Adding fenv support for ARM
Tue May 19 23:14:19 UTC 2020
On Tue, May 19, 2020 at 5:20 PM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> On Wed, May 20, 2020 at 3:43 AM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> On Wed, May 20, 2020 at 2:25 AM Joel Sherrill <joel at rtems.org> wrote:
>>> On Tue, May 19, 2020 at 3:52 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>> wrote:
>>>> On Wed, May 20, 2020 at 1:55 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>> wrote:
>>>>> On Wed, May 20, 2020 at 1:42 AM Joel Sherrill <joel at rtems.org> wrote:
>>>>>> There shouldn't need to be an arm/fenv.c file after this is over if I
>>>>>> am thinking right. Each method will be split into its own file. I think
>>>>>> that's how the riscv is done.
>>>>> The files in sys/fenv are the one having inline assembly, But the
>>>>> methods in fenv.c have the files for soft float, and vpf.
>>>> could all the files be retailed under different #ifdef conditions
>>>> similar to that followed in FreeBSD
>>> Hmmm... maybe the methods in sys/fenv.h are redundant. If the bodies in
>>> fenv.c cover all the multilibs, then delete the static inlines.
>> This may be the case
>> but the files in Fenv.h are the once with the assembly code.
>> the files in fenv.c are calling functions from fenv-softfp.c and
>> fenv-vfp.c
>> which inturn call files for fenv.h and fenv-softfloat.h
>> If we remove the inline declaration of the functions from Fenv.h they
>> won't be able to get the definitions
>> and will cause errors.
> Warning the compiler generates:
> arm-rtems5-gcc
> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/
> -isystem
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include
> -isystem /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include
>  -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
> -DPACKAGE_VERSION=\"3.3.0\" -DPACKAGE_STRING=\"newlib\ 3.3.0\"
> -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -I.
> -I../../../../../../newlib-cygwin/newlib/libm/machine/arm -I
> ../../../../../../newlib-cygwin/newlib/libm/machine/arm/../../../../newlib/libm/common
> -fno-builtin -ffunction-sections -fdata-sections  -D_COMPILING_NEWLIB
> -DCLOCK_PROVIDED -DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED
> -DGETREENT_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP
> -DHAVE_BLKSIZE -DHAVE_FCNTL -DHAVE_ASSERT_FUNC -D_NO_GETLOGIN
> -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET -D_NO_WORDEXP
> -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI      -g -O2 -c -o
> lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo
> '../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-vfp.c
> ../../../../../../newlib-cygwin/newlib/libm/machine/arm/fenv-vfp.c:29:24:
> warning: inline function '__vfp_fegetexcept' declared but never defined
>  #define FENV_MANGLE(x) __vfp_ ##x
Hmm... trace the naming patch from the mangled declaration to a method. You
can drop into the build directory and run the gcc command by hand. Tinker
with it to add a -E and save the output (not -o...). That will let you see
the preprocessed output. Something specific and subtle is happening. Decode
that and you win.
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:52:21:
> note: in expansion of macro 'FENV_MANGLE'
>  #define fegetexcept FENV_MANGLE(fegetexcept)
> warning: inline function '__vfp_fedisableexcept' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:51:25:
>  #define fedisableexcept FENV_MANGLE(fedisableexcept)
> warning: inline function '__vfp_feenableexcept' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:50:24:
>  #define feenableexcept FENV_MANGLE(feenableexcept)
> warning: inline function '__vfp_feupdateenv' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:49:21:
>  #define feupdateenv FENV_MANGLE(feupdateenv)
> warning: inline function '__vfp_fesetenv' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:48:18:
>  #define fesetenv FENV_MANGLE(fesetenv)
> warning: inline function '__vfp_feholdexcept' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:47:22:
>  #define feholdexcept FENV_MANGLE(feholdexcept)
> warning: inline function '__vfp_fegetenv' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:46:18:
>  #define fegetenv FENV_MANGLE(fegetenv)
> warning: inline function '__vfp_fesetround' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:45:20:
>  #define fesetround FENV_MANGLE(fesetround)
> warning: inline function '__vfp_fegetround' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:44:20:
>  #define fegetround FENV_MANGLE(fegetround)
> warning: inline function '__vfp_fetestexcept' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:43:22:
>  #define fetestexcept FENV_MANGLE(fetestexcept)
> warning: inline function '__vfp_fesetexceptflag' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:41:25:
>  #define fesetexceptflag FENV_MANGLE(fesetexceptflag)
> warning: inline function '__vfp_feraiseexcept' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:42:23:
>  #define feraiseexcept FENV_MANGLE(feraiseexcept)
> warning: inline function '__vfp_fegetexceptflag' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:40:25:
>  #define fegetexceptflag FENV_MANGLE(fegetexceptflag)
> warning: inline function '__vfp_feclearexcept' declared but never defined
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:39:23:
>  #define feclearexcept FENV_MANGLE(feclearexcept)
> arm-rtems5-gcc
> -isystem
> lib_a-fenv-softfp.o `test -f 'fenv-softfp.c' || echo
> '../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-softfp.c
> rm -f lib.a
> arm-rtems5-ar cru lib.a lib_a-e_sqrt.o lib_a-ef_sqrt.o lib_a-s_ceil.o
> lib_a-s_floor.o lib_a-s_nearbyint.o lib_a-s_rint.o lib_a-s_round.o
> lib_a-s_trunc.o lib_a-sf_ceil.o lib_a-sf_floor.o lib_a-sf_nearbyint.o
> lib_a-sf_rint.o lib_a-sf_round.o lib_a-sf_trunc.o lib_a-feclearexcept.o
> lib_a-fegetenv.o lib_a-fegetexceptflag.o lib_a-fegetround.o
> lib_a-feholdexcept.o lib_a-fenv.o lib_a-feraiseexcept.o lib_a-fesetenv.o
> lib_a-fesetexceptflag.o lib_a-fesetround.o lib_a-fetestexcept.o
> lib_a-feupdateenv.o lib_a-fenv-vfp.o lib_a-fenv-softfp.o
> arm-rtems5-ar: `u' modifier ignored since `D' is the default (see `U')
> arm-rtems5-ranlib lib.a
> make[6]: Leaving directory
> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm/machine/arm'
> Making all in .
