Adding fenv support for ARM
Wed May 20 19:47:50 UTC 2020
On Wed, May 20, 2020 at 2:40 PM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> I compiled the fenv-vpf.c and got this output.
> output file:
> https://github.com/eshandhawan51/rough_notes/blob/master/gcc_fenv-vfp.txt
> A strange thing happened today I reset the branch to the previous commit
> from removing the inline functions from sys/fenv.h
> and the redefinition error disappeared and the error changed.
> make[5]: Entering directory
> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm/machine'
> Making all in arm
> make[6]: Entering directory
> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm/machine/arm'
> arm-rtems5-gcc
> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/
> -isystem
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include
> -isystem /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include
>  -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
> -DPACKAGE_VERSION=\"3.3.0\" -DPACKAGE_STRING=\"newlib\ 3.3.0\"
> -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -I.
> -I../../../../../../newlib-cygwin/newlib/libm/machine/arm -I
> ../../../../../../newlib-cygwin/newlib/libm/machine/arm/../../../../newlib/libm/common
> -fno-builtin -ffunction-sections -fdata-sections  -D_COMPILING_NEWLIB
> -DCLOCK_PROVIDED -DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED
> -DGETREENT_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP
> -DHAVE_BLKSIZE -DHAVE_FCNTL -DHAVE_ASSERT_FUNC -D_NO_GETLOGIN
> -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET -D_NO_WORDEXP
> -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI      -g -O2 -c -o
> lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo
> '../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-vfp.c
> /tmp/ccqybjKL.s: Assembler messages:
> /tmp/ccqybjKL.s:35: Error: selected processor does not support `vmrs
> r3,fpscr' in ARM mode
This looks like a bit of progress to me. As bad as getting a compile error
sounds.
I do not see any -mXXX options on the gcc invocation above. fenv-vfp.c is
being compiled in this situation which is understandable because newlib
builds every file independent of if it is appropriate for the CPU model
variant or not. This file needs to have its contents wrapped in "#if
vfp_avaiable" or whatever gcc defines when vfp is available. The other fenv
variant files will have to have the opposite of that to ensure that the no
VFP variant is not built when vfp is available.
Does that make sense? All the files in libm/arm are going to get compiled.
The contents need to be disabled if that implementation is not right for
the CPU model variant. In the end, only one implementation of the fenv
methods should get real code produced.
> /tmp/ccqybjKL.s:46: Error: selected processor does not support `vmsr
> fpscr,r0' in ARM mode
> /tmp/ccqybjKL.s:76: Error: selected processor does not support `vmrs
> /tmp/ccqybjKL.s:111: Error: selected processor does not support `vmrs
> r2,fpscr' in ARM mode
> /tmp/ccqybjKL.s:126: Error: selected processor does not support `vmsr
> fpscr,r1' in ARM mode
> /tmp/ccqybjKL.s:158: Error: selected processor does not support `vmrs
> /tmp/ccqybjKL.s:171: Error: selected processor does not support `vmsr
> fpscr,r3' in ARM mode
> /tmp/ccqybjKL.s:203: Error: selected processor does not support `vmrs
> /tmp/ccqybjKL.s:233: Error: selected processor does not support `vmrs
> r0,fpscr' in ARM mode
> /tmp/ccqybjKL.s:264: Error: selected processor does not support `vmrs
> /tmp/ccqybjKL.s:278: Error: selected processor does not support `vmsr
> /tmp/ccqybjKL.s:310: Error: selected processor does not support `vmrs
> /tmp/ccqybjKL.s:343: Error: selected processor does not support `vmrs
> /tmp/ccqybjKL.s:357: Error: selected processor does not support `vmsr
> /tmp/ccqybjKL.s:388: Error: selected processor does not support `vmsr
> /tmp/ccqybjKL.s:418: Error: selected processor does not support `vmrs
> /tmp/ccqybjKL.s:427: Error: selected processor does not support `vmsr
> fpscr,r2' in ARM mode
> /tmp/ccqybjKL.s:439: Error: selected processor does not support `vmrs
> /tmp/ccqybjKL.s:463: Error: selected processor does not support `vmsr
> /tmp/ccqybjKL.s:498: Error: selected processor does not support `vmrs
> /tmp/ccqybjKL.s:512: Error: selected processor does not support `vmsr
> /tmp/ccqybjKL.s:544: Error: selected processor does not support `vmrs
> /tmp/ccqybjKL.s:557: Error: selected processor does not support `vmsr
> /tmp/ccqybjKL.s:588: Error: selected processor does not support `vmrs
> Makefile:476: recipe for target 'lib_a-fenv-vfp.o' failed
> make[6]: *** [lib_a-fenv-vfp.o] Error 1
> make[6]: Target 'all' not remade because of errors.
