Adding fenv support for ARM
Eshan Dhawan
eshandhawan51 at gmail.com
Wed May 20 19:40:30 UTC 2020
I compiled the fenv-vpf.c and got this output.
output file:
https://github.com/eshandhawan51/rough_notes/blob/master/gcc_fenv-vfp.txt
A strange thing happened today I reset the branch to the previous commit
from removing the inline functions from sys/fenv.h
and the redefinition error disappeared and the error changed.
make[5]: Entering directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm/machine'
Making all in arm
make[6]: Entering directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm/machine/arm'
arm-rtems5-gcc
-B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/
-isystem
/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include
-isystem /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include
-DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
-DPACKAGE_VERSION=\"3.3.0\" -DPACKAGE_STRING=\"newlib\ 3.3.0\"
-DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -I.
-I../../../../../../newlib-cygwin/newlib/libm/machine/arm -I
../../../../../../newlib-cygwin/newlib/libm/machine/arm/../../../../newlib/libm/common
-fno-builtin -ffunction-sections -fdata-sections -D_COMPILING_NEWLIB
-DCLOCK_PROVIDED -DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED
-DGETREENT_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP
-DHAVE_BLKSIZE -DHAVE_FCNTL -DHAVE_ASSERT_FUNC -D_NO_GETLOGIN
-D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET -D_NO_WORDEXP
-D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI -g -O2 -c -o
lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo
'../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-vfp.c
/tmp/ccqybjKL.s: Assembler messages:
/tmp/ccqybjKL.s:35: Error: selected processor does not support `vmrs
r3,fpscr' in ARM mode
/tmp/ccqybjKL.s:46: Error: selected processor does not support `vmsr
fpscr,r0' in ARM mode
/tmp/ccqybjKL.s:76: Error: selected processor does not support `vmrs
/tmp/ccqybjKL.s:111: Error: selected processor does not support `vmrs
r2,fpscr' in ARM mode
/tmp/ccqybjKL.s:126: Error: selected processor does not support `vmsr
fpscr,r1' in ARM mode
/tmp/ccqybjKL.s:158: Error: selected processor does not support `vmrs
/tmp/ccqybjKL.s:171: Error: selected processor does not support `vmsr
fpscr,r3' in ARM mode
/tmp/ccqybjKL.s:203: Error: selected processor does not support `vmrs
/tmp/ccqybjKL.s:233: Error: selected processor does not support `vmrs
r0,fpscr' in ARM mode
/tmp/ccqybjKL.s:264: Error: selected processor does not support `vmrs
/tmp/ccqybjKL.s:278: Error: selected processor does not support `vmsr
/tmp/ccqybjKL.s:310: Error: selected processor does not support `vmrs
/tmp/ccqybjKL.s:343: Error: selected processor does not support `vmrs
/tmp/ccqybjKL.s:357: Error: selected processor does not support `vmsr
/tmp/ccqybjKL.s:388: Error: selected processor does not support `vmsr
/tmp/ccqybjKL.s:418: Error: selected processor does not support `vmrs
/tmp/ccqybjKL.s:427: Error: selected processor does not support `vmsr
fpscr,r2' in ARM mode
/tmp/ccqybjKL.s:439: Error: selected processor does not support `vmrs
/tmp/ccqybjKL.s:463: Error: selected processor does not support `vmsr
/tmp/ccqybjKL.s:498: Error: selected processor does not support `vmrs
/tmp/ccqybjKL.s:512: Error: selected processor does not support `vmsr
/tmp/ccqybjKL.s:544: Error: selected processor does not support `vmrs
/tmp/ccqybjKL.s:557: Error: selected processor does not support `vmsr
/tmp/ccqybjKL.s:588: Error: selected processor does not support `vmrs
Makefile:476: recipe for target 'lib_a-fenv-vfp.o' failed
make[6]: *** [lib_a-fenv-vfp.o] Error 1
make[6]: Target 'all' not remade because of errors.
make[6]: Leaving directory
Making all in .
make[6]: Nothing to be done for 'all-am'.
Makefile:324: recipe for target 'all-recursive' failed
make[5]: *** [all-recursive] Error 1
make[5]: Target 'all' not remade because of errors.
make[5]: Leaving directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm'
make[5]: Nothing to be done for 'all-am'.
Makefile:553: recipe for target 'all-recursive' failed
make[4]: *** [all-recursive] Error 1
make[4]: Target 'all' not remade because of errors.
make[4]: Leaving directory
Making all in doc
make[4]: Entering directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/doc'
make[4]: Nothing to be done for 'all'.
Making all in .
'/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib'
Makefile:641: recipe for target 'all-recursive' failed
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory
Makefile:452: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory
Makefile:8491: recipe for target 'all-target-newlib' failed
make[1]: *** [all-target-newlib] Error 2
make[1]: Target 'all-target' not remade because of errors.
make[1]: Leaving directory
'/home/eshan/development/newlib/c-arm-rtems5-newlib'
Makefile:878: recipe for target 'all' failed
make: *** [all] Error 2
On Wed, May 20, 2020 at 4:44 AM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, May 19, 2020 at 5:20 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> On Wed, May 20, 2020 at 3:43 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>> wrote:
>>> On Wed, May 20, 2020 at 2:25 AM Joel Sherrill <joel at rtems.org> wrote:
>>>> On Tue, May 19, 2020 at 3:52 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>> wrote:
>>>>> On Wed, May 20, 2020 at 1:55 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>>> wrote:
>>>>>> On Wed, May 20, 2020 at 1:42 AM Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> There shouldn't need to be an arm/fenv.c file after this is over if
>>>>>>> I am thinking right. Each method will be split into its own file. I think
>>>>>>> that's how the riscv is done.
>>>>>> The files in sys/fenv are the one having inline assembly, But the
>>>>>> methods in fenv.c have the files for soft float, and vpf.
>>>>> could all the files be retailed under different #ifdef conditions
>>>>> similar to that followed in FreeBSD
>>>> Hmmm... maybe the methods in sys/fenv.h are redundant. If the bodies in
>>>> fenv.c cover all the multilibs, then delete the static inlines.
>>> This may be the case
>>> but the files in Fenv.h are the once with the assembly code.