> make[6]: Entering directory
> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm/machine'
> rm -f lib.a
> ln arm/lib.a lib.a >/dev/null 2>/dev/null || \
>  cp arm/lib.a lib.a
> make[5]: Leaving directory
> make[5]: Entering directory
> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm'
> rm -f libm.a
> rm -rf tmp
> mkdir tmp
> cd tmp; \
>   for i in math/lib.a common/lib.a complex/lib.a fenv/lib.a machine/lib.a;
> do \
>     arm-rtems5-ar x ../$i; \
> done; \
> arm-rtems5-ar rc ../libm.a *.o
> arm-rtems5-ranlib libm.a
> rm -rf tmp
> make[4]: Leaving directory
> Making all in doc
> make[4]: Entering directory
> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/doc'
> gcc -g -g -O2 -c ../../../../newlib-cygwin/newlib/doc/makedoc.c
> gcc -g -O2  -o makedoc makedoc.o
> Making all in .
> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib'
> rm -f libm.a
> ln libm/libm.a libm.a >/dev/null 2>/dev/null || cp libm/libm.a libm.a
> rm -rf libc.a libg.a tmp
> mkdir tmp
> cd tmp; \
>  arm-rtems5-ar x ../libm.a lib_a-s_fpclassify.o lib_a-sf_fpclassify.o
> lib_a-s_isinf.o lib_a-sf_isinf.o lib_a-s_isnan.o lib_a-sf_isnan.o
> lib_a-s_isinfd.o lib_a-sf_isinff.o lib_a-s_isnand.o lib_a-sf_isnanf.o
> lib_a-s_nan.o lib_a-sf_nan.o lib_a-s_ldexp.o lib_a-sf_ldexp.o
> lib_a-s_frexp.o lib_a-sf_frexp.o lib_a-s_modf.o lib_a-sf_modf.o
> lib_a-s_scalbn.o lib_a-sf_scalbn.o lib_a-s_finite.o lib_a-sf_finite.o
> lib_a-s_copysign.o lib_a-sf_copysign.o ; \
>  arm-rtems5-ar x ../libc/libc.a ; \
>  arm-rtems5-ar rc ../libc.a *.o
> arm-rtems5-ranlib libc.a
> ln libc.a libg.a >/dev/null 2>/dev/null || cp libc.a libg.a
> rm -rf tmp
> rm -f crt0.o
> ln libc/crt0.o crt0.o >/dev/null 2>/dev/null || cp libc/crt0.o crt0.o
> make[3]: Leaving directory
> make[2]: Leaving directory
> make[1]: Leaving directory
> '/home/eshan/development/newlib/c-arm-rtems5-newlib'
>>> --joel
>>>>>> --joel
>>>>>> On Tue, May 19, 2020 at 3:05 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, May 20, 2020 at 12:47 AM Joel Sherrill <joel at rtems.org>
>>>>>>> wrote:
>>>>>>>> Crap! The default mode <sys/fenv.h> is working is turning the
>>>>>>>> methods into static inline which conflicts with the default implementation.
>>>>>>>> That's what is happening.
>>>>>>>> Cut the static inline bodies out of the arm sys/fenv.h and
>>>>>>>> distribute them to libm/arm/XXX.c based on their method name. Drop
>>>>>>>> __fenv_static completely.
>>>>>>> What will happen to the fenv methods in the fenv.c file
>>>>>>>> Make the new split out feXXX.c files FreeBSD copyright. You should
>>>>>>>> add a note that you adapted them from their sys/fenv.h with static inline
>>>>>>>> to have the bodies in separate files. Make the same type of note in the arm
>>>>>>>> sys/fenv.h.
>>>>>>>> Sorry to beat the copyright/credit thing but it is important to
>>>>>>>> note that the meat of the code came from FreeBSD and you split it into
>>>>>>>> files.
>>>>>>>> --joel
>>>>>>>> On Tue, May 19, 2020 at 1:48 PM Eshan Dhawan <
>>>>>>>> eshandhawan51 at gmail.com> wrote:
>>>>>>>>> Hello
>>>>>>>>> I have encountered a new error
>>>>>>>>> the error is coming from libm/fenv
>>>>>>>>> link to GitHub repository:
>>>>>>>>> https://github.com/eshandhawan51/newlib-cygwin/tree/add_fenv_support
>>>>>>>>> Make file log:
>>>>>>>>> eshan at EDs-pc:~/development/newlib/c-arm-rtems5-newlib$ make -k
>>>>>>>>> make[1]: Entering directory
>>>>>>>>> make[2]: Entering directory
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/etc'
>>>>>>>>> make[2]: Nothing to be done for 'all'.
>>>>>>>>> Checking multilib configuration for newlib...