> make[6]: Leaving directory
> Making all in .
> make[6]: Nothing to be done for 'all-am'.
> Makefile:324: recipe for target 'all-recursive' failed
> make[5]: *** [all-recursive] Error 1
> make[5]: Target 'all' not remade because of errors.
> make[5]: Leaving directory
> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/libm'
> make[5]: Nothing to be done for 'all-am'.
> Makefile:553: recipe for target 'all-recursive' failed
> make[4]: *** [all-recursive] Error 1
> make[4]: Target 'all' not remade because of errors.
> make[4]: Leaving directory
> Making all in doc
> make[4]: Entering directory
> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/doc'
> make[4]: Nothing to be done for 'all'.
> Making all in .
> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib'
> Makefile:641: recipe for target 'all-recursive' failed
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory
> Makefile:452: recipe for target 'all' failed
> make[2]: *** [all] Error 2
> make[2]: Leaving directory
> Makefile:8491: recipe for target 'all-target-newlib' failed
> make[1]: *** [all-target-newlib] Error 2
> make[1]: Target 'all-target' not remade because of errors.
> make[1]: Leaving directory
> '/home/eshan/development/newlib/c-arm-rtems5-newlib'
> Makefile:878: recipe for target 'all' failed
> make: *** [all] Error 2
> On Wed, May 20, 2020 at 4:44 AM Joel Sherrill <joel at rtems.org> wrote:
>> On Tue, May 19, 2020 at 5:20 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>> wrote:
>>> On Wed, May 20, 2020 at 3:43 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>>> wrote:
>>>> On Wed, May 20, 2020 at 2:25 AM Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Tue, May 19, 2020 at 3:52 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>>> wrote:
>>>>>> On Wed, May 20, 2020 at 1:55 AM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, May 20, 2020 at 1:42 AM Joel Sherrill <joel at rtems.org>
>>>>>>> wrote:
>>>>>>>> There shouldn't need to be an arm/fenv.c file after this is over if
>>>>>>>> I am thinking right. Each method will be split into its own file. I think
>>>>>>>> that's how the riscv is done.
>>>>>>> The files in sys/fenv are the one having inline assembly, But the
>>>>>>> methods in fenv.c have the files for soft float, and vpf.
>>>>>> could all the files be retailed under different #ifdef conditions
>>>>>> similar to that followed in FreeBSD
>>>>> Hmmm... maybe the methods in sys/fenv.h are redundant. If the bodies
>>>>> in fenv.c cover all the multilibs, then delete the static inlines.
>>>> This may be the case
>>>> but the files in Fenv.h are the once with the assembly code.
>>>> the files in fenv.c are calling functions from fenv-softfp.c and
>>>> fenv-vfp.c
>>>> which inturn call files for fenv.h and fenv-softfloat.h
>>>> If we remove the inline declaration of the functions from Fenv.h they
>>>> won't be able to get the definitions
>>>> and will cause errors.
>>> Warning the compiler generates:
>>> arm-rtems5-gcc
>>> -isystem
>>> ../../../../../../newlib-cygwin/newlib/libm/machine/arm/fenv-vfp.c:29:24:
>>> warning: inline function '__vfp_fegetexcept' declared but never defined
>>>  #define FENV_MANGLE(x) __vfp_ ##x
>> Hmm... trace the naming patch from the mangled declaration to a method.
>> You can drop into the build directory and run the gcc command by hand.
>> Tinker with it to add a -E and save the output (not -o...). That will let
>> you see the preprocessed output. Something specific and subtle is
>> happening. Decode that and you win.
