[rtems/rsb]: Adding PTP support to RSB [GSoC 2020]
Mritunjay Sharma mritunjaysharma394 at gmail.com
Wed May 20 19:37:18 UTC 2020
On Wed, May 20, 2020 at 1:46 AM Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
> On Wed, May 20, 2020 at 1:27 AM Mritunjay Sharma
> <mritunjaysharma394 at gmail.com> wrote:
> >> Thanks for the log files. From a quick look, there is one obvious
> >> error, the linker can't find libbsd most probably because it is not
> >> there. So, you need to remove the -lbsd option from ptpd-2-1.cfg file
> >> LIBS value. Another thing to be noted is that there are a few errors
> >> due to failed version checking of the sparc-rtems5-gcc, this can
> >> probably ignored for now if removing the -lbsd option fixes your
> >> issue.
> > Thank you so much! Removing the lbsd from cfg file resloved the earlier
> > compiler issue but now another error is coming up and it is somewhat
> like this:
> >  "Makefile:502: recipe for target 'all-recursive' failed
> > make[1]: Leaving directory
> '/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/build-cxc'
> > make[1]: *** [all-recursive] Error 1
> > Makefile:412: recipe for target 'all' failed
> > make: *** [all] Error 2
> > shell cmd failed: /bin/sh -ex
> /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/do-build
> > error: building ptpd-2.3.1-sparc-rtems5-1"
> The error is generally at the end of the log file. In this case, it is:
> In file included from ../../ptpd-2.3.1/src/arith.c:53:0:
> ../../ptpd-2.3.1/src/ptpd.h:93:10: fatal error: netinet/ip.h: No such
> file or directory
>  #include <netinet/ip.h>
> compilation terminated.
> This header file isn't there in the include directory. Is netinet a
> dependency fo ptpd? If so, you'll have to find the package that
> provides netinet, and add that to rsb in a similar manner as in ptpd,
> then you'll have to add it in the ptpd.bset .
I have tried in this course. Have to still execute. Chris is telling there
is a problem with Canadian Cross
Compiling this. Is it allowed here to implement?
> > Attaching the log file as well.
> > - Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200521/f02deeda/attachment.html>