>>>>>>>>> make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2"
>>>>>>>>> "CCASFLAGS=-g -O2" "CFLAGS_FOR_BUILD=-g -O2" "CFLAGS_FOR_TARGET=-g -O2"
>>>>>>>>> "INSTALL=/usr/bin/install -c" "LDFLAGS=" "LIBCFLAGS=-g -O2"
>>>>>>>>> "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make" "MAKEINFO=makeinfo
>>>>>>>>> --split-size=5000000 --split-size=5000000 " "PICFLAG="
>>>>>>>>> "PICFLAG_FOR_TARGET=" "SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest"
>>>>>>>>> "RUNTESTFLAGS=" "exec_prefix=/usr/local" "infodir=/usr/local/share/info"
>>>>>>>>> "libdir=/usr/local/lib" "prefix=/usr/local" "tooldir=/usr/local/arm-rtems5"
>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib" "AR=arm-rtems5-ar"
>>>>>>>>> "AS=arm-rtems5-as" "CC=arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> " "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2" "NM=arm-rtems5-nm" "PICFLAG="
>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" all-recursive
>>>>>>>>> make[3]: Entering directory
>>>>>>>>> -isystem
>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" DO=all multi-do # make
>>>>>>>>> if [ -z "thumb vfp/hard thumb/armv6-m thumb/armv7-a thumb/armv7-r
>>>>>>>>> thumb/cortex-m3 thumb/cortex-m4 thumb/armv7-a/neon/hard
>>>>>>>>> thumb/armv7-r/vfpv3-d16/hard thumb/cortex-m4/fpv4-sp-d16/hard
>>>>>>>>> thumb/cortex-m7/fpv5-d16/hard eb/thumb/armv7-r
>>>>>>>>> eb/thumb/armv7-r/vfpv3-d16/hard" ]; then \
>>>>>>>>>   true; \
>>>>>>>>> else \
>>>>>>>>>   rootpre=`${PWDCMD-pwd}`/; export rootpre; \
>>>>>>>>>   srcrootpre=`cd ../../../newlib-cygwin/newlib; ${PWDCMD-pwd}`/;
>>>>>>>>> export srcrootpre; \
>>>>>>>>>   lib=`echo "${rootpre}" | sed -e 's,^.*/\([^/][^/]*\)/$,\1,'`; \
>>>>>>>>>   compiler="arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>>   for i in `${compiler} --print-multi-lib 2>/dev/null`; do \
>>>>>>>>>     dir=`echo $i | sed -e 's/;.*$//'`; \
>>>>>>>>>     if [ "${dir}" = "." ]; then \
>>>>>>>>>       true; \
>>>>>>>>>     else \
>>>>>>>>>       if [ -d ../${dir}/${lib} ]; then \
>>>>>>>>> flags=`echo $i | sed -e 's/^[^;]*;//' -e 's/@/ -/g'`; \
>>>>>>>>> if (cd ../${dir}/${lib}; make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc"
>>>>>>>>> "CFLAGS=-g -O2" "CCASFLAGS=-g -O2" "CFLAGS_FOR_BUILD=-g -O2"
>>>>>>>>> "CFLAGS_FOR_TARGET=-g -O2" "INSTALL=/usr/bin/install -c" "LDFLAGS="
>>>>>>>>> "LIBCFLAGS=-g -O2" "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make"
>>>>>>>>> "MAKEINFO=makeinfo --split-size=5000000 --split-size=5000000   " "PICFLAG="
>>>>>>>>> -isystem
>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" \
>>>>>>>>> CFLAGS="-g -O2 ${flags}" \
>>>>>>>>> CCASFLAGS="-g -O2 ${flags}" \
>>>>>>>>> FCFLAGS=" ${flags}" \
>>>>>>>>> FFLAGS=" ${flags}" \
>>>>>>>>> ADAFLAGS=" ${flags}" \
>>>>>>>>> prefix="/usr/local" \
>>>>>>>>> exec_prefix="/usr/local" \
>>>>>>>>> GCJFLAGS=" ${flags}" \
>>>>>>>>> GOCFLAGS="-O2 -g ${flags}" \
>>>>>>>>> CXXFLAGS="-g -O2 ${flags}" \
>>>>>>>>> LIBCFLAGS="-g -O2 ${flags}" \
>>>>>>>>> LIBCXXFLAGS="-g -O2 -fno-implicit-templates ${flags}" \
>>>>>>>>> LDFLAGS=" ${flags}" \
>>>>>>>>> MULTIFLAGS="${flags}" \
>>>>>>>>> DESTDIR="" \
>>>>>>>>> INSTALL="/usr/bin/install -c" \
>>>>>>>>> INSTALL_DATA="/usr/bin/install -c -m 644" \
>>>>>>>>> INSTALL_PROGRAM="/usr/bin/install -c" \
>>>>>>>>> INSTALL_SCRIPT="/usr/bin/install -c" \
>>>>>>>>> all); then \
>>>>>>>>>  true; \
>>>>>>>>> else \
>>>>>>>>>  exit 1; \
>>>>>>>>> fi; \
>>>>>>>>>       else true; \
>>>>>>>>>       fi; \
>>>>>>>>>     fi; \
>>>>>>>>>   done; \
>>>>>>>>> fi
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib'
>>>>>>>>> make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mthumb"
>>>>>>>>> "CCASFLAGS=-g -O2  -mthumb" "CFLAGS_FOR_BUILD=-g -O2" "CFLAGS_FOR_TARGET=-g
>>>>>>>>> -O2" "INSTALL=/usr/bin/install -c" "LDFLAGS=-mthumb" "LIBCFLAGS=-g -O2
>>>>>>>>>  -mthumb" "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make" "MAKEINFO=makeinfo
>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib/thumb" "AR=arm-rtems5-ar"
>>>>>>>>> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/
>>>>>>>>> -isystem
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include
>>>>>>>>>  -mthumb" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2  -mthumb" "NM=arm-rtems5-nm"
>>>>>>>>> "PICFLAG=" "RANLIB=arm-rtems5-ranlib" "DESTDIR=" all-recursive
>>>>>>>>> true "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mthumb"
>>>>>>>>> -isystem
>>>>>>>>> "PICFLAG=" "RANLIB=arm-rtems5-ranlib" "DESTDIR=" DO=all multi-do # make
>>>>>>>>> Making all in libc
>>>>>>>>> make[7]: Entering directory
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc'
>>>>>>>>> Making all in argz
>>>>>>>>> make[8]: Entering directory
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/argz'
>>>>>>>>> make[8]: Nothing to be done for 'all'.
