[rtems/rsb]: Adding PTP support to RSB [GSoC 2020]
Vijay Kumar Banerjee vijay at rtems.org
Tue May 19 20:16:31 UTC 2020
On Wed, May 20, 2020 at 1:27 AM Mritunjay Sharma
<mritunjaysharma394 at gmail.com> wrote:
>> Thanks for the log files. From a quick look, there is one obvious
>> error, the linker can't find libbsd most probably because it is not
>> there. So, you need to remove the -lbsd option from ptpd-2-1.cfg file
>> LIBS value. Another thing to be noted is that there are a few errors
>> due to failed version checking of the sparc-rtems5-gcc, this can
>> probably ignored for now if removing the -lbsd option fixes your
>> issue.
> Thank you so much! Removing the lbsd from cfg file resloved the earlier
> compiler issue but now another error is coming up and it is somewhat like this:
>  "Makefile:502: recipe for target 'all-recursive' failed
> make[1]: Leaving directory '/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/build-cxc'
> make[1]: *** [all-recursive] Error 1
> Makefile:412: recipe for target 'all' failed
> make: *** [all] Error 2
> shell cmd failed: /bin/sh -ex  /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/do-build
> error: building ptpd-2.3.1-sparc-rtems5-1"
The error is generally at the end of the log file. In this case, it is:
In file included from ../../ptpd-2.3.1/src/arith.c:53:0:
../../ptpd-2.3.1/src/ptpd.h:93:10: fatal error: netinet/ip.h: No such
file or directory
 #include <netinet/ip.h>
compilation terminated.
This header file isn't there in the include directory. Is netinet a
dependency fo ptpd? If so, you'll have to find the package that
provides netinet, and add that to rsb in a similar manner as in ptpd,
then you'll have to add it in the ptpd.bset .
> Attaching the log file as well.
> - Mritunjay
