[rtems/rsb]: Adding PTP support to RSB [GSoC 2020]
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Tue May 19 14:12:06 UTC 2020
Hello everyone,
Starting this thread to discuss and give a detail of my progress in
relation to
my GSoC 2020 project "BSP Buildset for EPICS".
It is to tell that I have worked on adding ptp2 support as suggested by
mentors
The implementation that I found could work was ptp2 daemon and so worked
with
it.
I added these files:
rsb/rtems/config/net/ptpd-2.3-1.cfg
rsb/rtems/config/net/ptpd.bset
rsb/source-builder/config/ptpd-2.1.cfg
I am attaching the .diff file and the bug that I have encountered in the
respective txt file and will like the help of mentors in trying to help me
fix it.
I will also be uploading the files on my GitHub repo as well which can be
accessed from here:
https://github.com/mritunjaysharma394/rtems-source-builder
Thanks,
Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200519/89753b02/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: building ptpd-2.3.1-sparc-rtems5-1
Command Line: ../source-builder/sb-set-builder --log=log_sis_net_snmp --prefix=/home/mritunjay/development/rtems/5 --with-tools=/home/mritunjay/development/rtems/5 --host=sparc-rtems5 --with-rtems-bsp=erc32 net/ptpd
Python: 2.7.17 (default, Apr 15 2020, 17:20:14) [GCC 7.5.0]
git://git.rtems.org/rtems-source-builder.git/origin/96cdedce58e32f07c174966676e8b7e8c6620634
Linux mritunjay-XPS-15-9570 5.3.0-51-generic #44~18.04.2-Ubuntu SMP Thu Apr 23 14:27:18 UTC 2020 x86_64
Tail of the build log:
script: 21: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 22: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 23: SB_ARCH="sparc"
script: 24: SB_OS="linux"
script: 25: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 26: export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS SB_HOST_LIBS
script: 27: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
script: 28: export SB_CFLAGS SB_CXXFLAGS
script: 29: # Documentation
script: 30: SB_DOC_DIR="/home/mritunjay/development/rtems/5/share/doc"
script: 31: export SB_DOC_DIR
script: 32: # Packages
script: 33: SB_PACKAGE_NAME="ptpd-2.3.1-sparc-rtems5-1"
script: 34: SB_PACKAGE_BUILDNAME="ptpd-2.3.1-sparc-rtems5-1"
script: 35: SB_PACKAGE_VERSION="2.3.1"
script: 36: SB_PACKAGE_RELEASE="1"
script: 37: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 38: # Build directories
script: 39: export SB_PREFIX
script: 40: SB_BUILD_DIR="/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1"
script: 41: SB_BUILD_ROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000"
script: 42: SB_BUILD_ROOT_BINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000/${SB_PREFIX_CLEAN}/bin"
script: 43: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 44: SB_BUILD_CXC_DIR="/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1-cxc"
script: 45: SB_BUILD_CXC_ROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000-cxc"
script: 46: SB_BUILD_CXC_ROOT_BINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000-cxc/${SB_PREFIX_CLEAN}/bin"
script: 47: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 48: SB_TMPROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd"
script: 49: SB_TMPPREFIX="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/${SB_PREFIX_CLEAN}"
script: 50: SB_TMPBINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/${SB_PREFIX_CLEAN}/bin"
script: 51: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 52: SB_TMPCXCROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd"
script: 53: SB_TMPCXCPREFIX="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/${SB_PREFIX_CLEAN}"
script: 54: SB_TMPCXCBINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/${SB_PREFIX_CLEAN}/bin"
script: 55: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 56: # Extra path support
script: 57: SB_EXTRAPATH="/home/mritunjay/development/rtems/rsb/source-builder"
script: 58: # The compiler flags
script: 59:
script: 60:
script: 61: export CFLAGS_FOR_TARGET
script: 62: export CXXFLAGS_FOR_TARGET
script: 63: # Set up the path. Put the CXC path first.