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:52:21:
>>> note: in expansion of macro 'FENV_MANGLE'
>>>  #define fegetexcept FENV_MANGLE(fegetexcept)
>>> warning: inline function '__vfp_fedisableexcept' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:51:25:
>>>  #define fedisableexcept FENV_MANGLE(fedisableexcept)
>>> warning: inline function '__vfp_feenableexcept' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:50:24:
>>>  #define feenableexcept FENV_MANGLE(feenableexcept)
>>> warning: inline function '__vfp_feupdateenv' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:49:21:
>>>  #define feupdateenv FENV_MANGLE(feupdateenv)
>>> warning: inline function '__vfp_fesetenv' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:48:18:
>>>  #define fesetenv FENV_MANGLE(fesetenv)
>>> warning: inline function '__vfp_feholdexcept' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:47:22:
>>>  #define feholdexcept FENV_MANGLE(feholdexcept)
>>> warning: inline function '__vfp_fegetenv' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:46:18:
>>>  #define fegetenv FENV_MANGLE(fegetenv)
>>> warning: inline function '__vfp_fesetround' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:45:20:
>>>  #define fesetround FENV_MANGLE(fesetround)
>>> warning: inline function '__vfp_fegetround' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:44:20:
>>>  #define fegetround FENV_MANGLE(fegetround)
>>> warning: inline function '__vfp_fetestexcept' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:43:22:
>>>  #define fetestexcept FENV_MANGLE(fetestexcept)
>>> warning: inline function '__vfp_fesetexceptflag' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:41:25:
>>>  #define fesetexceptflag FENV_MANGLE(fesetexceptflag)
>>> warning: inline function '__vfp_feraiseexcept' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:42:23:
>>>  #define feraiseexcept FENV_MANGLE(feraiseexcept)
>>> warning: inline function '__vfp_fegetexceptflag' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:40:25:
>>>  #define fegetexceptflag FENV_MANGLE(fegetexceptflag)
>>> warning: inline function '__vfp_feclearexcept' declared but never defined
>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/newlib/targ-include/machine/fenv-mangle.h:39:23:
>>>  #define feclearexcept FENV_MANGLE(feclearexcept)
>>> arm-rtems5-gcc
>>> -isystem
>>> lib_a-fenv-softfp.o `test -f 'fenv-softfp.c' || echo
>>> '../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-softfp.c
>>> rm -f lib.a
>>> arm-rtems5-ar cru lib.a lib_a-e_sqrt.o lib_a-ef_sqrt.o lib_a-s_ceil.o
>>> lib_a-s_floor.o lib_a-s_nearbyint.o lib_a-s_rint.o lib_a-s_round.o
>>> lib_a-s_trunc.o lib_a-sf_ceil.o lib_a-sf_floor.o lib_a-sf_nearbyint.o
>>> lib_a-sf_rint.o lib_a-sf_round.o lib_a-sf_trunc.o lib_a-feclearexcept.o
>>> lib_a-fegetenv.o lib_a-fegetexceptflag.o lib_a-fegetround.o
>>> lib_a-feholdexcept.o lib_a-fenv.o lib_a-feraiseexcept.o lib_a-fesetenv.o
>>> lib_a-fesetexceptflag.o lib_a-fesetround.o lib_a-fetestexcept.o
>>> lib_a-feupdateenv.o lib_a-fenv-vfp.o lib_a-fenv-softfp.o
>>> arm-rtems5-ar: `u' modifier ignored since `D' is the default (see `U')
>>> arm-rtems5-ranlib lib.a
>>> Making all in .
>>> rm -f lib.a
>>> ln arm/lib.a lib.a >/dev/null 2>/dev/null || \
>>>  cp arm/lib.a lib.a
>>> rm -f libm.a
>>> rm -rf tmp
>>> mkdir tmp
>>> cd tmp; \
>>>   for i in math/lib.a common/lib.a complex/lib.a fenv/lib.a
>>> machine/lib.a; do \
>>>     arm-rtems5-ar x ../$i; \
>>> done; \
>>> arm-rtems5-ar rc ../libm.a *.o
>>> arm-rtems5-ranlib libm.a
>>> rm -rf tmp
>>> Making all in doc
>>> gcc -g -g -O2 -c ../../../../newlib-cygwin/newlib/doc/makedoc.c
>>> gcc -g -O2  -o makedoc makedoc.o
>>> Making all in .