>>>>>>>>> make[8]: Leaving directory
>>>>>>>>> Making all in stdlib
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/stdlib'
>>>>>>>>> Making all in ctype
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/ctype'
>>>>>>>>> Making all in search
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/search'
>>>>>>>>> Making all in stdio
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/stdio'
>>>>>>>>> Making all in string
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/string'
>>>>>>>>> Making all in signal
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/signal'
>>>>>>>>> Making all in time
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/time'
>>>>>>>>> Making all in locale
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/locale'
>>>>>>>>> Making all in sys
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/sys'
>>>>>>>>> Making all in rtems
>>>>>>>>> make[9]: Entering directory
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/sys/rtems'
>>>>>>>>> make[9]: Nothing to be done for 'all'.
>>>>>>>>> make[9]: Leaving directory
>>>>>>>>> Making all in .
>>>>>>>>> make[9]: Nothing to be done for 'all-am'.
>>>>>>>>> Making all in reent
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/reent'
>>>>>>>>> Making all in errno
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/errno'
>>>>>>>>> Making all in misc
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/misc'
>>>>>>>>> Making all in machine
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/machine'
>>>>>>>>> Making all in arm
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/machine/arm'
>>>>>>>>> Making all in .
>>>>>>>>> Making all in unix
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/unix'
>>>>>>>>> Making all in posix
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/posix'
>>>>>>>>> Making all in ssp
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/ssp'
>>>>>>>>> Making all in .
>>>>>>>>> make[8]: Nothing to be done for 'all-am'.
>>>>>>>>> make[7]: Leaving directory
>>>>>>>>> Making all in libm
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm'
>>>>>>>>> Making all in math
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/math'
>>>>>>>>> Making all in common
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/common'
>>>>>>>>> Making all in complex
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/complex'
>>>>>>>>> Making all in fenv
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/fenv'
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine'
>>>>>>>>> Making all in arm
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine/arm'
>>>>>>>>> Making all in .
>>>>>>>>> Making all in .
>>>>>>>>> rm -f thumb/crt0.o
>>>>>>>>> ln libc/crt0.o thumb/crt0.o >/dev/null 2>/dev/null || cp
>>>>>>>>> rm -f thumb/libc.a ./thumb/libg.a
>>>>>>>>> ln libc.a thumb/libc.a >/dev/null 2>/dev/null || cp libc.a
>>>>>>>>> thumb/libc.a
>>>>>>>>> ln libg.a ./thumb/libg.a >/dev/null 2>/dev/null || \
>>>>>>>>> cp libg.a ./thumb/libg.a
>>>>>>>>> rm -f thumb/libm.a
>>>>>>>>> ln libm.a thumb/libm.a >/dev/null 2>/dev/null || cp libm.a
>>>>>>>>> thumb/libm.a
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib'
>>>>>>>>> make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mfpu=vfp
>>>>>>>>> -mfloat-abi=hard" "CCASFLAGS=-g -O2  -mfpu=vfp -mfloat-abi=hard"
>>>>>>>>> "INSTALL=/usr/bin/install -c" "LDFLAGS=-mfpu=vfp -mfloat-abi=hard"
>>>>>>>>> "LIBCFLAGS=-g -O2  -mfpu=vfp -mfloat-abi=hard" "LIBCFLAGS_FOR_TARGET=-g
>>>>>>>>> -O2" "MAKE=make" "MAKEINFO=makeinfo --split-size=5000000
>>>>>>>>> --split-size=5000000    " "PICFLAG=" "PICFLAG_FOR_TARGET="
>>>>>>>>> "SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest" "RUNTESTFLAGS="
>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib/vfp/hard" "AR=arm-rtems5-ar"
>>>>>>>>> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/
>>>>>>>>> -isystem
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include
>>>>>>>>>  -mfpu=vfp -mfloat-abi=hard" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2
>>>>>>>>>  -mfpu=vfp -mfloat-abi=hard" "NM=arm-rtems5-nm" "PICFLAG="
>>>>>>>>> true "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mfpu=vfp
>>>>>>>>> -isystem
>>>>>>>>> Making all in libc
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc'
>>>>>>>>> Making all in argz
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/argz'
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/stdlib'
>>>>>>>>> Making all in ctype
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/ctype'
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/search'
>>>>>>>>> Making all in stdio
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/stdio'
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/string'
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/signal'
>>>>>>>>> Making all in time
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/time'
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/locale'
>>>>>>>>> Making all in sys
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/sys'
>>>>>>>>> Making all in rtems
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/sys/rtems'
>>>>>>>>> Making all in .
>>>>>>>>> Making all in reent
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/reent'
>>>>>>>>> Making all in errno
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/errno'
>>>>>>>>> Making all in misc
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/misc'
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/machine'
>>>>>>>>> Making all in arm
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/machine/arm'
>>>>>>>>> Making all in .
>>>>>>>>> Making all in unix
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/unix'
>>>>>>>>> Making all in posix
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/posix'
>>>>>>>>> Making all in ssp
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/ssp'
>>>>>>>>> Making all in .
