o
arm-rtems5-ranlib libc.a
ln libc.a libg.a >/dev/null 2>/dev/null || cp libc.a libg.a
rm -rf tmp
rm -f vfp/hard/crt0.o
ln libc/crt0.o vfp/hard/crt0.o >/dev/null 2>/dev/null || cp libc/crt0.o
vfp/hard/crt0.o
rm -f vfp/hard/libc.a ./vfp/hard/libg.a
ln libc.a vfp/hard/libc.a >/dev/null 2>/dev/null || cp libc.a
vfp/hard/libc.a
ln libg.a ./vfp/hard/libg.a >/dev/null 2>/dev/null || \
cp libg.a ./vfp/hard/libg.a
rm -f vfp/hard/libm.a
ln libm.a vfp/hard/libm.a >/dev/null 2>/dev/null || cp libm.a
vfp/hard/libm.a
Makefile:641: recipe for target 'all-recursive' failed
make[6]: *** [all-recursive] Error 1
Makefile:452: recipe for target 'all' failed
make[5]: *** [all] Error 2
Makefile:1260: recipe for target 'multi-do' failed
make[4]: *** [multi-do] Error 1
make[4]: Leaving directory
Makefile:1176: recipe for target 'all-multi' failed
make[3]: *** [all-multi] Error 2
make[3]: Target 'all-recursive' not remade because of errors.
make[3]: Leaving directory
make[2]: *** [all] Error 2
Makefile:8491: recipe for target 'all-target-newlib' failed
make[1]: *** [all-target-newlib] Error 2
make[1]: Target 'all-target' not remade because of errors.
make[1]: Leaving directory
Makefile:878: recipe for target 'all' failed
make: *** [all] Error 2
Thanks
-Eshan :)
On Sat, May 16, 2020 at 8:09 PM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, May 15, 2020, 5:59 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> On Fri, May 15, 2020 at 2:22 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>> wrote:
>>> On Wed, May 13, 2020 at 7:40 PM Joel Sherrill <joel at rtems.org> wrote:
>>>> National free hint day!!!
>>>> Look above the line that is reported. You will see __BEGIN_DECL. It
>>>> isn't defined. It is intended to expand to the __cplusplus wrapper.
>>>> After you fix this, you will sequentially find 2 other things to change
>>>> in this file.
>>>> I have made those changes when a new error occurs from the assembler in
>>> arm thumb mode
>>> There is no support for vfp instructions in arm thumb.
>>> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html
>>> So in which file will the compiler instructions given in the page
>>> <http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html>
>>> added?
>> FreeBSD has added file and architecture-specific flags in their
>> makefile.inc
>> https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/Makefile.inc
>> How will it be added in newlib
>> I tried adding the flags -mfpu=vfp -mfloat-abi=softfp (used in FreeBSD)
>> to makefile.in but no effect.
> This isn't going to work with newlib. They don't specify CPU flags that
> way.
> The fenv code is going to have to compile for every multilib variant built
> by arm-rtems and arm-eabi. You will have to use conditionals based on the
> flags gcc uses to indicate the various cpu features. This command should be
> close to how you you dump them.
> gcc -dM -E - </dev/null
> Add a CPU flag and see how the setting change.
> You can also look in rtems score cpu arm for examples since the core arm
> code will be dealing with these.
> --joel
>> thanks
>> -Eshan
>>> Errors :
>>> arm-rtems5-gcc
>>> -isystem
>>>  -mthumb -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
>>> -DPACKAGE_VERSION=\"3.3.0\" -DPACKAGE_STRING=\"newlib\ 3.3.0\"
>>> -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -I.
>>> -I../../../../../../../newlib-cygwin/newlib/libm/machine/arm -I
>>> ../../../../../../../newlib-cygwin/newlib/libm/machine/arm/../../../../newlib/libm/common
>>> -fno-builtin -mfpu=vfpv2 -ffunction-sections -fdata-sections
>>>  -D_COMPILING_NEWLIB -DCLOCK_PROVIDED -DMALLOC_PROVIDED -DEXIT_PROVIDED
>>> -DSIGNAL_PROVIDED -DGETREENT_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED
>>> -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL -DHAVE_ASSERT_FUNC
>>> -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET
>>> -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI      -g -O2
>>>  -mthumb -c -o lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo
>>> '../../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-vfp.c
>>> /tmp/ccEHiFws.s: Assembler messages:
>>> /tmp/ccEHiFws.s:37: Error: selected processor does not support `vmrs
>>> r3,fpscr' in Thumb mode
>>> /tmp/ccEHiFws.s:48: Error: selected processor does not support `vmsr
>>> fpscr,r3' in Thumb mode
>>> /tmp/ccEHiFws.s:81: Error: selected processor does not support `vmrs
>>> /tmp/ccEHiFws.s:119: Error: selected processor does not support `vmrs
>>> /tmp/ccEHiFws.s:134: Error: selected processor does not support `vmsr
>>> /tmp/ccEHiFws.s:169: Error: selected processor does not support `vmrs
>>> /tmp/ccEHiFws.s:182: Error: selected processor does not support `vmsr
>>> /tmp/ccEHiFws.s:217: Error: selected processor does not support `vmrs
>>> /tmp/ccEHiFws.s:251: Error: selected processor does not support `vmrs
>>> r0,fpscr' in Thumb mode
>>> /tmp/ccEHiFws.s:288: Error: selected processor does not support `vmrs
>>> /tmp/ccEHiFws.s:303: Error: selected processor does not support `vmsr
>>> fpscr,r0' in Thumb mode
>>> /tmp/ccEHiFws.s:340: Error: selected processor does not support `vmrs
>>> /tmp/ccEHiFws.s:374: Error: selected processor does not support `vmrs
>>> /tmp/ccEHiFws.s:390: Error: selected processor does not support `vmsr
>>> /tmp/ccEHiFws.s:424: Error: selected processor does not support `vmsr
>>> /tmp/ccEHiFws.s:457: Error: selected processor does not support `vmrs
>>> r1,fpscr' in Thumb mode
>>> /tmp/ccEHiFws.s:466: Error: selected processor does not support `vmsr
>>> /tmp/ccEHiFws.s:478: Error: selected processor does not support `vmrs
>>> r2,fpscr' in Thumb mode
>>> /tmp/ccEHiFws.s:503: Error: selected processor does not support `vmsr
>>> /tmp/ccEHiFws.s:543: Error: selected processor does not support `vmrs
>>> /tmp/ccEHiFws.s:559: Error: selected processor does not support `vmsr
>>> /tmp/ccEHiFws.s:595: Error: selected processor does not support `vmrs
>>> /tmp/ccEHiFws.s:612: Error: selected processor does not support `vmsr
>>> fpscr,r2' in Thumb mode
>>> /tmp/ccEHiFws.s:647: Error: selected processor does not support `vmrs
>>> Makefile:476: recipe for target 'lib_a-fenv-vfp.o' failed
>>> make[9]: *** [lib_a-fenv-vfp.o] Error 1
>>> Makefile:324: recipe for target 'all-recursive' failed
>>> make[8]: *** [all-recursive] Error 1
>>> -Eshan
>>>> Then we need to make a decision whether the static inline versions of
>>>> the methods in sys/fenv.h are appropriate for newlib or not.