>>> rm -f libm.a
>>> ln libm/libm.a libm.a >/dev/null 2>/dev/null || cp libm/libm.a libm.a
>>> rm -rf libc.a libg.a tmp
>>> mkdir tmp
>>> cd tmp; \
>>>  arm-rtems5-ar x ../libm.a lib_a-s_fpclassify.o lib_a-sf_fpclassify.o
>>> lib_a-s_isinf.o lib_a-sf_isinf.o lib_a-s_isnan.o lib_a-sf_isnan.o
>>> lib_a-s_isinfd.o lib_a-sf_isinff.o lib_a-s_isnand.o lib_a-sf_isnanf.o
>>> lib_a-s_nan.o lib_a-sf_nan.o lib_a-s_ldexp.o lib_a-sf_ldexp.o
>>> lib_a-s_frexp.o lib_a-sf_frexp.o lib_a-s_modf.o lib_a-sf_modf.o
>>> lib_a-s_scalbn.o lib_a-sf_scalbn.o lib_a-s_finite.o lib_a-sf_finite.o
>>> lib_a-s_copysign.o lib_a-sf_copysign.o ; \
>>>  arm-rtems5-ar x ../libc/libc.a ; \
>>>  arm-rtems5-ar rc ../libc.a *.o
>>> arm-rtems5-ranlib libc.a
>>> ln libc.a libg.a >/dev/null 2>/dev/null || cp libc.a libg.a
>>> rm -rf tmp
>>> rm -f crt0.o
>>> ln libc/crt0.o crt0.o >/dev/null 2>/dev/null || cp libc/crt0.o crt0.o
>>>>> --joel
>>>>>>>> --joel
>>>>>>>> On Tue, May 19, 2020 at 3:05 PM Eshan Dhawan <
>>>>>>>> eshandhawan51 at gmail.com> wrote:
>>>>>>>>> On Wed, May 20, 2020 at 12:47 AM Joel Sherrill <joel at rtems.org>
>>>>>>>>> wrote:
>>>>>>>>>> Crap! The default mode <sys/fenv.h> is working is turning the
>>>>>>>>>> methods into static inline which conflicts with the default implementation.
>>>>>>>>>> That's what is happening.
>>>>>>>>>> Cut the static inline bodies out of the arm sys/fenv.h and
>>>>>>>>>> distribute them to libm/arm/XXX.c based on their method name. Drop
>>>>>>>>>> __fenv_static completely.
>>>>>>>>> What will happen to the fenv methods in the fenv.c file
>>>>>>>>>> Make the new split out feXXX.c files FreeBSD copyright. You
>>>>>>>>>> should add a note that you adapted them from their sys/fenv.h with static
>>>>>>>>>> inline to have the bodies in separate files. Make the same type of note in
>>>>>>>>>> the arm sys/fenv.h.
>>>>>>>>>> Sorry to beat the copyright/credit thing but it is important to
>>>>>>>>>> note that the meat of the code came from FreeBSD and you split it into
>>>>>>>>>> files.
>>>>>>>>>> --joel
>>>>>>>>>> On Tue, May 19, 2020 at 1:48 PM Eshan Dhawan <
>>>>>>>>>>> Hello
>>>>>>>>>>> I have encountered a new error
>>>>>>>>>>> the error is coming from libm/fenv
>>>>>>>>>>> link to GitHub repository:
>>>>>>>>>>> https://github.com/eshandhawan51/newlib-cygwin/tree/add_fenv_support
>>>>>>>>>>> Make file log:
>>>>>>>>>>> eshan at EDs-pc:~/development/newlib/c-arm-rtems5-newlib$ make -k
>>>>>>>>>>> make[1]: Entering directory
>>>>>>>>>>> make[2]: Entering directory
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/etc'
>>>>>>>>>>> make[2]: Nothing to be done for 'all'.
>>>>>>>>>>> Checking multilib configuration for newlib...