>>>>>>>>> Making all in libm
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm'
>>>>>>>>> Making all in math
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/math'
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/common'
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/complex'
>>>>>>>>> Making all in fenv
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/fenv'
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>>  -mfpu=vfp -mfloat-abi=hard -DPACKAGE_NAME=\"newlib\"
>>>>>>>>> -DPACKAGE_TARNAME=\"newlib\" -DPACKAGE_VERSION=\"3.3.0\"
>>>>>>>>> -DPACKAGE_STRING=\"newlib\ 3.3.0\" -DPACKAGE_BUGREPORT=\"\"
>>>>>>>>> -I../../../../../../../newlib-cygwin/newlib/libm/fenv -fno-builtin
>>>>>>>>> -ffunction-sections -fdata-sections  -D_COMPILING_NEWLIB -DCLOCK_PROVIDED
>>>>>>>>> -DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED -DGETREENT_PROVIDED
>>>>>>>>> -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL
>>>>>>>>> -DHAVE_ASSERT_FUNC -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS
>>>>>>>>> -D_NO_SIGSET -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI
>>>>>>>>>   -fbuiltin -fno-math-errno  -g -O2  -mfpu=vfp -mfloat-abi=hard -c -o
>>>>>>>>> lib_a-feclearexcept.o `test -f 'feclearexcept.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feclearexcept.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:64:5:
>>>>>>>>> error: redefinition of 'feclearexcept'
>>>>>>>>>  int feclearexcept(int excepts)
>>>>>>>>> In file included from
>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:15:0,
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:126:1:
>>>>>>>>> note: previous definition of 'feclearexcept' was here
>>>>>>>>> Makefile:347: recipe for target 'lib_a-feclearexcept.o' failed
>>>>>>>>> make[8]: *** [lib_a-feclearexcept.o] Error 1
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> lib_a-fegetenv.o `test -f 'fegetenv.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetenv.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetenv.c:64:5:
>>>>>>>>> error: redefinition of 'fegetenv'
>>>>>>>>>  int fegetenv(fenv_t *envp)
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetenv.c:29:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:198:1:
>>>>>>>>> note: previous definition of 'fegetenv' was here
>>>>>>>>> Makefile:359: recipe for target 'lib_a-fegetenv.o' failed
>>>>>>>>> make[8]: *** [lib_a-fegetenv.o] Error 1
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> lib_a-fegetexceptflag.o `test -f 'fegetexceptflag.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetexceptflag.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetexceptflag.c:65:5:
>>>>>>>>> error: redefinition of 'fegetexceptflag'
>>>>>>>>>  int fegetexceptflag(fexcept_t *flagp, int excepts)
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetexceptflag.c:29:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:137:1:
>>>>>>>>> note: previous definition of 'fegetexceptflag' was here
>>>>>>>>> Makefile:365: recipe for target 'lib_a-fegetexceptflag.o' failed
>>>>>>>>> make[8]: *** [lib_a-fegetexceptflag.o] Error 1
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> lib_a-fegetround.o `test -f 'fegetround.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetround.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetround.c:63:5:
>>>>>>>>> error: redefinition of 'fegetround'
>>>>>>>>>  int fegetround(void)
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetround.c:29:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:177:1:
>>>>>>>>> note: previous definition of 'fegetround' was here
>>>>>>>>>  fegetround(void)
>>>>>>>>> Makefile:371: recipe for target 'lib_a-fegetround.o' failed
>>>>>>>>> make[8]: *** [lib_a-fegetround.o] Error 1
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> lib_a-feholdexcept.o `test -f 'feholdexcept.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feholdexcept.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feholdexcept.c:67:5:
>>>>>>>>> error: redefinition of 'feholdexcept'
>>>>>>>>>  int feholdexcept(fenv_t *envp)
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feholdexcept.c:29:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:206:1:
>>>>>>>>> note: previous definition of 'feholdexcept' was here
>>>>>>>>> Makefile:377: recipe for target 'lib_a-feholdexcept.o' failed
>>>>>>>>> make[8]: *** [lib_a-feholdexcept.o] Error 1
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> lib_a-feraiseexcept.o `test -f 'feraiseexcept.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feraiseexcept.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feraiseexcept.c:64:5:
>>>>>>>>> error: redefinition of 'feraiseexcept'
>>>>>>>>>  int feraiseexcept(int excepts)
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feraiseexcept.c:29:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:159:1:
>>>>>>>>> note: previous definition of 'feraiseexcept' was here
>>>>>>>>> Makefile:383: recipe for target 'lib_a-feraiseexcept.o' failed
>>>>>>>>> make[8]: *** [lib_a-feraiseexcept.o] Error 1
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> lib_a-fesetenv.o `test -f 'fesetenv.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetenv.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetenv.c:69:5:
>>>>>>>>> error: redefinition of 'fesetenv'
>>>>>>>>>  int fesetenv(const fenv_t *envp)
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetenv.c:29:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:218:1:
>>>>>>>>> note: previous definition of 'fesetenv' was here
>>>>>>>>> Makefile:389: recipe for target 'lib_a-fesetenv.o' failed
>>>>>>>>> make[8]: *** [lib_a-fesetenv.o] Error 1
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> lib_a-fesetexceptflag.o `test -f 'fesetexceptflag.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetexceptflag.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetexceptflag.c:70:5:
>>>>>>>>> error: redefinition of 'fesetexceptflag'
>>>>>>>>>  int fesetexceptflag(const fexcept_t *flagp, int excepts)
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetexceptflag.c:29:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:147:1:
>>>>>>>>> note: previous definition of 'fesetexceptflag' was here
>>>>>>>>> Makefile:395: recipe for target 'lib_a-fesetexceptflag.o' failed
>>>>>>>>> make[8]: *** [lib_a-fesetexceptflag.o] Error 1
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> lib_a-fesetround.o `test -f 'fesetround.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetround.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetround.c:64:5:
>>>>>>>>> error: redefinition of 'fesetround'
>>>>>>>>>  int fesetround(int round)
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetround.c:29:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:186:1:
>>>>>>>>> note: previous definition of 'fesetround' was here
>>>>>>>>> Makefile:401: recipe for target 'lib_a-fesetround.o' failed
>>>>>>>>> make[8]: *** [lib_a-fesetround.o] Error 1
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> lib_a-fetestexcept.o `test -f 'fetestexcept.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fetestexcept.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fetestexcept.c:65:5:
>>>>>>>>> error: redefinition of 'fetestexcept'
>>>>>>>>>  int fetestexcept(int excepts)
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fetestexcept.c:30:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:168:1:
>>>>>>>>> note: previous definition of 'fetestexcept' was here
>>>>>>>>> Makefile:407: recipe for target 'lib_a-fetestexcept.o' failed
>>>>>>>>> make[8]: *** [lib_a-fetestexcept.o] Error 1
>>>>>>>>> arm-rtems5-gcc
>>>>>>>>> -isystem
>>>>>>>>> lib_a-feupdateenv.o `test -f 'feupdateenv.c' || echo
>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feupdateenv.c
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feupdateenv.c:69:5:
>>>>>>>>> error: redefinition of 'feupdateenv'
>>>>>>>>>  int feupdateenv(const fenv_t *envp)
>>>>>>>>>                  from
>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feupdateenv.c:29:
>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:226:1:
>>>>>>>>> note: previous definition of 'feupdateenv' was here
>>>>>>>>> Makefile:413: recipe for target 'lib_a-feupdateenv.o' failed
>>>>>>>>> make[8]: *** [lib_a-feupdateenv.o] Error 1
>>>>>>>>> make[8]: Target 'all' not remade because of errors.