script: 64: if test -n "${SB_TMPBINDIR}" ; then
script: 65: PATH="${SB_TMPBINDIR}:$PATH"
script: 66: fi
script: 67: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 68: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 69: fi
script: 70: if test -n "${SB_EXTRAPATH}" ; then
script: 71: PATH="${SB_EXTRAPATH}:$PATH"
script: 72: fi
script: 73: PATH="/home/mritunjay/development/rtems/5/bin:$PATH"
script: 74:
script: 75: export PATH
script: 76: # Default environment set up.
script: 77: LANG=C
script: 78: export LANG
script: 79: unset DISPLAY || :
script: 80: umask 022
script: 81: cd "/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1"
script: 82: echo "=> ptpd-2.3.1-sparc-rtems5-1: CLEAN"
script: 83: echo "==> %clean:"
removing: /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1
making dir: /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1
write script: /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/do-build
write script: /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/do-clean
building: ptpd-2.3.1-sparc-rtems5-1
run: /bin/sh -ex /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/do-build
+ export SB_ORIG_PATH=/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ SB_PREFIX=/home/mritunjay/development/rtems/5
+ + echo /home/mritunjay/development/rtems/5
/bin/sed -e s/^\///
+ SB_PREFIX_CLEAN=home/mritunjay/development/rtems/5
+ SB_SOURCE_DIR=/home/mritunjay/development/rtems/rsb/rtems/sources
+ SB_BUILD_DIR=/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1
+ SB_HOST_CPPFLAGS=-I/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/include
+ SB_HOST_CFLAGS=-qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ SB_HOST_CXXFLAGS=-qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ echo -qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ awk {for (i=1;i<NF;++i) if ($i ~ /\-m/) printf("%s ",$i);}
+ SB_HOST_LDFLAGS=-L/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib -mcpu=cypress -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/lib
+ SB_HOST_LIBS=-lrtemsdefaultconfig
+ SB_BUILD_CFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ SB_BUILD_CXXFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ SB_BUILD_LDFLAGS= -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/lib
+ SB_BUILD_LBS=
+ SB_CFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ SB_CXXFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ SB_ARCH=sparc
+ SB_OS=linux
+ export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
+ export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS SB_HOST_LIBS
+ export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
+ export SB_CFLAGS SB_CXXFLAGS
+ SB_DOC_DIR=/home/mritunjay/development/rtems/5/share/doc
+ export SB_DOC_DIR
+ SB_PACKAGE_NAME=ptpd-2.3.1-sparc-rtems5-1
+ SB_PACKAGE_BUILDNAME=ptpd-2.3.1-sparc-rtems5-1
+ SB_PACKAGE_VERSION=2.3.1
+ SB_PACKAGE_RELEASE=1
+ export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
+ export SB_PREFIX
+ SB_BUILD_ROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000
+ SB_BUILD_ROOT_BINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000/home/mritunjay/development/rtems/5/bin
+ export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
+ SB_BUILD_CXC_DIR=/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1-cxc