>>>>>>>>>>> make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2"
>>>>>>>>>>> "CCASFLAGS=-g -O2" "CFLAGS_FOR_BUILD=-g -O2" "CFLAGS_FOR_TARGET=-g -O2"
>>>>>>>>>>> "INSTALL=/usr/bin/install -c" "LDFLAGS=" "LIBCFLAGS=-g -O2"
>>>>>>>>>>> "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make" "MAKEINFO=makeinfo
>>>>>>>>>>> --split-size=5000000 --split-size=5000000 " "PICFLAG="
>>>>>>>>>>> "PICFLAG_FOR_TARGET=" "SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest"
>>>>>>>>>>> "RUNTESTFLAGS=" "exec_prefix=/usr/local" "infodir=/usr/local/share/info"
>>>>>>>>>>> "libdir=/usr/local/lib" "prefix=/usr/local" "tooldir=/usr/local/arm-rtems5"
>>>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib" "AR=arm-rtems5-ar"
>>>>>>>>>>> "AS=arm-rtems5-as" "CC=arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> " "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2" "NM=arm-rtems5-nm" "PICFLAG="
>>>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" all-recursive
>>>>>>>>>>> make[3]: Entering directory
>>>>>>>>>>> -isystem
>>>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" DO=all multi-do # make
>>>>>>>>>>> if [ -z "thumb vfp/hard thumb/armv6-m thumb/armv7-a
>>>>>>>>>>> thumb/armv7-r thumb/cortex-m3 thumb/cortex-m4 thumb/armv7-a/neon/hard
>>>>>>>>>>> thumb/armv7-r/vfpv3-d16/hard thumb/cortex-m4/fpv4-sp-d16/hard
>>>>>>>>>>> thumb/cortex-m7/fpv5-d16/hard eb/thumb/armv7-r
>>>>>>>>>>> eb/thumb/armv7-r/vfpv3-d16/hard" ]; then \
>>>>>>>>>>>   true; \
>>>>>>>>>>> else \
>>>>>>>>>>>   rootpre=`${PWDCMD-pwd}`/; export rootpre; \
>>>>>>>>>>>   srcrootpre=`cd ../../../newlib-cygwin/newlib; ${PWDCMD-pwd}`/;
>>>>>>>>>>> export srcrootpre; \
>>>>>>>>>>>   lib=`echo "${rootpre}" | sed -e 's,^.*/\([^/][^/]*\)/$,\1,'`; \
>>>>>>>>>>>   compiler="arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>>   for i in `${compiler} --print-multi-lib 2>/dev/null`; do \
>>>>>>>>>>>     dir=`echo $i | sed -e 's/;.*$//'`; \
>>>>>>>>>>>     if [ "${dir}" = "." ]; then \
>>>>>>>>>>>       true; \
>>>>>>>>>>>     else \
>>>>>>>>>>>       if [ -d ../${dir}/${lib} ]; then \
>>>>>>>>>>> flags=`echo $i | sed -e 's/^[^;]*;//' -e 's/@/ -/g'`; \
>>>>>>>>>>> if (cd ../${dir}/${lib}; make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc"
>>>>>>>>>>> "CFLAGS=-g -O2" "CCASFLAGS=-g -O2" "CFLAGS_FOR_BUILD=-g -O2"
>>>>>>>>>>> "CFLAGS_FOR_TARGET=-g -O2" "INSTALL=/usr/bin/install -c" "LDFLAGS="
>>>>>>>>>>> "LIBCFLAGS=-g -O2" "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make"
>>>>>>>>>>> "MAKEINFO=makeinfo --split-size=5000000 --split-size=5000000   " "PICFLAG="
>>>>>>>>>>> -isystem
>>>>>>>>>>> "RANLIB=arm-rtems5-ranlib" "DESTDIR=" \
>>>>>>>>>>> CFLAGS="-g -O2 ${flags}" \
>>>>>>>>>>> CCASFLAGS="-g -O2 ${flags}" \
>>>>>>>>>>> FCFLAGS=" ${flags}" \
>>>>>>>>>>> FFLAGS=" ${flags}" \
>>>>>>>>>>> ADAFLAGS=" ${flags}" \
>>>>>>>>>>> prefix="/usr/local" \
>>>>>>>>>>> exec_prefix="/usr/local" \
>>>>>>>>>>> GCJFLAGS=" ${flags}" \
>>>>>>>>>>> GOCFLAGS="-O2 -g ${flags}" \
>>>>>>>>>>> CXXFLAGS="-g -O2 ${flags}" \
>>>>>>>>>>> LIBCFLAGS="-g -O2 ${flags}" \
