[rtems/rsb]: Adding PTP support to RSB [GSoC 2020]
Mritunjay Sharma mritunjaysharma394 at gmail.com
Tue May 19 19:22:32 UTC 2020
On Tue, May 19, 2020 at 10:09 PM Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
> On Tue, May 19, 2020 at 7:42 PM Mritunjay Sharma
> <mritunjaysharma394 at gmail.com> wrote:
> > Hello everyone,
> > Starting this thread to discuss and give a detail of my progress in
> relation to
> > my GSoC 2020 project "BSP Buildset for EPICS".
> > It is to tell that I have worked on adding ptp2 support as suggested by
> mentors
> > The implementation that I found could work was ptp2 daemon and so worked
> with
> > it.
> > I added these files:
> > rsb/rtems/config/net/ptpd-2.3-1.cfg
> > rsb/rtems/config/net/ptpd.bset
> > rsb/source-builder/config/ptpd-2.1.cfg
> > I am attaching the .diff file and the bug that I have encountered in the
> > respective txt file and will like the help of mentors in trying to help
> me
> > fix it.
> Hi Mritrynjay,
> The error your are facing is here:
> checking whether the C compiler works... no
> configure: error: in
> `/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/build-cxc':
> configure: error: C compiler cannot create executables
> Looks like it's not able to find the CC properly. If I remember
> correctly, you had a similar problem before. Do you remember how you
> fixed that or what was missing?
> Thank you so much for the help, Vijay. However, the thing that was working
last time is not
helping me this time. I am attaching the config.log as well. Hope it will
help with debugging.
> Also, there's another warning in the log:
> configure: WARNING: unrecognized options: --disable-embedded-perl,
> --without-openssl
> You can just remove these options from the cfg file.
Thank you so much, I have removed them now and will update on the GitHub as
well.
- Mritunjay
> Best regards,
> Vijay
> > I will also be uploading the files on my GitHub repo as well which can
> be accessed from here:
> > https://github.com/mritunjaysharma394/rtems-source-builder
> > Thanks,
> > Mritunjay
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200520/d8ef2981/attachment.html>
Type: text/x-log
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200520/d8ef2981/attachment.bin>