+ SB_BUILD_CXC_ROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000-cxc
+ SB_BUILD_CXC_ROOT_BINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000-cxc/home/mritunjay/development/rtems/5/bin
+ export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
+ SB_TMPROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd
+ SB_TMPPREFIX=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5
+ SB_TMPBINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin
+ export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
+ SB_TMPCXCROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd
+ SB_TMPCXCPREFIX=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5
+ SB_TMPCXCBINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5/bin
+ export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
+ SB_EXTRAPATH=/home/mritunjay/development/rtems/rsb/source-builder
+ export CFLAGS_FOR_TARGET
+ export CXXFLAGS_FOR_TARGET
+ test -n /home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin
+ PATH=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ test -n /home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5/bin
+ PATH=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ test -n /home/mritunjay/development/rtems/rsb/source-builder
+ PATH=/home/mritunjay/development/rtems/rsb/source-builder:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
=> ptpd-2.3.1-sparc-rtems5-1: BUILD
==> %prep:
+ PATH=/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/source-builder:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ export PATH
+ LANG=C
+ export LANG
+ unset DISPLAY
+ umask 022
+ cd /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1
+ echo => ptpd-2.3.1-sparc-rtems5-1: BUILD
+ echo ==> %prep:
+ pwd
+ build_top=/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1
+ source_dir_ptpd=ptpd-2.3.1
+ /bin/rm -rf ptpd-2.3.1
+ /usr/bin/xz -dc /home/mritunjay/development/rtems/rsb/rtems/sources/ptpd-2.3.1-debian1.orig.tar.xz
+ /bin/tar -xvv -f -
drwxr-xr-x stigge/stigge 0 2015-06-29 20:44 ptpd-2.3.1/
-rw-r--r-- stigge/stigge 29375 2015-06-29 20:43 ptpd-2.3.1/Makefile.in
-rw-r--r-- stigge/stigge 15590 2015-06-29 20:41 ptpd-2.3.1/ChangeLog
drwxr-xr-x stigge/stigge 0 2015-06-29 20:44 ptpd-2.3.1/build-aux/
-rwxr-xr-x stigge/stigge 35564 2015-06-29 20:41 ptpd-2.3.1/build-aux/config.sub
-rwxr-xr-x stigge/stigge 6872 2015-06-29 20:41 ptpd-2.3.1/build-aux/missing
-rwxr-xr-x stigge/stigge 7333 2015-06-29 20:41 ptpd-2.3.1/build-aux/compile
-rwxr-xr-x stigge/stigge 45297 2015-06-29 20:41 ptpd-2.3.1/build-aux/config.guess
-rwxr-xr-x stigge/stigge 23566 2015-06-29 20:41 ptpd-2.3.1/build-aux/depcomp
-rwxr-xr-x stigge/stigge 13997 2015-06-29 20:41 ptpd-2.3.1/build-aux/install-sh
-rw-r--r-- stigge/stigge 283684 2015-06-29 20:41 ptpd-2.3.1/build-aux/ltmain.sh
-rw-r--r-- stigge/stigge 42075 2015-06-29 20:43 ptpd-2.3.1/aclocal.m4
-rw-r--r-- stigge/stigge 2349 2015-06-29 20:41 ptpd-2.3.1/COPYRIGHT
drwxr-xr-x stigge/stigge 0 2015-06-29 20:44 ptpd-2.3.1/m4/
-rw-r--r-- stigge/stigge 286793 2015-06-29 20:41 ptpd-2.3.1/m4/libtool.m4
-rw-r--r-- stigge/stigge 4372 2015-06-29 20:41 ptpd-2.3.1/m4/ltsugar.m4
-rw-r--r-- stigge/stigge 12347 2015-06-29 20:41 ptpd-2.3.1/m4/ltoptions.m4
-rw-r--r-- stigge/stigge 128 2015-06-29 20:41 ptpd-2.3.1/m4/version.m4
-rw-r--r-- stigge/stigge 6126 2015-06-29 20:41 ptpd-2.3.1/m4/lt~obsolete.m4