>>>>>>>>>>> LIBCXXFLAGS="-g -O2 -fno-implicit-templates ${flags}" \
>>>>>>>>>>> LDFLAGS=" ${flags}" \
>>>>>>>>>>> MULTIFLAGS="${flags}" \
>>>>>>>>>>> DESTDIR="" \
>>>>>>>>>>> INSTALL="/usr/bin/install -c" \
>>>>>>>>>>> INSTALL_DATA="/usr/bin/install -c -m 644" \
>>>>>>>>>>> INSTALL_PROGRAM="/usr/bin/install -c" \
>>>>>>>>>>> INSTALL_SCRIPT="/usr/bin/install -c" \
>>>>>>>>>>> all); then \
>>>>>>>>>>>  true; \
>>>>>>>>>>> else \
>>>>>>>>>>>  exit 1; \
>>>>>>>>>>> fi; \
>>>>>>>>>>>       else true; \
>>>>>>>>>>>       fi; \
>>>>>>>>>>>     fi; \
>>>>>>>>>>>   done; \
>>>>>>>>>>> fi
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib'
>>>>>>>>>>> make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mthumb"
>>>>>>>>>>> "CCASFLAGS=-g -O2  -mthumb" "CFLAGS_FOR_BUILD=-g -O2" "CFLAGS_FOR_TARGET=-g
>>>>>>>>>>> -O2" "INSTALL=/usr/bin/install -c" "LDFLAGS=-mthumb" "LIBCFLAGS=-g -O2
>>>>>>>>>>>  -mthumb" "LIBCFLAGS_FOR_TARGET=-g -O2" "MAKE=make" "MAKEINFO=makeinfo
>>>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib/thumb" "AR=arm-rtems5-ar"
>>>>>>>>>>> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/
>>>>>>>>>>> -isystem
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include
>>>>>>>>>>>  -mthumb" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2  -mthumb" "NM=arm-rtems5-nm"
>>>>>>>>>>> "PICFLAG=" "RANLIB=arm-rtems5-ranlib" "DESTDIR=" all-recursive
>>>>>>>>>>> true "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mthumb"
>>>>>>>>>>> -isystem
>>>>>>>>>>> "PICFLAG=" "RANLIB=arm-rtems5-ranlib" "DESTDIR=" DO=all multi-do # make
>>>>>>>>>>> Making all in libc
>>>>>>>>>>> make[7]: Entering directory
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc'
>>>>>>>>>>> Making all in argz
>>>>>>>>>>> make[8]: Entering directory
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/argz'
>>>>>>>>>>> make[8]: Nothing to be done for 'all'.
>>>>>>>>>>> make[8]: Leaving directory
>>>>>>>>>>> Making all in stdlib
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/stdlib'
>>>>>>>>>>> Making all in ctype
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/ctype'
>>>>>>>>>>> Making all in search
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/search'
>>>>>>>>>>> Making all in stdio
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/stdio'
>>>>>>>>>>> Making all in string
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/string'
>>>>>>>>>>> Making all in signal
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/signal'
>>>>>>>>>>> Making all in time
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/time'
>>>>>>>>>>> Making all in locale
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/locale'
>>>>>>>>>>> Making all in sys
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/sys'
>>>>>>>>>>> Making all in rtems
>>>>>>>>>>> make[9]: Entering directory
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/sys/rtems'
>>>>>>>>>>> make[9]: Nothing to be done for 'all'.
>>>>>>>>>>> make[9]: Leaving directory
>>>>>>>>>>> Making all in .
>>>>>>>>>>> make[9]: Nothing to be done for 'all-am'.