>>> the files in fenv.c are calling functions from fenv-softfp.c and
>>> fenv-vfp.c
>>> which inturn call files for fenv.h and fenv-softfloat.h
>>> If we remove the inline declaration of the functions from Fenv.h they
>>> won't be able to get the definitions
>>> and will cause errors.
>> Warning the compiler generates:
>> arm-rtems5-gcc
>> -isystem
>> ../../../../../../newlib-cygwin/newlib/libm/machine/arm/fenv-vfp.c:29:24:
>> warning: inline function '__vfp_fegetexcept' declared but never defined
>> #define FENV_MANGLE(x) __vfp_ ##x
> Hmm... trace the naming patch from the mangled declaration to a method.
> You can drop into the build directory and run the gcc command by hand.
> Tinker with it to add a -E and save the output (not -o...). That will let
> you see the preprocessed output. Something specific and subtle is
> happening. Decode that and you win.
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:52:21:
>> note: in expansion of macro 'FENV_MANGLE'
>> #define fegetexcept FENV_MANGLE(fegetexcept)
>> warning: inline function '__vfp_fedisableexcept' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:51:25:
>> #define fedisableexcept FENV_MANGLE(fedisableexcept)
>> warning: inline function '__vfp_feenableexcept' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:50:24:
>> #define feenableexcept FENV_MANGLE(feenableexcept)
>> warning: inline function '__vfp_feupdateenv' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:49:21:
>> #define feupdateenv FENV_MANGLE(feupdateenv)
>> warning: inline function '__vfp_fesetenv' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:48:18:
>> #define fesetenv FENV_MANGLE(fesetenv)
>> warning: inline function '__vfp_feholdexcept' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:47:22:
>> #define feholdexcept FENV_MANGLE(feholdexcept)
>> warning: inline function '__vfp_fegetenv' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:46:18:
>> #define fegetenv FENV_MANGLE(fegetenv)
>> warning: inline function '__vfp_fesetround' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:45:20:
>> #define fesetround FENV_MANGLE(fesetround)
>> warning: inline function '__vfp_fegetround' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:44:20:
>> #define fegetround FENV_MANGLE(fegetround)
>> warning: inline function '__vfp_fetestexcept' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:43:22:
>> #define fetestexcept FENV_MANGLE(fetestexcept)
>> warning: inline function '__vfp_fesetexceptflag' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:41:25:
>> #define fesetexceptflag FENV_MANGLE(fesetexceptflag)
>> warning: inline function '__vfp_feraiseexcept' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:42:23:
>> #define feraiseexcept FENV_MANGLE(feraiseexcept)
>> warning: inline function '__vfp_fegetexceptflag' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:40:25:
>> #define fegetexceptflag FENV_MANGLE(fegetexceptflag)
>> warning: inline function '__vfp_feclearexcept' declared but never defined
>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:39:23:
>> #define feclearexcept FENV_MANGLE(feclearexcept)
>> arm-rtems5-gcc
>> -isystem
>> lib_a-fenv-softfp.o `test -f 'fenv-softfp.c' || echo
>> '../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-softfp.c
>> rm -f lib.a
>> arm-rtems5-ar cru lib.a lib_a-e_sqrt.o lib_a-ef_sqrt.o lib_a-s_ceil.o
>> lib_a-s_floor.o lib_a-s_nearbyint.o lib_a-s_rint.o lib_a-s_round.o
>> lib_a-s_trunc.o lib_a-sf_ceil.o lib_a-sf_floor.o lib_a-sf_nearbyint.o
>> lib_a-sf_rint.o lib_a-sf_round.o lib_a-sf_trunc.o lib_a-feclearexcept.o
>> lib_a-fegetenv.o lib_a-fegetexceptflag.o lib_a-fegetround.o
>> lib_a-feholdexcept.o lib_a-fenv.o lib_a-feraiseexcept.o lib_a-fesetenv.o
>> lib_a-fesetexceptflag.o lib_a-fesetround.o lib_a-fetestexcept.o
>> lib_a-feupdateenv.o lib_a-fenv-vfp.o lib_a-fenv-softfp.o
>> arm-rtems5-ar: `u' modifier ignored since `D' is the default (see `U')
>> arm-rtems5-ranlib lib.a
>> Making all in .
>> rm -f lib.a
>> ln arm/lib.a lib.a >/dev/null 2>/dev/null || \
>> cp arm/lib.a lib.a
>> rm -f libm.a
>> rm -rf tmp
>> mkdir tmp
>> cd tmp; \
>> for i in math/lib.a common/lib.a complex/lib.a fenv/lib.a
>> machine/lib.a; do \
>> arm-rtems5-ar x ../$i; \
>> done; \
>> arm-rtems5-ar rc ../libm.a *.o
>> arm-rtems5-ranlib libm.a
>> rm -rf tmp
>> Making all in doc
>> gcc -g -g -O2 -c ../../../../newlib-cygwin/newlib/doc/makedoc.c
>> gcc -g -O2 -o makedoc makedoc.o
>> Making all in .
>> rm -f libm.a
>> ln libm/libm.a libm.a >/dev/null 2>/dev/null || cp libm/libm.a libm.a
>> rm -rf libc.a libg.a tmp
>> mkdir tmp
>> cd tmp; \
>> arm-rtems5-ar x ../libm.a lib_a-s_fpclassify.o lib_a-sf_fpclassify.o
>> lib_a-s_isinf.o lib_a-sf_isinf.o lib_a-s_isnan.o lib_a-sf_isnan.o
>> lib_a-s_isinfd.o lib_a-sf_isinff.o lib_a-s_isnand.o lib_a-sf_isnanf.o
>> lib_a-s_nan.o lib_a-sf_nan.o lib_a-s_ldexp.o lib_a-sf_ldexp.o
>> lib_a-s_frexp.o lib_a-sf_frexp.o lib_a-s_modf.o lib_a-sf_modf.o
>> lib_a-s_scalbn.o lib_a-sf_scalbn.o lib_a-s_finite.o lib_a-sf_finite.o
>> lib_a-s_copysign.o lib_a-sf_copysign.o ; \
>> arm-rtems5-ar x ../libc/libc.a ; \
>> arm-rtems5-ar rc ../libc.a *.o
>> arm-rtems5-ranlib libc.a
>> ln libc.a libg.a >/dev/null 2>/dev/null || cp libc.a libg.a
>> rm -rf tmp
>> rm -f crt0.o
>> ln libc/crt0.o crt0.o >/dev/null 2>/dev/null || cp libc/crt0.o crt0.o
>>>> --joel
>>>>>>> --joel
>>>>>>> On Tue, May 19, 2020 at 3:05 PM Eshan Dhawan <
>>>>>>> eshandhawan51 at gmail.com> wrote:
>>>>>>>> On Wed, May 20, 2020 at 12:47 AM Joel Sherrill <joel at rtems.org>
>>>>>>>> wrote:
>>>>>>>>> Crap! The default mode <sys/fenv.h> is working is turning the
>>>>>>>>> methods into static inline which conflicts with the default implementation.