-rw-r--r-- stigge/stigge 690 2015-06-29 20:41 ptpd-2.3.1/m4/ltversion.m4
-rw-r--r-- stigge/stigge 1641 2015-06-29 20:41 ptpd-2.3.1/README
-rwxr-xr-x stigge/stigge 482406 2015-06-29 20:43 ptpd-2.3.1/configure
drwxr-xr-x stigge/stigge 0 2015-06-29 20:44 ptpd-2.3.1/src/
-rw-r--r-- stigge/stigge 34413 2015-06-29 20:43 ptpd-2.3.1/src/Makefile.in
-rw-r--r-- stigge/stigge 59294 2015-06-29 20:41 ptpd-2.3.1/src/ptpd2.conf.5.in
-rw-r--r-- stigge/stigge 5313 2015-06-29 20:41 ptpd-2.3.1/src/timingdomain.h
-rw-r--r-- stigge/stigge 41942 2015-06-29 20:41 ptpd-2.3.1/src/signaling.c
-rw-r--r-- stigge/stigge 3593 2015-06-29 20:41 ptpd-2.3.1/src/ptp_timers.h
-rw-r--r-- stigge/stigge 25066 2015-06-29 20:41 ptpd-2.3.1/src/bmc.c
-rw-r--r-- stigge/stigge 16694 2015-06-29 20:41 ptpd-2.3.1/src/ptpd.h
-rw-r--r-- stigge/stigge 4511 2015-06-29 20:41 ptpd-2.3.1/src/ptpd.c
-rw-r--r-- stigge/stigge 8599 2015-06-29 20:41 ptpd-2.3.1/src/arith.c
-rw-r--r-- stigge/stigge 10383 2015-06-29 20:41 ptpd-2.3.1/src/leap-seconds.list.28dec2015
-rw-r--r-- stigge/stigge 59279 2015-06-29 20:43 ptpd-2.3.1/src/ptpd2.conf.5
-rw-r--r-- stigge/stigge 10427 2015-06-29 20:41 ptpd-2.3.1/src/constants.h
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/src/def/
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/src/def/message/
-rw-r--r-- stigge/stigge 423 2015-06-29 20:41 ptpd-2.3.1/src/def/message/management.def
-rw-r--r-- stigge/stigge 717 2015-06-29 20:41 ptpd-2.3.1/src/def/message/header.def
-rw-r--r-- stigge/stigge 229 2015-06-29 20:41 ptpd-2.3.1/src/def/message/signaling.def
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/
-rw-r--r-- stigge/stigge 454 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/faultRecord.def
-rw-r--r-- stigge/stigge 268 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/portAddress.def
-rw-r--r-- stigge/stigge 212 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/ptpText.def
-rw-r--r-- stigge/stigge 261 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/clockQuality.def
-rw-r--r-- stigge/stigge 246 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/tlv.def
-rw-r--r-- stigge/stigge 440 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/timePropertiesDS.def
-rw-r--r-- stigge/stigge 175 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/timeInterval.def
-rw-r--r-- stigge/stigge 232 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/portIdentity.def
-rw-r--r-- stigge/stigge 211 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/timestamp.def
-rw-r--r-- stigge/stigge 378 2015-06-29 20:41 ptpd-2.3.1/src/def/derivedData/physicalAddress.def
-rw-r--r-- stigge/stigge 439 2015-06-29 20:41 ptpd-2.3.1/src/def/README
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/
-rw-r--r-- stigge/stigge 194 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/time.def
-rw-r--r-- stigge/stigge 237 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/clockAccuracy.def
-rw-r--r-- stigge/stigge 262 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/managementTLV.def
-rw-r--r-- stigge/stigge 238 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/logSyncInterval.def
-rw-r--r-- stigge/stigge 276 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/versionNumber.def
-rw-r--r-- stigge/stigge 256 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/logMinPdelayReqInterval.def