>>>>>>>>>>> Making all in reent
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/reent'
>>>>>>>>>>> Making all in errno
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/errno'
>>>>>>>>>>> Making all in misc
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/misc'
>>>>>>>>>>> Making all in machine
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/machine'
>>>>>>>>>>> Making all in arm
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/machine/arm'
>>>>>>>>>>> Making all in .
>>>>>>>>>>> Making all in unix
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/unix'
>>>>>>>>>>> Making all in posix
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/posix'
>>>>>>>>>>> Making all in ssp
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libc/ssp'
>>>>>>>>>>> Making all in .
>>>>>>>>>>> make[8]: Nothing to be done for 'all-am'.
>>>>>>>>>>> make[7]: Leaving directory
>>>>>>>>>>> Making all in libm
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm'
>>>>>>>>>>> Making all in math
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/math'
>>>>>>>>>>> Making all in common
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/common'
>>>>>>>>>>> Making all in complex
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/complex'
>>>>>>>>>>> Making all in fenv
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/fenv'
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine'
>>>>>>>>>>> Making all in arm
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/libm/machine/arm'
>>>>>>>>>>> Making all in .
>>>>>>>>>>> Making all in .
>>>>>>>>>>> rm -f thumb/crt0.o
>>>>>>>>>>> ln libc/crt0.o thumb/crt0.o >/dev/null 2>/dev/null || cp
>>>>>>>>>>> rm -f thumb/libc.a ./thumb/libg.a
>>>>>>>>>>> ln libc.a thumb/libc.a >/dev/null 2>/dev/null || cp libc.a
>>>>>>>>>>> thumb/libc.a
>>>>>>>>>>> ln libg.a ./thumb/libg.a >/dev/null 2>/dev/null || \
>>>>>>>>>>> cp libg.a ./thumb/libg.a
>>>>>>>>>>> rm -f thumb/libm.a
>>>>>>>>>>> ln libm.a thumb/libm.a >/dev/null 2>/dev/null || cp libm.a
>>>>>>>>>>> thumb/libm.a
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib'
>>>>>>>>>>> make "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mfpu=vfp
>>>>>>>>>>> -mfloat-abi=hard" "CCASFLAGS=-g -O2  -mfpu=vfp -mfloat-abi=hard"
>>>>>>>>>>> "INSTALL=/usr/bin/install -c" "LDFLAGS=-mfpu=vfp -mfloat-abi=hard"
>>>>>>>>>>> "LIBCFLAGS=-g -O2  -mfpu=vfp -mfloat-abi=hard" "LIBCFLAGS_FOR_TARGET=-g
>>>>>>>>>>> -O2" "MAKE=make" "MAKEINFO=makeinfo --split-size=5000000
>>>>>>>>>>> --split-size=5000000    " "PICFLAG=" "PICFLAG_FOR_TARGET="
>>>>>>>>>>> "SHELL=/bin/bash" "EXPECT=expect" "RUNTEST=runtest" "RUNTESTFLAGS="
>>>>>>>>>>> "top_toollibdir=/usr/local/arm-rtems5/lib/vfp/hard" "AR=arm-rtems5-ar"
>>>>>>>>>>> -B/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/
>>>>>>>>>>> -isystem
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include
>>>>>>>>>>>  -mfpu=vfp -mfloat-abi=hard" "LD=arm-rtems5-ld" "LIBCFLAGS=-g -O2
>>>>>>>>>>>  -mfpu=vfp -mfloat-abi=hard" "NM=arm-rtems5-nm" "PICFLAG="
>>>>>>>>>>> true "AR_FLAGS=rc" "CC_FOR_BUILD=gcc" "CFLAGS=-g -O2  -mfpu=vfp
>>>>>>>>>>> -isystem
>>>>>>>>>>> Making all in libc
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc'
>>>>>>>>>>> Making all in argz
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/argz'
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/stdlib'
>>>>>>>>>>> Making all in ctype
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/ctype'
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/search'
>>>>>>>>>>> Making all in stdio
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/stdio'
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/string'
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/signal'
>>>>>>>>>>> Making all in time
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/time'
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/locale'
>>>>>>>>>>> Making all in sys
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/sys'
>>>>>>>>>>> Making all in rtems
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/sys/rtems'
>>>>>>>>>>> Making all in .