>>>>>>>>> That's what is happening.
>>>>>>>>> Cut the static inline bodies out of the arm sys/fenv.h and
>>>>>>>>> distribute them to libm/arm/XXX.c based on their method name. Drop
>>>>>>>>> __fenv_static completely.
>>>>>>>> What will happen to the fenv methods in the fenv.c file
>>>>>>>>> Make the new split out feXXX.c files FreeBSD copyright. You should
>>>>>>>>> add a note that you adapted them from their sys/fenv.h with static inline
>>>>>>>>> to have the bodies in separate files. Make the same type of note in the arm
>>>>>>>>> sys/fenv.h.
>>>>>>>>> Sorry to beat the copyright/credit thing but it is important to
>>>>>>>>> note that the meat of the code came from FreeBSD and you split it into
>>>>>>>>> files.
>>>>>>>>> --joel
>>>>>>>>> On Tue, May 19, 2020 at 1:48 PM Eshan Dhawan <
>>>>>>>>>> Hello
>>>>>>>>>> I have encountered a new error
>>>>>>>>>> the error is coming from libm/fenv
>>>>>>>>>> link to GitHub repository:
>>>>>>>>>> https://github.com/eshandhawan51/newlib-cygwin/tree/add_fenv_support
>>>>>>>>>> Make file log:
>>>>>>>>>> eshan at EDs-pc:~/development/newlib/c-arm-rtems5-newlib$ make -k
>>>>>>>>>> make[1]: Entering directory
>>>>>>>>>> make[2]: Entering directory
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/etc'
>>>>>>>>>> make[2]: Nothing to be done for 'all'.
>>>>>>>>>> Checking multilib configuration for newlib...
>>>>>>>>>> make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2"
>>>>>>>>>> "CCASFLAGS=-g -O2" "CFLAGS_FOR_BUILD=-g -O2" "CFLAGS_FOR_TARGET=-g -O2"
>>>>>>>>>> "INSTALL=/usr/bin/install -c" "LDFLAGS=" "LIBCFLAGS=-g -O2"
>>>>>>>>>> "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make" "MAKEINFO=makeinfo
>>>>>>>>>> --split-size=5000000 --split-size=5000000 " "PICFLAG="
>>>>>>>>>> "PICFLAG_FOR_TARGET=" "SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest"
>>>>>>>>>> "RUNTESTFLAGS=" "exec_prefix=/usr/local" "infodir=/usr/local/share/info"
>>>>>>>>>> "libdir=/usr/local/lib" "prefix=/usr/local" "tooldir=/usr/local/arm-rtems5"
>>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib" "AR=arm-rtems5-ar"
>>>>>>>>>> "AS=arm-rtems5-as" "CC=arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> " "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2" "NM=arm-rtems5-nm" "PICFLAG="
>>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" all-recursive
>>>>>>>>>> make[3]: Entering directory
>>>>>>>>>> -isystem
>>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" DO=all multi-do # make
>>>>>>>>>> if [ -z "thumb vfp/hard thumb/armv6-m thumb/armv7-a thumb/armv7-r
>>>>>>>>>> thumb/cortex-m3 thumb/cortex-m4 thumb/armv7-a/neon/hard
>>>>>>>>>> thumb/armv7-r/vfpv3-d16/hard thumb/cortex-m4/fpv4-sp-d16/hard
>>>>>>>>>> thumb/cortex-m7/fpv5-d16/hard eb/thumb/armv7-r
>>>>>>>>>> eb/thumb/armv7-r/vfpv3-d16/hard" ]; then \
>>>>>>>>>> true; \
>>>>>>>>>> else \
>>>>>>>>>> rootpre=`${PWDCMD-pwd}`/; export rootpre; \
>>>>>>>>>> srcrootpre=`cd ../../../newlib-cygwin/newlib; ${PWDCMD-pwd}`/;
>>>>>>>>>> export srcrootpre; \
>>>>>>>>>> lib=`echo "${rootpre}" | sed -e 's,^.*/\([^/][^/]*\)/$,\1,'`; \
>>>>>>>>>> compiler="arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> for i in `${compiler} --print-multi-lib 2>/dev/null`; do \
>>>>>>>>>> dir=`echo $i | sed -e 's/;.*$//'`; \
>>>>>>>>>> if [ "${dir}" = "." ]; then \
>>>>>>>>>> true; \
>>>>>>>>>> else \
>>>>>>>>>> if [ -d ../${dir}/${lib} ]; then \
>>>>>>>>>> flags=`echo $i | sed -e 's/^[^;]*;//' -e 's/@/ -/g'`; \
>>>>>>>>>> if (cd ../${dir}/${lib}; make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc"
>>>>>>>>>> "CFLAGS=-g -O2" "CCASFLAGS=-g -O2" "CFLAGS_FOR_BUILD=-g -O2"
>>>>>>>>>> "CFLAGS_FOR_TARGET=-g -O2" "INSTALL=/usr/bin/install -c" "LDFLAGS="
>>>>>>>>>> "LIBCFLAGS=-g -O2" "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make"
>>>>>>>>>> "MAKEINFO=makeinfo --split-size=5000000 --split-size=5000000 " "PICFLAG="
>>>>>>>>>> -isystem
>>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" \
>>>>>>>>>> CFLAGS="-g -O2 ${flags}" \
>>>>>>>>>> CCASFLAGS="-g -O2 ${flags}" \
>>>>>>>>>> FCFLAGS=" ${flags}" \
>>>>>>>>>> FFLAGS=" ${flags}" \
>>>>>>>>>> ADAFLAGS=" ${flags}" \
>>>>>>>>>> prefix="/usr/local" \
>>>>>>>>>> exec_prefix="/usr/local" \
>>>>>>>>>> GCJFLAGS=" ${flags}" \
>>>>>>>>>> GOCFLAGS="-O2 -g ${flags}" \
>>>>>>>>>> CXXFLAGS="-g -O2 ${flags}" \
>>>>>>>>>> LIBCFLAGS="-g -O2 ${flags}" \
>>>>>>>>>> LIBCXXFLAGS="-g -O2 -fno-implicit-templates ${flags}" \
>>>>>>>>>> LDFLAGS=" ${flags}" \