-rw-r--r-- stigge/stigge 239 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/delayMechanism.def
-rw-r--r-- stigge/stigge 208 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/initialize.def
-rw-r--r-- stigge/stigge 225 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/domain.def
-rw-r--r-- stigge/stigge 480 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/defaultDataSet.def
-rw-r--r-- stigge/stigge 225 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/priority1.def
-rw-r--r-- stigge/stigge 631 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/portDataSet.def
-rw-r--r-- stigge/stigge 217 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/slaveOnly.def
-rw-r--r-- stigge/stigge 306 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/errorStatus.def
-rw-r--r-- stigge/stigge 305 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/timePropertiesDataSet.def
-rw-r--r-- stigge/stigge 1112 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/clockDescription.def
-rw-r--r-- stigge/stigge 225 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/priority2.def
-rw-r--r-- stigge/stigge 245 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/userDescription.def
-rw-r--r-- stigge/stigge 235 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/traceabilityProperties.def
-rw-r--r-- stigge/stigge 272 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/utcProperties.def
-rw-r--r-- stigge/stigge 292 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/currentDataSet.def
-rw-r--r-- stigge/stigge 253 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/announceReceiptTimeout.def
-rw-r--r-- stigge/stigge 246 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/logAnnounceInterval.def
-rw-r--r-- stigge/stigge 580 2015-06-29 20:41 ptpd-2.3.1/src/def/managementTLV/parentDataSet.def
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/src/def/signalingTLV/
-rw-r--r-- stigge/stigge 294 2015-06-29 20:41 ptpd-2.3.1/src/def/signalingTLV/cancelUnicastTransmission.def
-rw-r--r-- stigge/stigge 347 2015-06-29 20:41 ptpd-2.3.1/src/def/signalingTLV/requestUnicastTransmission.def
-rw-r--r-- stigge/stigge 200 2015-06-29 20:41 ptpd-2.3.1/src/def/signalingTLV/signalingTLV.def
-rw-r--r-- stigge/stigge 418 2015-06-29 20:41 ptpd-2.3.1/src/def/signalingTLV/grantUnicastTransmission.def
-rw-r--r-- stigge/stigge 299 2015-06-29 20:41 ptpd-2.3.1/src/def/signalingTLV/acknowledgeCancelUnicastTransmission.def
-rw-r--r-- stigge/stigge 1346 2015-06-29 20:41 ptpd-2.3.1/src/ptpd2.conf.minimal
-rw-r--r-- stigge/stigge 33375 2015-06-29 20:41 ptpd-2.3.1/src/ptpd2.conf.default-full
-rw-r--r-- stigge/stigge 130176 2015-06-29 20:41 ptpd-2.3.1/src/protocol.c
drwxr-xr-x stigge/stigge 0 2015-06-29 20:44 ptpd-2.3.1/src/dep/
-rw-r--r-- stigge/stigge 33306 2015-06-29 20:41 ptpd-2.3.1/src/dep/startup.c
-rw-r--r-- stigge/stigge 24667 2015-06-29 20:41 ptpd-2.3.1/src/dep/statistics.c
-rw-r--r-- stigge/stigge 6221 2015-06-29 20:41 ptpd-2.3.1/src/dep/eventtimer_itimer.c
-rw-r--r-- stigge/stigge 57964 2015-06-29 20:41 ptpd-2.3.1/src/dep/net.c
-rw-r--r-- stigge/stigge 2317 2015-06-29 20:41 ptpd-2.3.1/src/dep/daemonconfig.h
drwxr-xr-x stigge/stigge 0 2015-06-29 20:44 ptpd-2.3.1/src/dep/iniparser/
-rw-r--r-- stigge/stigge 6829 2015-06-29 20:41 ptpd-2.3.1/src/dep/iniparser/dictionary.h