>>>> --joel
>>>> On Tue, May 12, 2020 at 5:20 PM Joel Sherrill <joel at rtems.org> wrote:
>>>>> Gedare is right but one more piece of information is needed. When
>>>>> newlib is being built, it lays target dependent files on top of generic
>>>>> ones. So the default sys/fenv.h is replaced with something like
>>>>> libc/machine/arm/sys/fenv.h. Make sure that
>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h is
>>>>> in fact the file you think it should be.
>>>>> Also look at what is supposed to be in the generic fenv.h and
>>>>> <sys/fenv.h>. You will probably have to tweak it some.
>>>>> Check out what is in x86_64/fenv.h and riscv/fenv.h with respect to
>>>>> the default environment variable. It looks to be declared differently in
>>>>> the other ports so you may have to make it match.
>>>>> But more output does help.
>>>>> --joel
>>>>> On Tue, May 12, 2020 at 4:53 PM Gedare Bloom <gedare at rtems.org> wrote:
>>>>>> Take the first error reported, and show what is being compiled. You've
>>>>>> trimmed off too much preceding this to know what is being compiled and
>>>>>> how this might be influencing your error.
>>>>>> The specific error you're getting is often due to some syntax errors
>>>>>> preceding the line shown.
>>>>>> On Tue, May 12, 2020 at 2:59 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>>>> wrote:
>>>>>> > Hello everyone,
>>>>>> > After adding the files and compiling. I am
>>>>>> > getting a few errors which I am not able to rectify.
>>>>>> > If you could take a look and tell how to sort them.
>>>>>> > link to newlib's git repo:
>>>>>> > errors :
>>>>>> >                  from
>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include/sys/fenv.h:82:1:
>>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'extern'
>>>>>> >  extern const fenv_t *_fe_dfl_env;
>>>>>> ../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:0:
>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:22:1:
>>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'int'
>>>>>> >  int feclearexcept(int excepts);
>>>>>> > thanks
>>>>>> > -Eshan
>>>>>> > On Sat, May 9, 2020 at 2:53 AM Joel Sherrill <joel at rtems.org>
>>>>>> wrote:
>>>>>> >> On Thu, May 7, 2020 at 1:33 PM Eshan Dhawan <
>>>>>> eshandhawan51 at gmail.com> wrote:
>>>>>> >>> Hello everyone,
>>>>>> >>> This the tread to discuss adding fenv support for ARM
>>>>>> architecture in newlib.
>>>>>> >>> Link to previous thread:
>>>>>> https://lists.rtems.org/pipermail/devel/2020-March/058473.html
>>>>>> >>> ---FreeBSD Source
>>>>>> >>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
>>>>>> https://github.com/freebsd/freebsd/blob/master/sys/arm/include/ieeefp.h
>>>>>> >>> ---NetBSD Source
>>>>>> >>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
>>>>>> >>> --- Musl has no implementation for fenv support for ARM  in it
>>>>>> >>> After going through the implementations both FreeBSD and NetBSD
>>>>>> have a stub implementation.
>>>>>> >>> But then FreeBSD implementation seems to be more portable
>>>>>> compared to that in NetBSD.
>>>>>> >>> Should I start porting it from FreeBSD?
>>>>>> >>> And which ARM BSP should I use for testing the changes?
>>>>>> >>> Currently, I have xilinx_zynq_a9_qemu build
>>>>>> >> I think the FreeBSD implementation is the one to use. It looks to
>>>>>> support hard and soft floating point implementations.
>>>>>> >> I think the fenv.h file there will have to be worked on so some of
>>>>>> the contents go into sys or machine/fenv.h. There is a portable fenv.h.
>>>>>> >>> There would also be a requirement to discuss where to place the
>>>>>> files in Newlib.
>>>>>> >> Not much to discuss. It should go into
>>>>>> newlib-cygwin/newlib/libm/machine/arm.
>>>>>> >>> Thanks
>>>>>> >>> -Eshan
>>>>>> > _______________________________________________
>>>>>> > devel mailing list
>>>>>> > devel at rtems.org
>>>>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200520/a47b55b8/attachment-0001.html>