>>>>>>>>>> MULTIFLAGS="${flags}" \
>>>>>>>>>> DESTDIR="" \
>>>>>>>>>> INSTALL="/usr/bin/install -c" \
>>>>>>>>>> INSTALL_DATA="/usr/bin/install -c -m 644" \
>>>>>>>>>> INSTALL_PROGRAM="/usr/bin/install -c" \
>>>>>>>>>> INSTALL_SCRIPT="/usr/bin/install -c" \
>>>>>>>>>> all); then \
>>>>>>>>>> true; \
>>>>>>>>>> else \
>>>>>>>>>> exit 1; \
>>>>>>>>>> fi; \
>>>>>>>>>> else true; \
>>>>>>>>>> fi; \
>>>>>>>>>> fi; \
>>>>>>>>>> done; \
>>>>>>>>>> fi
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib'
>>>>>>>>>> make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2 -mthumb"
>>>>>>>>>> "CCASFLAGS=-g -O2 -mthumb" "CFLAGS_FOR_BUILD=-g -O2" "CFLAGS_FOR_TARGET=-g
>>>>>>>>>> -O2" "INSTALL=/usr/bin/install -c" "LDFLAGS=-mthumb" "LIBCFLAGS=-g -O2
>>>>>>>>>> -mthumb" "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make" "MAKEINFO=makeinfo
>>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib/thumb" "AR=arm-rtems5-ar"
>>>>>>>>>> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/
>>>>>>>>>> -isystem
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include
>>>>>>>>>> -mthumb" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2 -mthumb" "NM=arm-rtems5-nm"
>>>>>>>>>> "PICFLAG=" "RANLIB=arm-rtems5-ranlib" "DESTDIR=" all-recursive
>>>>>>>>>> true "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2 -mthumb"
>>>>>>>>>> -isystem
>>>>>>>>>> "PICFLAG=" "RANLIB=arm-rtems5-ranlib" "DESTDIR=" DO=all multi-do # make
>>>>>>>>>> Making all in libc
>>>>>>>>>> make[7]: Entering directory
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc'
>>>>>>>>>> Making all in argz
>>>>>>>>>> make[8]: Entering directory
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/argz'
>>>>>>>>>> make[8]: Nothing to be done for 'all'.
>>>>>>>>>> make[8]: Leaving directory
>>>>>>>>>> Making all in stdlib
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/stdlib'
>>>>>>>>>> Making all in ctype
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/ctype'
>>>>>>>>>> Making all in search
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/search'
>>>>>>>>>> Making all in stdio
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/stdio'
>>>>>>>>>> Making all in string
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/string'
>>>>>>>>>> Making all in signal
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/signal'
>>>>>>>>>> Making all in time
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/time'
>>>>>>>>>> Making all in locale
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/locale'
>>>>>>>>>> Making all in sys
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/sys'
>>>>>>>>>> Making all in rtems
>>>>>>>>>> make[9]: Entering directory
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/sys/rtems'
>>>>>>>>>> make[9]: Nothing to be done for 'all'.
>>>>>>>>>> make[9]: Leaving directory
>>>>>>>>>> Making all in .
>>>>>>>>>> make[9]: Nothing to be done for 'all-am'.
>>>>>>>>>> Making all in reent
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/reent'
>>>>>>>>>> Making all in errno
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/errno'
>>>>>>>>>> Making all in misc
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/misc'
>>>>>>>>>> Making all in machine
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/machine'
>>>>>>>>>> Making all in arm
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/machine/arm'
>>>>>>>>>> Making all in .
>>>>>>>>>> Making all in unix
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/unix'
>>>>>>>>>> Making all in posix
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/posix'
>>>>>>>>>> Making all in ssp
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/ssp'
>>>>>>>>>> Making all in .
>>>>>>>>>> make[8]: Nothing to be done for 'all-am'.
>>>>>>>>>> make[7]: Leaving directory
>>>>>>>>>> Making all in libm
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm'
>>>>>>>>>> Making all in math
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/math'
>>>>>>>>>> Making all in common
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/common'
>>>>>>>>>> Making all in complex
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/complex'
>>>>>>>>>> Making all in fenv
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/fenv'
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine'
>>>>>>>>>> Making all in arm
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine/arm'
>>>>>>>>>> Making all in .
>>>>>>>>>> Making all in .