-rw-r--r-- stigge/stigge 23366 2015-06-29 20:41 ptpd-2.3.1/src/dep/iniparser/iniparser.c
-rw-r--r-- stigge/stigge 11574 2015-06-29 20:41 ptpd-2.3.1/src/dep/iniparser/iniparser.h
-rw-r--r-- stigge/stigge 295 2015-06-29 20:41 ptpd-2.3.1/src/dep/iniparser/README
-rw-r--r-- stigge/stigge 246 2015-06-29 20:41 ptpd-2.3.1/src/dep/iniparser/AUTHORS
-rw-r--r-- stigge/stigge 13128 2015-06-29 20:41 ptpd-2.3.1/src/dep/iniparser/dictionary.c
-rw-r--r-- stigge/stigge 1083 2015-06-29 20:41 ptpd-2.3.1/src/dep/iniparser/LICENSE
-rw-r--r-- stigge/stigge 143705 2015-06-29 20:41 ptpd-2.3.1/src/dep/daemonconfig.c
-rw-r--r-- stigge/stigge 36197 2015-06-29 20:41 ptpd-2.3.1/src/dep/servo.c
-rw-r--r-- stigge/stigge 10525 2015-06-29 20:41 ptpd-2.3.1/src/dep/ipv4_acl.c
-rw-r--r-- stigge/stigge 4744 2015-06-29 20:41 ptpd-2.3.1/src/dep/datatypes_dep.h
-rw-r--r-- stigge/stigge 82188 2015-06-29 20:41 ptpd-2.3.1/src/dep/msg.c
-rw-r--r-- stigge/stigge 5398 2015-06-29 20:41 ptpd-2.3.1/src/dep/constants_dep.h
-rw-r--r-- stigge/stigge 18302 2015-06-29 20:41 ptpd-2.3.1/src/dep/ptpd_dep.h
-rw-r--r-- stigge/stigge 3019 2015-06-29 20:41 ptpd-2.3.1/src/dep/eventtimer.c
drwxr-xr-x stigge/stigge 0 2015-06-29 20:44 ptpd-2.3.1/src/dep/ntpengine/
-rw-r--r-- stigge/stigge 3293 2015-06-29 20:41 ptpd-2.3.1/src/dep/ntpengine/ntp_isc_md5.h
-rw-r--r-- stigge/stigge 12196 2015-06-29 20:41 ptpd-2.3.1/src/dep/ntpengine/ntpdcontrol.h
-rw-r--r-- stigge/stigge 20434 2015-06-29 20:41 ptpd-2.3.1/src/dep/ntpengine/ntpdcontrol.c
-rw-r--r-- stigge/stigge 8685 2015-06-29 20:41 ptpd-2.3.1/src/dep/ntpengine/ntp_isc_md5.c
-rw-r--r-- stigge/stigge 3699 2015-06-29 20:41 ptpd-2.3.1/src/dep/outlierfilter.h
-rw-r--r-- stigge/stigge 5610 2015-06-29 20:41 ptpd-2.3.1/src/dep/eventtimer_posix.c
-rw-r--r-- stigge/stigge 5088 2015-06-29 20:41 ptpd-2.3.1/src/dep/statistics.h
-rw-r--r-- stigge/stigge 2311 2015-06-29 20:41 ptpd-2.3.1/src/dep/eventtimer.h
-rw-r--r-- stigge/stigge 11586 2015-06-29 20:41 ptpd-2.3.1/src/dep/outlierfilter.c
-rw-r--r-- stigge/stigge 28709 2015-06-29 20:41 ptpd-2.3.1/src/dep/snmp.c
-rw-r--r-- stigge/stigge 68096 2015-06-29 20:41 ptpd-2.3.1/src/dep/sys.c
-rw-r--r-- stigge/stigge 1240 2015-06-29 20:41 ptpd-2.3.1/src/dep/ipv4_acl.h
-rw-r--r-- stigge/stigge 3799 2015-06-29 20:41 ptpd-2.3.1/src/ptp_timers.c
-rw-r--r-- stigge/stigge 26358 2015-06-29 20:41 ptpd-2.3.1/src/timingdomain.c
-rw-r--r-- stigge/stigge 32498 2015-06-29 20:41 ptpd-2.3.1/src/display.c
-rw-r--r-- stigge/stigge 42953 2015-06-29 20:41 ptpd-2.3.1/src/management.c
-rw-r--r-- stigge/stigge 15642 2015-06-29 20:43 ptpd-2.3.1/src/ptpd2.8
-rw-r--r-- stigge/stigge 35579 2015-06-29 20:41 ptpd-2.3.1/src/datatypes.h
-rw-r--r-- stigge/stigge 1941 2015-06-29 20:41 ptpd-2.3.1/src/Makefile.am
-rw-r--r-- stigge/stigge 15657 2015-06-29 20:41 ptpd-2.3.1/src/ptpd2.8.in
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/tools/
-rw-r--r-- stigge/stigge 336 2015-06-29 20:41 ptpd-2.3.1/tools/cleanup.sed
-rw-r--r-- stigge/stigge 303 2015-06-29 20:41 ptpd-2.3.1/tools/cleanup_sf2.sed
-rwxr-xr-x stigge/stigge 478 2015-06-29 20:41 ptpd-2.3.1/tools/filter_response.m
-rwxr-xr-x stigge/stigge 2049 2015-06-29 20:41 ptpd-2.3.1/tools/stats.R
-rwxr-xr-x stigge/stigge 2333 2015-06-29 20:41 ptpd-2.3.1/tools/compare.R
-rwxr-xr-x stigge/stigge 1971 2015-06-29 20:41 ptpd-2.3.1/tools/offset.R