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/machine'
>>>>>>>>> Making all in arm
>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/machine/arm'
>>>>>>>>> Making all in .
>>>>>>>>> rm -f libm.a
>>>>>>>>> rm -rf tmp
>>>>>>>>> mkdir tmp
>>>>>>>>> cd tmp; \
>>>>>>>>> machine/lib.a; do \
>>>>>>>>> done; \
>>>>>>>>> arm-rtems5-ar: ../fenv/lib.a: No such file or directory
>>>>>>>>> rm -rf tmp
>>>>>>>>> Makefile:553: recipe for target 'all-recursive' failed
>>>>>>>>> make[7]: *** [all-recursive] Error 1
>>>>>>>>> make[7]: Target 'all' not remade because of errors.
>>>>>>>>> Making all in .
>>>>>>>>> rm -f libm.a
>>>>>>>>> libm.a
>>>>>>>>> mkdir tmp
>>>>>>>>> cd tmp; \
>>>>>>>>> lib_a-sf_fpclassify.o lib_a-s_isinf.o lib_a-sf_isinf.o lib_a-s_isnan.o
>>>>>>>>> lib_a-sf_isnan.o lib_a-s_isinfd.o lib_a-sf_isinff.o lib_a-s_isnand.o
>>>>>>>>> lib_a-sf_isnanf.o lib_a-s_nan.o lib_a-sf_nan.o lib_a-s_ldexp.o
>>>>>>>>> lib_a-sf_ldexp.o lib_a-s_frexp.o lib_a-sf_frexp.o lib_a-s_modf.o
>>>>>>>>> lib_a-sf_modf.o lib_a-s_scalbn.o lib_a-sf_scalbn.o lib_a-s_finite.o
>>>>>>>>> lib_a-sf_finite.o lib_a-s_copysign.o lib_a-sf_copysign.o ; \
>>>>>>>>> rm -rf tmp
>>>>>>>>> rm -f vfp/hard/crt0.o
>>>>>>>>> ln libc/crt0.o vfp/hard/crt0.o >/dev/null 2>/dev/null || cp
>>>>>>>>> rm -f vfp/hard/libc.a ./vfp/hard/libg.a
>>>>>>>>> ln libc.a vfp/hard/libc.a >/dev/null 2>/dev/null || cp libc.a
>>>>>>>>> vfp/hard/libc.a
>>>>>>>>> ln libg.a ./vfp/hard/libg.a >/dev/null 2>/dev/null || \
>>>>>>>>> cp libg.a ./vfp/hard/libg.a
>>>>>>>>> rm -f vfp/hard/libm.a
>>>>>>>>> ln libm.a vfp/hard/libm.a >/dev/null 2>/dev/null || cp libm.a
>>>>>>>>> vfp/hard/libm.a
>>>>>>>>> Makefile:641: recipe for target 'all-recursive' failed
>>>>>>>>> make[6]: *** [all-recursive] Error 1
>>>>>>>>> Makefile:452: recipe for target 'all' failed
>>>>>>>>> make[5]: *** [all] Error 2
>>>>>>>>> Makefile:1260: recipe for target 'multi-do' failed
>>>>>>>>> make[4]: *** [multi-do] Error 1
>>>>>>>>> Makefile:1176: recipe for target 'all-multi' failed
>>>>>>>>> make[3]: *** [all-multi] Error 2
>>>>>>>>> make[3]: Target 'all-recursive' not remade because of errors.
>>>>>>>>> make[2]: *** [all] Error 2
>>>>>>>>> Makefile:8491: recipe for target 'all-target-newlib' failed
>>>>>>>>> make[1]: *** [all-target-newlib] Error 2
>>>>>>>>> make[1]: Target 'all-target' not remade because of errors.