>>>>>>>>>> rm -f thumb/crt0.o
>>>>>>>>>> ln libc/crt0.o thumb/crt0.o >/dev/null 2>/dev/null || cp
>>>>>>>>>> rm -f thumb/libc.a ./thumb/libg.a
>>>>>>>>>> ln libc.a thumb/libc.a >/dev/null 2>/dev/null || cp libc.a
>>>>>>>>>> thumb/libc.a
>>>>>>>>>> ln libg.a ./thumb/libg.a >/dev/null 2>/dev/null || \
>>>>>>>>>> cp libg.a ./thumb/libg.a
>>>>>>>>>> rm -f thumb/libm.a
>>>>>>>>>> ln libm.a thumb/libm.a >/dev/null 2>/dev/null || cp libm.a
>>>>>>>>>> thumb/libm.a
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib'
>>>>>>>>>> make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2 -mfpu=vfp
>>>>>>>>>> -mfloat-abi=hard" "CCASFLAGS=-g -O2 -mfpu=vfp -mfloat-abi=hard"
>>>>>>>>>> "INSTALL=/usr/bin/install -c" "LDFLAGS=-mfpu=vfp -mfloat-abi=hard"
>>>>>>>>>> "LIBCFLAGS=-g -O2 -mfpu=vfp -mfloat-abi=hard" "LIBCFLAGS_FOR_TARGET=-g
>>>>>>>>>> -O2" "MAKE=make" "MAKEINFO=makeinfo --split-size=5000000
>>>>>>>>>> --split-size=5000000 " "PICFLAG=" "PICFLAG_FOR_TARGET="
>>>>>>>>>> "SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest" "RUNTESTFLAGS="
>>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib/vfp/hard" "AR=arm-rtems5-ar"
>>>>>>>>>> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/
>>>>>>>>>> -isystem
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include
>>>>>>>>>> -mfpu=vfp -mfloat-abi=hard" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2
>>>>>>>>>> -mfpu=vfp -mfloat-abi=hard" "NM=arm-rtems5-nm" "PICFLAG="
>>>>>>>>>> true "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2 -mfpu=vfp
>>>>>>>>>> -isystem
>>>>>>>>>> Making all in libc
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc'
>>>>>>>>>> Making all in argz
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/argz'
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/stdlib'
>>>>>>>>>> Making all in ctype
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/ctype'
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/search'
>>>>>>>>>> Making all in stdio
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/stdio'
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/string'
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/signal'
>>>>>>>>>> Making all in time
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/time'
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/locale'
>>>>>>>>>> Making all in sys
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/sys'
>>>>>>>>>> Making all in rtems
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/sys/rtems'
>>>>>>>>>> Making all in .
>>>>>>>>>> Making all in reent
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/reent'
>>>>>>>>>> Making all in errno
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/errno'
>>>>>>>>>> Making all in misc
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/misc'
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/machine'
>>>>>>>>>> Making all in arm
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/machine/arm'
>>>>>>>>>> Making all in .
>>>>>>>>>> Making all in unix
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/unix'
>>>>>>>>>> Making all in posix
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/posix'
>>>>>>>>>> Making all in ssp
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/ssp'
>>>>>>>>>> Making all in .
>>>>>>>>>> Making all in libm
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm'
>>>>>>>>>> Making all in math
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/math'
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/common'
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/complex'
>>>>>>>>>> Making all in fenv
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/fenv'
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> -mfpu=vfp -mfloat-abi=hard -DPACKAGE_NAME=\"newlib\"
>>>>>>>>>> -DPACKAGE_TARNAME=\"newlib\" -DPACKAGE_VERSION=\"3.3.0\"
>>>>>>>>>> -DPACKAGE_STRING=\"newlib\ 3.3.0\" -DPACKAGE_BUGREPORT=\"\"
>>>>>>>>>> -I../../../../../../../newlib-cygwin/newlib/libm/fenv -fno-builtin
>>>>>>>>>> -ffunction-sections -fdata-sections -D_COMPILING_NEWLIB -DCLOCK_PROVIDED
>>>>>>>>>> -DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED -DGETREENT_PROVIDED
>>>>>>>>>> -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL
>>>>>>>>>> -DHAVE_ASSERT_FUNC -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS
>>>>>>>>>> -D_NO_SIGSET -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI
>>>>>>>>>> -fbuiltin -fno-math-errno -g -O2 -mfpu=vfp -mfloat-abi=hard -c -o
>>>>>>>>>> lib_a-feclearexcept.o `test -f 'feclearexcept.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feclearexcept.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:64:5:
>>>>>>>>>> error: redefinition of 'feclearexcept'
>>>>>>>>>> int feclearexcept(int excepts)
>>>>>>>>>> In file included from
>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:15:0,
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:126:1:
>>>>>>>>>> note: previous definition of 'feclearexcept' was here
>>>>>>>>>> Makefile:347: recipe for target 'lib_a-feclearexcept.o' failed
>>>>>>>>>> make[8]: *** [lib_a-feclearexcept.o] Error 1
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> lib_a-fegetenv.o `test -f 'fegetenv.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetenv.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetenv.c:64:5:
>>>>>>>>>> error: redefinition of 'fegetenv'
>>>>>>>>>> int fegetenv(fenv_t *envp)
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetenv.c:29:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:198:1:
>>>>>>>>>> note: previous definition of 'fegetenv' was here
>>>>>>>>>> Makefile:359: recipe for target 'lib_a-fegetenv.o' failed
>>>>>>>>>> make[8]: *** [lib_a-fegetenv.o] Error 1
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> lib_a-fegetexceptflag.o `test -f 'fegetexceptflag.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetexceptflag.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetexceptflag.c:65:5:
>>>>>>>>>> error: redefinition of 'fegetexceptflag'
>>>>>>>>>> int fegetexceptflag(fexcept_t *flagp, int excepts)
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetexceptflag.c:29:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:137:1:
>>>>>>>>>> note: previous definition of 'fegetexceptflag' was here
>>>>>>>>>> Makefile:365: recipe for target 'lib_a-fegetexceptflag.o' failed
>>>>>>>>>> make[8]: *** [lib_a-fegetexceptflag.o] Error 1
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> lib_a-fegetround.o `test -f 'fegetround.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetround.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetround.c:63:5:
>>>>>>>>>> error: redefinition of 'fegetround'
>>>>>>>>>> int fegetround(void)
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetround.c:29:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:177:1:
>>>>>>>>>> note: previous definition of 'fegetround' was here
>>>>>>>>>> fegetround(void)
>>>>>>>>>> Makefile:371: recipe for target 'lib_a-fegetround.o' failed
>>>>>>>>>> make[8]: *** [lib_a-fegetround.o] Error 1
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> lib_a-feholdexcept.o `test -f 'feholdexcept.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feholdexcept.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feholdexcept.c:67:5:
>>>>>>>>>> error: redefinition of 'feholdexcept'
>>>>>>>>>> int feholdexcept(fenv_t *envp)
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feholdexcept.c:29:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:206:1:
>>>>>>>>>> note: previous definition of 'feholdexcept' was here
>>>>>>>>>> Makefile:377: recipe for target 'lib_a-feholdexcept.o' failed
>>>>>>>>>> make[8]: *** [lib_a-feholdexcept.o] Error 1
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> lib_a-feraiseexcept.o `test -f 'feraiseexcept.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feraiseexcept.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feraiseexcept.c:64:5:
>>>>>>>>>> error: redefinition of 'feraiseexcept'
>>>>>>>>>> int feraiseexcept(int excepts)
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feraiseexcept.c:29:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:159:1:
>>>>>>>>>> note: previous definition of 'feraiseexcept' was here
>>>>>>>>>> Makefile:383: recipe for target 'lib_a-feraiseexcept.o' failed
>>>>>>>>>> make[8]: *** [lib_a-feraiseexcept.o] Error 1
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> lib_a-fesetenv.o `test -f 'fesetenv.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetenv.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetenv.c:69:5:
>>>>>>>>>> error: redefinition of 'fesetenv'
>>>>>>>>>> int fesetenv(const fenv_t *envp)
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetenv.c:29:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:218:1:
>>>>>>>>>> note: previous definition of 'fesetenv' was here
>>>>>>>>>> Makefile:389: recipe for target 'lib_a-fesetenv.o' failed
>>>>>>>>>> make[8]: *** [lib_a-fesetenv.o] Error 1
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> lib_a-fesetexceptflag.o `test -f 'fesetexceptflag.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetexceptflag.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetexceptflag.c:70:5:
>>>>>>>>>> error: redefinition of 'fesetexceptflag'
>>>>>>>>>> int fesetexceptflag(const fexcept_t *flagp, int excepts)
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetexceptflag.c:29:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:147:1:
>>>>>>>>>> note: previous definition of 'fesetexceptflag' was here
>>>>>>>>>> Makefile:395: recipe for target 'lib_a-fesetexceptflag.o' failed
>>>>>>>>>> make[8]: *** [lib_a-fesetexceptflag.o] Error 1
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> lib_a-fesetround.o `test -f 'fesetround.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetround.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetround.c:64:5:
>>>>>>>>>> error: redefinition of 'fesetround'
>>>>>>>>>> int fesetround(int round)
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetround.c:29:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:186:1:
>>>>>>>>>> note: previous definition of 'fesetround' was here
>>>>>>>>>> Makefile:401: recipe for target 'lib_a-fesetround.o' failed
>>>>>>>>>> make[8]: *** [lib_a-fesetround.o] Error 1
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> lib_a-fetestexcept.o `test -f 'fetestexcept.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fetestexcept.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fetestexcept.c:65:5:
>>>>>>>>>> error: redefinition of 'fetestexcept'
>>>>>>>>>> int fetestexcept(int excepts)
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fetestexcept.c:30:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:168:1:
>>>>>>>>>> note: previous definition of 'fetestexcept' was here
>>>>>>>>>> Makefile:407: recipe for target 'lib_a-fetestexcept.o' failed
>>>>>>>>>> make[8]: *** [lib_a-fetestexcept.o] Error 1
>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>> -isystem
>>>>>>>>>> lib_a-feupdateenv.o `test -f 'feupdateenv.c' || echo
>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feupdateenv.c
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feupdateenv.c:69:5:
>>>>>>>>>> error: redefinition of 'feupdateenv'
>>>>>>>>>> int feupdateenv(const fenv_t *envp)
>>>>>>>>>> from
>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feupdateenv.c:29:
>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:226:1:
>>>>>>>>>> note: previous definition of 'feupdateenv' was here
>>>>>>>>>> Makefile:413: recipe for target 'lib_a-feupdateenv.o' failed
>>>>>>>>>> make[8]: *** [lib_a-feupdateenv.o] Error 1
>>>>>>>>>> make[8]: Target 'all' not remade because of errors.
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/machine'
>>>>>>>>>> Making all in arm
>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/machine/arm'
>>>>>>>>>> Making all in .
>>>>>>>>>> rm -f libm.a
>>>>>>>>>> rm -rf tmp
>>>>>>>>>> mkdir tmp
>>>>>>>>>> cd tmp; \
>>>>>>>>>> machine/lib.a; do \
>>>>>>>>>> done; \
>>>>>>>>>> arm-rtems5-ar: ../fenv/lib.a: No such file or directory
>>>>>>>>>> rm -rf tmp
>>>>>>>>>> make[7]: *** [all-recursive] Error 1
>>>>>>>>>> make[7]: Target 'all' not remade because of errors.
>>>>>>>>>> Making all in .
>>>>>>>>>> rm -f libm.a
>>>>>>>>>> libm.a
>>>>>>>>>> mkdir tmp
>>>>>>>>>> cd tmp; \
>>>>>>>>>> lib_a-sf_fpclassify.o lib_a-s_isinf.o lib_a-sf_isinf.o lib_a-s_isnan.o
>>>>>>>>>> lib_a-sf_isnan.o lib_a-s_isinfd.o lib_a-sf_isinff.o lib_a-s_isnand.o
>>>>>>>>>> lib_a-sf_isnanf.o lib_a-s_nan.o lib_a-sf_nan.o lib_a-s_ldexp.o
>>>>>>>>>> lib_a-sf_ldexp.o lib_a-s_frexp.o lib_a-sf_frexp.o lib_a-s_modf.o
>>>>>>>>>> lib_a-sf_modf.o lib_a-s_scalbn.o lib_a-sf_scalbn.o lib_a-s_finite.o
>>>>>>>>>> lib_a-sf_finite.o lib_a-s_copysign.o lib_a-sf_copysign.o ; \
>>>>>>>>>> rm -rf tmp
>>>>>>>>>> rm -f vfp/hard/crt0.o
>>>>>>>>>> ln libc/crt0.o vfp/hard/crt0.o >/dev/null 2>/dev/null || cp
>>>>>>>>>> rm -f vfp/hard/libc.a ./vfp/hard/libg.a
>>>>>>>>>> ln libc.a vfp/hard/libc.a >/dev/null 2>/dev/null || cp libc.a
>>>>>>>>>> vfp/hard/libc.a
>>>>>>>>>> ln libg.a ./vfp/hard/libg.a >/dev/null 2>/dev/null || \
>>>>>>>>>> cp libg.a ./vfp/hard/libg.a
>>>>>>>>>> rm -f vfp/hard/libm.a
>>>>>>>>>> ln libm.a vfp/hard/libm.a >/dev/null 2>/dev/null || cp libm.a
>>>>>>>>>> vfp/hard/libm.a
>>>>>>>>>> make[6]: *** [all-recursive] Error 1
>>>>>>>>>> make[5]: *** [all] Error 2
>>>>>>>>>> Makefile:1260: recipe for target 'multi-do' failed
>>>>>>>>>> make[4]: *** [multi-do] Error 1
>>>>>>>>>> Makefile:1176: recipe for target 'all-multi' failed
>>>>>>>>>> make[3]: *** [all-multi] Error 2
>>>>>>>>>> make[3]: Target 'all-recursive' not remade because of errors.