-rwxr-xr-x stigge/stigge 1987 2015-06-29 20:41 ptpd-2.3.1/tools/offset_stats.m
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/man/
-rw-r--r-- stigge/stigge 1638 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/man/ptpLogRead.Rd
-rw-r--r-- stigge/stigge 2535 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/man/ptpStats.Rd
-rw-r--r-- stigge/stigge 1289 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/man/ptpQualityCompare.Rd
-rw-r--r-- stigge/stigge 2966 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/man/ptpGraph.Rd
-rw-r--r-- stigge/stigge 1260 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/man/ptpQualityRead.Rd
-rw-r--r-- stigge/stigge 3766 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/man/ptpCompare.Rd
-rw-r--r-- stigge/stigge 511 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/man/ptplib-package.Rd
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/R/
-rw-r--r-- stigge/stigge 4955 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/R/ntplib.R
-rw-r--r-- stigge/stigge 15052 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/R/ptplib.R
-rw-r--r-- stigge/stigge 476 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/DESCRIPTION
-rw-r--r-- stigge/stigge 31 2015-06-29 20:41 ptpd-2.3.1/tools/ptplib/NAMESPACE
-rwxr-xr-x stigge/stigge 2058 2015-06-29 20:41 ptpd-2.3.1/tools/graph.R
-rw-r--r-- stigge/stigge 16629 2015-06-29 20:41 ptpd-2.3.1/configure.ac
-rw-r--r-- stigge/stigge 9943 2015-06-29 20:44 ptpd-2.3.1/config.h.in
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/test/
-rw-r--r-- stigge/stigge 15565 2015-06-29 20:41 ptpd-2.3.1/test/client-e2e-pcap.conf
-rw-r--r-- stigge/stigge 15580 2015-06-29 20:41 ptpd-2.3.1/test/client-e2e-8023.conf
-rw-r--r-- stigge/stigge 610 2015-06-29 20:41 ptpd-2.3.1/test/testing.org
-rw-r--r-- stigge/stigge 15558 2015-06-29 20:41 ptpd-2.3.1/test/client-e2e-socket.conf
drwxr-xr-x stigge/stigge 0 2016-01-22 21:07 ptpd-2.3.1/doc/
-rw-r--r-- stigge/stigge 6505 2015-06-29 20:41 ptpd-2.3.1/doc/ptpd-2.3.0-migration-guide.html
-rw-r--r-- stigge/stigge 4151 2015-06-29 20:41 ptpd-2.3.1/doc/index.html
-rw-r--r-- stigge/stigge 323600 2015-06-29 20:41 ptpd-2.3.1/doc/ptpd_2005_1588_conference_paper.pdf
-rw-r--r-- stigge/stigge 110188 2015-06-29 20:41 ptpd-2.3.1/doc/PTPBASE-MIB.txt
-rw-r--r-- stigge/stigge 272225 2015-06-29 20:41 ptpd-2.3.1/doc/IEEE1588v1_vs_IEEE1588v2.pdf
-rw-r--r-- stigge/stigge 5048 2015-06-29 20:41 ptpd-2.3.1/INSTALL
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/packagebuild/
drwxr-xr-x stigge/stigge 0 2015-06-29 20:41 ptpd-2.3.1/packagebuild/rpm-rh/
-rw-r--r-- stigge/stigge 3233 2015-06-29 20:41 ptpd-2.3.1/packagebuild/rpm-rh/ptpd.init
-rw-r--r-- stigge/stigge 5162 2015-06-29 20:41 ptpd-2.3.1/packagebuild/rpm-rh/ptpd-slaveonly.spec
-rw-r--r-- stigge/stigge 242 2015-06-29 20:41 ptpd-2.3.1/packagebuild/rpm-rh/ptpd.sysconfig
-rw-r--r-- stigge/stigge 5052 2015-06-29 20:41 ptpd-2.3.1/packagebuild/rpm-rh/ptpd.spec
-rw-r--r-- stigge/stigge 1818 2015-06-29 20:41 ptpd-2.3.1/packagebuild/rpm-rh/README.RH
-rw-r--r-- stigge/stigge 2050 2015-06-29 20:41 ptpd-2.3.1/packagebuild/rpm-rh/ptpd.conf
-rwxr-xr-x stigge/stigge 1319 2015-06-29 20:41 ptpd-2.3.1/packagebuild/rpm-rh/rpmbuild.sh
-rw-r--r-- stigge/stigge 838 2015-06-29 20:41 ptpd-2.3.1/Makefile.am
+ tar_exit=0
+ cd ptpd-2.3.1
+ /bin/chmod -R a+rX,g-w,o-w .