>>>>>>>>> Makefile:878: recipe for target 'all' failed
>>>>>>>>> make: *** [all] Error 2
>>>>>>>>> Thanks
>>>>>>>>> -Eshan :)
>>>>>>>>> On Sat, May 16, 2020 at 8:09 PM Joel Sherrill <joel at rtems.org>
>>>>>>>>> wrote:
>>>>>>>>>> On Fri, May 15, 2020, 5:59 PM Eshan Dhawan <
>>>>>>>>>>> On Fri, May 15, 2020 at 2:22 AM Eshan Dhawan <
>>>>>>>>>>>> On Wed, May 13, 2020 at 7:40 PM Joel Sherrill <joel at rtems.org>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> National free hint day!!!
>>>>>>>>>>>>> Look above the line that is reported. You will see
>>>>>>>>>>>>> __BEGIN_DECL. It isn't defined. It is intended to expand to the __cplusplus
>>>>>>>>>>>>> wrapper.
>>>>>>>>>>>>> After you fix this, you will sequentially find 2 other things
>>>>>>>>>>>>> to change in this file.
>>>>>>>>>>>>> I have made those changes when a new error occurs from the
>>>>>>>>>>>> assembler in arm thumb mode
>>>>>>>>>>>> There is no support for vfp instructions in arm thumb.
>>>>>>>>>>>> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html
>>>>>>>>>>>> So in which file will the compiler instructions given in the
>>>>>>>>>>>> page
>>>>>>>>>>>> <http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html>
>>>>>>>>>>>> added?
>>>>>>>>>>> FreeBSD has added file and architecture-specific flags in their
>>>>>>>>>>> makefile.inc
>>>>>>>>>>> https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/Makefile.inc
>>>>>>>>>>> How will it be added in newlib
>>>>>>>>>>> I tried adding the flags -mfpu=vfp -mfloat-abi=softfp (used in
>>>>>>>>>>> FreeBSD) to makefile.in but no effect.
>>>>>>>>>> This isn't going to work with newlib. They don't specify CPU
>>>>>>>>>> flags that way.
>>>>>>>>>> The fenv code is going to have to compile for every multilib
>>>>>>>>>> variant built by arm-rtems and arm-eabi. You will have to use conditionals
>>>>>>>>>> based on the flags gcc uses to indicate the various cpu features. This
>>>>>>>>>> command should be close to how you you dump them.
>>>>>>>>>> gcc -dM -E - </dev/null
>>>>>>>>>> Add a CPU flag and see how the setting change.
>>>>>>>>>> You can also look in rtems score cpu arm for examples since the
>>>>>>>>>> core arm code will be dealing with these.
>>>>>>>>>> --joel
>>>>>>>>>>> thanks
>>>>>>>>>>> -Eshan
>>>>>>>>>>>> Errors :
>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>> -isystem
>>>>>>>>>>>>  -mthumb -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
>>>>>>>>>>>> -I../../../../../../../newlib-cygwin/newlib/libm/machine/arm -I
>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/machine/arm/../../../../newlib/libm/common
>>>>>>>>>>>> -fno-builtin -mfpu=vfpv2 -ffunction-sections -fdata-sections
>>>>>>>>>>>>  -D_COMPILING_NEWLIB -DCLOCK_PROVIDED -DMALLOC_PROVIDED -DEXIT_PROVIDED
>>>>>>>>>>>> -DSIGNAL_PROVIDED -DGETREENT_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED
>>>>>>>>>>>> -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL -DHAVE_ASSERT_FUNC
>>>>>>>>>>>> -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET
>>>>>>>>>>>> -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI      -g -O2
>>>>>>>>>>>>  -mthumb -c -o lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo
>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-vfp.c
>>>>>>>>>>>> /tmp/ccEHiFws.s: Assembler messages:
>>>>>>>>>>>> /tmp/ccEHiFws.s:37: Error: selected processor does not support
>>>>>>>>>>>> `vmrs r3,fpscr' in Thumb mode
>>>>>>>>>>>> /tmp/ccEHiFws.s:48: Error: selected processor does not support
>>>>>>>>>>>> `vmsr fpscr,r3' in Thumb mode
>>>>>>>>>>>> /tmp/ccEHiFws.s:81: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:119: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:134: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:169: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:182: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:217: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:251: Error: selected processor does not support
>>>>>>>>>>>> `vmrs r0,fpscr' in Thumb mode
>>>>>>>>>>>> /tmp/ccEHiFws.s:288: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:303: Error: selected processor does not support
>>>>>>>>>>>> `vmsr fpscr,r0' in Thumb mode
>>>>>>>>>>>> /tmp/ccEHiFws.s:340: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:374: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:390: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:424: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:457: Error: selected processor does not support
>>>>>>>>>>>> `vmrs r1,fpscr' in Thumb mode
>>>>>>>>>>>> /tmp/ccEHiFws.s:466: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:478: Error: selected processor does not support
>>>>>>>>>>>> `vmrs r2,fpscr' in Thumb mode
>>>>>>>>>>>> /tmp/ccEHiFws.s:503: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:543: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:559: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:595: Error: selected processor does not support
>>>>>>>>>>>> /tmp/ccEHiFws.s:612: Error: selected processor does not support
>>>>>>>>>>>> `vmsr fpscr,r2' in Thumb mode
>>>>>>>>>>>> /tmp/ccEHiFws.s:647: Error: selected processor does not support
>>>>>>>>>>>> Makefile:476: recipe for target 'lib_a-fenv-vfp.o' failed
>>>>>>>>>>>> make[9]: *** [lib_a-fenv-vfp.o] Error 1
>>>>>>>>>>>> Makefile:324: recipe for target 'all-recursive' failed
>>>>>>>>>>>> make[8]: *** [all-recursive] Error 1
>>>>>>>>>>>> -Eshan
>>>>>>>>>>>>> Then we need to make a decision whether the static inline
>>>>>>>>>>>>> versions of the methods in sys/fenv.h are appropriate for newlib or not.