>>>>>>>>>> Thanks
>>>>>>>>>> -Eshan :)
>>>>>>>>>> On Sat, May 16, 2020 at 8:09 PM Joel Sherrill <joel at rtems.org>
>>>>>>>>>> wrote:
>>>>>>>>>>> On Fri, May 15, 2020, 5:59 PM Eshan Dhawan <
>>>>>>>>>>>> On Fri, May 15, 2020 at 2:22 AM Eshan Dhawan <
>>>>>>>>>>>>> On Wed, May 13, 2020 at 7:40 PM Joel Sherrill <joel at rtems.org>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> National free hint day!!!
>>>>>>>>>>>>>> Look above the line that is reported. You will see
>>>>>>>>>>>>>> __BEGIN_DECL. It isn't defined. It is intended to expand to the __cplusplus
>>>>>>>>>>>>>> wrapper.
>>>>>>>>>>>>>> After you fix this, you will sequentially find 2 other things
>>>>>>>>>>>>>> to change in this file.
>>>>>>>>>>>>>> I have made those changes when a new error occurs from the
>>>>>>>>>>>>> assembler in arm thumb mode
>>>>>>>>>>>>> There is no support for vfp instructions in arm thumb.
>>>>>>>>>>>>> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html
>>>>>>>>>>>>> So in which file will the compiler instructions given in the
>>>>>>>>>>>>> page
>>>>>>>>>>>>> <http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html>
>>>>>>>>>>>>> added?
>>>>>>>>>>>> FreeBSD has added file and architecture-specific flags in their
>>>>>>>>>>>> makefile.inc
>>>>>>>>>>>> https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/Makefile.inc
>>>>>>>>>>>> How will it be added in newlib
>>>>>>>>>>>> I tried adding the flags -mfpu=vfp -mfloat-abi=softfp (used in
>>>>>>>>>>>> FreeBSD) to makefile.in but no effect.
>>>>>>>>>>> This isn't going to work with newlib. They don't specify CPU
>>>>>>>>>>> flags that way.
>>>>>>>>>>> The fenv code is going to have to compile for every multilib
>>>>>>>>>>> variant built by arm-rtems and arm-eabi. You will have to use conditionals
>>>>>>>>>>> based on the flags gcc uses to indicate the various cpu features. This
>>>>>>>>>>> command should be close to how you you dump them.
>>>>>>>>>>> gcc -dM -E - </dev/null
>>>>>>>>>>> Add a CPU flag and see how the setting change.
>>>>>>>>>>> You can also look in rtems score cpu arm for examples since the
>>>>>>>>>>> core arm code will be dealing with these.
>>>>>>>>>>> --joel
>>>>>>>>>>>> thanks
>>>>>>>>>>>> -Eshan
>>>>>>>>>>>>> Errors :
>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>> -mthumb -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
>>>>>>>>>>>>> -I../../../../../../../newlib-cygwin/newlib/libm/machine/arm -I
>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/machine/arm/../../../../newlib/libm/common
>>>>>>>>>>>>> -fno-builtin -mfpu=vfpv2 -ffunction-sections -fdata-sections
>>>>>>>>>>>>> -D_COMPILING_NEWLIB -DCLOCK_PROVIDED -DMALLOC_PROVIDED -DEXIT_PROVIDED
>>>>>>>>>>>>> -DSIGNAL_PROVIDED -DGETREENT_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED
>>>>>>>>>>>>> -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL -DHAVE_ASSERT_FUNC
>>>>>>>>>>>>> -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET
>>>>>>>>>>>>> -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI -g -O2
>>>>>>>>>>>>> -mthumb -c -o lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo
>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-vfp.c
>>>>>>>>>>>>> /tmp/ccEHiFws.s: Assembler messages:
>>>>>>>>>>>>> /tmp/ccEHiFws.s:37: Error: selected processor does not support
>>>>>>>>>>>>> `vmrs r3,fpscr' in Thumb mode
>>>>>>>>>>>>> /tmp/ccEHiFws.s:48: Error: selected processor does not support
>>>>>>>>>>>>> `vmsr fpscr,r3' in Thumb mode
>>>>>>>>>>>>> /tmp/ccEHiFws.s:81: Error: selected processor does not support
>>>>>>>>>>>>> /tmp/ccEHiFws.s:119: Error: selected processor does not
>>>>>>>>>>>>> support `vmrs r3,fpscr' in Thumb mode
>>>>>>>>>>>>> /tmp/ccEHiFws.s:134: Error: selected processor does not
>>>>>>>>>>>>> support `vmsr fpscr,r3' in Thumb mode
>>>>>>>>>>>>> /tmp/ccEHiFws.s:169: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:182: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:217: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:251: Error: selected processor does not
>>>>>>>>>>>>> support `vmrs r0,fpscr' in Thumb mode
>>>>>>>>>>>>> /tmp/ccEHiFws.s:288: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:303: Error: selected processor does not
>>>>>>>>>>>>> support `vmsr fpscr,r0' in Thumb mode
>>>>>>>>>>>>> /tmp/ccEHiFws.s:340: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:374: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:390: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:424: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:457: Error: selected processor does not
>>>>>>>>>>>>> support `vmrs r1,fpscr' in Thumb mode
>>>>>>>>>>>>> /tmp/ccEHiFws.s:466: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:478: Error: selected processor does not
>>>>>>>>>>>>> support `vmrs r2,fpscr' in Thumb mode
>>>>>>>>>>>>> /tmp/ccEHiFws.s:503: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:543: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:559: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:595: Error: selected processor does not
>>>>>>>>>>>>> /tmp/ccEHiFws.s:612: Error: selected processor does not
>>>>>>>>>>>>> support `vmsr fpscr,r2' in Thumb mode
>>>>>>>>>>>>> /tmp/ccEHiFws.s:647: Error: selected processor does not
>>>>>>>>>>>>> make[9]: *** [lib_a-fenv-vfp.o] Error 1
>>>>>>>>>>>>> make[8]: *** [all-recursive] Error 1
>>>>>>>>>>>>> -Eshan
>>>>>>>>>>>>>> Then we need to make a decision whether the static inline
>>>>>>>>>>>>>> versions of the methods in sys/fenv.h are appropriate for newlib or not.