==> clean %{buildroot}: /home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000
+ SB_CXC=no
+ echo ==> clean %{buildroot}: /home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000
+ /bin/rm -rf /home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000
+ /bin/mkdir -p /home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-2.3.1-sparc-rtems5-1-1000
+ echo ==> %build:
==> %build:
+ pwd
+ test x86_64-linux-gnu != sparc-rtems5
+ test -z -o sparc-rtems5 ==
/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/do-build: 102: test: sparc-rtems5: unexpected operator
+ build_dir=build-cxc
+ mkdir -p build-cxc
+ cd build-cxc
+ echo sparc-rtems5-gcc
+ sed -e s,-std=gnu99 ,,
+ CC=sparc-rtems5-gcc
+ echo sparc-rtems5-g++
+ CXX=sparc-rtems5-g++
+ CPPFLAGS=-I/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/include
+ CFLAGS=-qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ CXXFLAGS=-qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ LDFLAGS=-L/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib -mcpu=cypress -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/lib
+ LDLIBS=-lrtemsdefaultconfig
+ LIBS=-lrtemsdefaultconfig
+ CPPFLAGS_FOR_HOST=-I/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/include
+ CFLAGS_FOR_HOST=-qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ CXXFLAGS_FOR_HOST=-qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ LDFLAGS_FOR_HOST=-L/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib -mcpu=cypress -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/lib
+ LDLIBS_FOR_HOST=-lrtemsdefaultconfig
+ LIBS_FOR_HOST=-lrtemsdefaultconfig
+ echo gcc -qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ CC_FOR_HOST=gcc -qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ echo g++ -qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ CXX_FOR_HOST=g++ -qrtems -B/home/mritunjay/development/rtems/5/sparc-rtems5/lib/ -B/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/ --specs bsp_specs -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections
+ CFLAGS_FOR_BUILD=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ CXXFLAGS_FOR_BUILD=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ LDFLAGS_FOR_BUILD= -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/lib
+ LDLIBS_FOR_BUILD=
+ LIBS_FOR_BUILD=
+ echo gcc -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ CC_FOR_BUILD=gcc -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ echo g++ -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ CXX_FOR_BUILD=g++ -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
+ export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
+ export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
+ LIBS=-lbsd -lm -lz -lrtemsdefaultconfig ../ptpd-2.3.1/configure --host=sparc-rtems5 --prefix=/home/mritunjay/development/rtems/5 --bindir=/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/bin --exec_prefix=/home/mritunjay/development/rtems/5/sparc-rtems5/erc32 --includedir=/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib/include --libdir=/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/lib --libexecdir=/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/libexec --mandir=/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/share/man --infodir=/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/share/info --datadir=/home/mritunjay/development/rtems/5/sparc-rtems5/erc32/share --disable-embedded-perl --disable-shared --without-openssl --disable-statistics --enable-slave-only --disable-posix-timers --with-max-unicast-destinations=[16...2048] --enable-experimental-options
configure: WARNING: unrecognized options: --disable-embedded-perl, --without-openssl
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for sparc-rtems5-strip... sparc-rtems5-strip
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking for gawk... (cached) mawk
checking for sparc-rtems5-gcc... sparc-rtems5-gcc
checking whether the C compiler works... no
configure: error: in `/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/build-cxc':
configure: error: C compiler cannot create executables
See `config.log' for more details
shell cmd failed: /bin/sh -ex /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/do-build
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200519/89753b02/attachment-0001.bin>