>>>>>>>>>>>>> --joel
>>>>>>>>>>>>> On Tue, May 12, 2020 at 5:20 PM Joel Sherrill <joel at rtems.org>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Gedare is right but one more piece of information is needed.
>>>>>>>>>>>>>> When newlib is being built, it lays target dependent files on top of
>>>>>>>>>>>>>> generic ones. So the default sys/fenv.h is replaced with something like
>>>>>>>>>>>>>> libc/machine/arm/sys/fenv.h. Make sure that
>>>>>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h is
>>>>>>>>>>>>>> in fact the file you think it should be.
>>>>>>>>>>>>>> Also look at what is supposed to be in the generic fenv.h and
>>>>>>>>>>>>>> <sys/fenv.h>. You will probably have to tweak it some.
>>>>>>>>>>>>>> Check out what is in x86_64/fenv.h and riscv/fenv.h with
>>>>>>>>>>>>>> respect to the default environment variable. It looks to be declared
>>>>>>>>>>>>>> differently in the other ports so you may have to make it match.
>>>>>>>>>>>>>> But more output does help.
>>>>>>>>>>>>>> --joel
>>>>>>>>>>>>>> On Tue, May 12, 2020 at 4:53 PM Gedare Bloom <
>>>>>>>>>>>>>> gedare at rtems.org> wrote:
>>>>>>>>>>>>>>> Take the first error reported, and show what is being
>>>>>>>>>>>>>>> compiled. You've
>>>>>>>>>>>>>>> trimmed off too much preceding this to know what is being
>>>>>>>>>>>>>>> compiled and
>>>>>>>>>>>>>>> how this might be influencing your error.
>>>>>>>>>>>>>>> The specific error you're getting is often due to some
>>>>>>>>>>>>>>> syntax errors
>>>>>>>>>>>>>>> preceding the line shown.
>>>>>>>>>>>>>>> On Tue, May 12, 2020 at 2:59 PM Eshan Dhawan <
>>>>>>>>>>>>>>> > Hello everyone,
>>>>>>>>>>>>>>> > After adding the files and compiling. I am
>>>>>>>>>>>>>>> > getting a few errors which I am not able to rectify.
>>>>>>>>>>>>>>> > If you could take a look and tell how to sort them.
>>>>>>>>>>>>>>> > link to newlib's git repo:
>>>>>>>>>>>>>>> > errors :
>>>>>>>>>>>>>>> >                  from
>>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include/sys/fenv.h:82:1:
>>>>>>>>>>>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'extern'
>>>>>>>>>>>>>>> >  extern const fenv_t *_fe_dfl_env;
>>>>>>>>>>>>>>> ../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:0:
>>>>>>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:22:1:
>>>>>>>>>>>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'int'
>>>>>>>>>>>>>>> >  int feclearexcept(int excepts);
>>>>>>>>>>>>>>> > thanks
>>>>>>>>>>>>>>> > -Eshan
>>>>>>>>>>>>>>> > On Sat, May 9, 2020 at 2:53 AM Joel Sherrill <
>>>>>>>>>>>>>>> >> On Thu, May 7, 2020 at 1:33 PM Eshan Dhawan <
>>>>>>>>>>>>>>> >>> Hello everyone,
>>>>>>>>>>>>>>> >>> This the tread to discuss adding fenv support for ARM
>>>>>>>>>>>>>>> architecture in newlib.
>>>>>>>>>>>>>>> >>> Link to previous thread:
>>>>>>>>>>>>>>> https://lists.rtems.org/pipermail/devel/2020-March/058473.html
>>>>>>>>>>>>>>> >>> ---FreeBSD Source
>>>>>>>>>>>>>>> https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
>>>>>>>>>>>>>>> https://github.com/freebsd/freebsd/blob/master/sys/arm/include/ieeefp.h
>>>>>>>>>>>>>>> >>> ---NetBSD Source
>>>>>>>>>>>>>>> https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
>>>>>>>>>>>>>>> >>> --- Musl has no implementation for fenv support for ARM
>>>>>>>>>>>>>>> in it
>>>>>>>>>>>>>>> >>> After going through the implementations both FreeBSD and
>>>>>>>>>>>>>>> NetBSD have a stub implementation.
>>>>>>>>>>>>>>> >>> But then FreeBSD implementation seems to be more
>>>>>>>>>>>>>>> portable compared to that in NetBSD.
>>>>>>>>>>>>>>> >>> Should I start porting it from FreeBSD?
>>>>>>>>>>>>>>> >>> And which ARM BSP should I use for testing the changes?
>>>>>>>>>>>>>>> >>> Currently, I have xilinx_zynq_a9_qemu build
>>>>>>>>>>>>>>> >> I think the FreeBSD implementation is the one to use. It
>>>>>>>>>>>>>>> looks to support hard and soft floating point implementations.
>>>>>>>>>>>>>>> >> I think the fenv.h file there will have to be worked on
>>>>>>>>>>>>>>> so some of the contents go into sys or machine/fenv.h. There is a portable
>>>>>>>>>>>>>>> fenv.h.
>>>>>>>>>>>>>>> >>> There would also be a requirement to discuss where to
>>>>>>>>>>>>>>> place the files in Newlib.
>>>>>>>>>>>>>>> >> Not much to discuss. It should go into
>>>>>>>>>>>>>>> newlib-cygwin/newlib/libm/machine/arm.
>>>>>>>>>>>>>>> >>> Thanks
>>>>>>>>>>>>>>> >>> -Eshan
>>>>>>>>>>>>>>> > _______________________________________________
>>>>>>>>>>>>>>> > devel mailing list
>>>>>>>>>>>>>>> > devel at rtems.org
>>>>>>>>>>>>>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200519/e3f5f767/attachment-0001.html>