>>>>>>>>>>>>>> --joel
>>>>>>>>>>>>>> On Tue, May 12, 2020 at 5:20 PM Joel Sherrill <joel at rtems.org>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>> Gedare is right but one more piece of information is needed.
>>>>>>>>>>>>>>> When newlib is being built, it lays target dependent files on top of
>>>>>>>>>>>>>>> generic ones. So the default sys/fenv.h is replaced with something like
>>>>>>>>>>>>>>> libc/machine/arm/sys/fenv.h. Make sure that
>>>>>>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h is
>>>>>>>>>>>>>>> in fact the file you think it should be.
>>>>>>>>>>>>>>> Also look at what is supposed to be in the generic fenv.h
>>>>>>>>>>>>>>> and <sys/fenv.h>. You will probably have to tweak it some.
>>>>>>>>>>>>>>> Check out what is in x86_64/fenv.h and riscv/fenv.h with
>>>>>>>>>>>>>>> respect to the default environment variable. It looks to be declared
>>>>>>>>>>>>>>> differently in the other ports so you may have to make it match.
>>>>>>>>>>>>>>> But more output does help.
>>>>>>>>>>>>>>> --joel
>>>>>>>>>>>>>>> On Tue, May 12, 2020 at 4:53 PM Gedare Bloom <
>>>>>>>>>>>>>>> gedare at rtems.org> wrote:
>>>>>>>>>>>>>>>> Take the first error reported, and show what is being
>>>>>>>>>>>>>>>> compiled. You've
>>>>>>>>>>>>>>>> trimmed off too much preceding this to know what is being
>>>>>>>>>>>>>>>> compiled and
>>>>>>>>>>>>>>>> how this might be influencing your error.
>>>>>>>>>>>>>>>> The specific error you're getting is often due to some
>>>>>>>>>>>>>>>> syntax errors
>>>>>>>>>>>>>>>> preceding the line shown.
>>>>>>>>>>>>>>>> On Tue, May 12, 2020 at 2:59 PM Eshan Dhawan <
>>>>>>>>>>>>>>>> > Hello everyone,
>>>>>>>>>>>>>>>> > After adding the files and compiling. I am
>>>>>>>>>>>>>>>> > getting a few errors which I am not able to rectify.
>>>>>>>>>>>>>>>> > If you could take a look and tell how to sort them.
>>>>>>>>>>>>>>>> > link to newlib's git repo:
>>>>>>>>>>>>>>>> > errors :
>>>>>>>>>>>>>>>> > from
>>>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include/sys/fenv.h:82:1:
>>>>>>>>>>>>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'extern'
>>>>>>>>>>>>>>>> > extern const fenv_t *_fe_dfl_env;
>>>>>>>>>>>>>>>> ../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:0:
>>>>>>>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:22:1:
>>>>>>>>>>>>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'int'
>>>>>>>>>>>>>>>> > int feclearexcept(int excepts);
>>>>>>>>>>>>>>>> > thanks
>>>>>>>>>>>>>>>> > -Eshan
>>>>>>>>>>>>>>>> > On Sat, May 9, 2020 at 2:53 AM Joel Sherrill <
>>>>>>>>>>>>>>>> >> On Thu, May 7, 2020 at 1:33 PM Eshan Dhawan <
>>>>>>>>>>>>>>>> >>> Hello everyone,
>>>>>>>>>>>>>>>> >>> This the tread to discuss adding fenv support for ARM
>>>>>>>>>>>>>>>> architecture in newlib.
>>>>>>>>>>>>>>>> >>> Link to previous thread:
>>>>>>>>>>>>>>>> https://lists.rtems.org/pipermail/devel/2020-March/058473.html
>>>>>>>>>>>>>>>> >>> ---FreeBSD Source
>>>>>>>>>>>>>>>> https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
>>>>>>>>>>>>>>>> https://github.com/freebsd/freebsd/blob/master/sys/arm/include/ieeefp.h
>>>>>>>>>>>>>>>> >>> ---NetBSD Source
>>>>>>>>>>>>>>>> https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
>>>>>>>>>>>>>>>> >>> --- Musl has no implementation for fenv support for
>>>>>>>>>>>>>>>> ARM in it
>>>>>>>>>>>>>>>> >>> After going through the implementations both FreeBSD
>>>>>>>>>>>>>>>> and NetBSD have a stub implementation.
>>>>>>>>>>>>>>>> >>> But then FreeBSD implementation seems to be more
>>>>>>>>>>>>>>>> portable compared to that in NetBSD.
>>>>>>>>>>>>>>>> >>> Should I start porting it from FreeBSD?
>>>>>>>>>>>>>>>> >>> And which ARM BSP should I use for testing the changes?
>>>>>>>>>>>>>>>> >>> Currently, I have xilinx_zynq_a9_qemu build
>>>>>>>>>>>>>>>> >> I think the FreeBSD implementation is the one to use. It
>>>>>>>>>>>>>>>> looks to support hard and soft floating point implementations.
>>>>>>>>>>>>>>>> >> I think the fenv.h file there will have to be worked on
>>>>>>>>>>>>>>>> so some of the contents go into sys or machine/fenv.h. There is a portable
>>>>>>>>>>>>>>>> fenv.h.
>>>>>>>>>>>>>>>> >>> There would also be a requirement to discuss where to
>>>>>>>>>>>>>>>> place the files in Newlib.
>>>>>>>>>>>>>>>> >> Not much to discuss. It should go into
>>>>>>>>>>>>>>>> newlib-cygwin/newlib/libm/machine/arm.
>>>>>>>>>>>>>>>> >>> Thanks
>>>>>>>>>>>>>>>> >>> -Eshan
>>>>>>>>>>>>>>>> > _______________________________________________
>>>>>>>>>>>>>>>> > devel mailing list
>>>>>>>>>>>>>>>> > devel at rtems.org
>>>>>>>>>>>>>>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200521/6b63e645/attachment-0001.html>