>>>>>>>>>>> Making all in reent
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/reent'
>>>>>>>>>>> Making all in errno
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/errno'
>>>>>>>>>>> Making all in misc
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/misc'
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/machine'
>>>>>>>>>>> Making all in arm
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/machine/arm'
>>>>>>>>>>> Making all in .
>>>>>>>>>>> Making all in unix
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/unix'
>>>>>>>>>>> Making all in posix
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/posix'
>>>>>>>>>>> Making all in ssp
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libc/ssp'
>>>>>>>>>>> Making all in .
>>>>>>>>>>> Making all in libm
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm'
>>>>>>>>>>> Making all in math
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/math'
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/common'
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/complex'
>>>>>>>>>>> Making all in fenv
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/fenv'
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>>  -mfpu=vfp -mfloat-abi=hard -DPACKAGE_NAME=\"newlib\"
>>>>>>>>>>> -DPACKAGE_TARNAME=\"newlib\" -DPACKAGE_VERSION=\"3.3.0\"
>>>>>>>>>>> -DPACKAGE_STRING=\"newlib\ 3.3.0\" -DPACKAGE_BUGREPORT=\"\"
>>>>>>>>>>> -I../../../../../../../newlib-cygwin/newlib/libm/fenv -fno-builtin
>>>>>>>>>>> -ffunction-sections -fdata-sections  -D_COMPILING_NEWLIB -DCLOCK_PROVIDED
>>>>>>>>>>> -DMALLOC_PROVIDED -DEXIT_PROVIDED -DSIGNAL_PROVIDED -DGETREENT_PROVIDED
>>>>>>>>>>> -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL
>>>>>>>>>>> -DHAVE_ASSERT_FUNC -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS
>>>>>>>>>>> -D_NO_SIGSET -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI
>>>>>>>>>>>   -fbuiltin -fno-math-errno  -g -O2  -mfpu=vfp -mfloat-abi=hard -c -o
>>>>>>>>>>> lib_a-feclearexcept.o `test -f 'feclearexcept.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feclearexcept.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:64:5:
>>>>>>>>>>> error: redefinition of 'feclearexcept'
>>>>>>>>>>>  int feclearexcept(int excepts)
>>>>>>>>>>> In file included from
>>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:15:0,
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:126:1:
>>>>>>>>>>> note: previous definition of 'feclearexcept' was here
>>>>>>>>>>> Makefile:347: recipe for target 'lib_a-feclearexcept.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-feclearexcept.o] Error 1
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> lib_a-fegetenv.o `test -f 'fegetenv.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetenv.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetenv.c:64:5:
>>>>>>>>>>> error: redefinition of 'fegetenv'
>>>>>>>>>>>  int fegetenv(fenv_t *envp)
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetenv.c:29:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:198:1:
>>>>>>>>>>> note: previous definition of 'fegetenv' was here
>>>>>>>>>>> Makefile:359: recipe for target 'lib_a-fegetenv.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-fegetenv.o] Error 1
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> lib_a-fegetexceptflag.o `test -f 'fegetexceptflag.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetexceptflag.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetexceptflag.c:65:5:
>>>>>>>>>>> error: redefinition of 'fegetexceptflag'
>>>>>>>>>>>  int fegetexceptflag(fexcept_t *flagp, int excepts)
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetexceptflag.c:29:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:137:1:
>>>>>>>>>>> note: previous definition of 'fegetexceptflag' was here
>>>>>>>>>>> Makefile:365: recipe for target 'lib_a-fegetexceptflag.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-fegetexceptflag.o] Error 1
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> lib_a-fegetround.o `test -f 'fegetround.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fegetround.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetround.c:63:5:
>>>>>>>>>>> error: redefinition of 'fegetround'
>>>>>>>>>>>  int fegetround(void)
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fegetround.c:29:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:177:1:
>>>>>>>>>>> note: previous definition of 'fegetround' was here
>>>>>>>>>>>  fegetround(void)
>>>>>>>>>>> Makefile:371: recipe for target 'lib_a-fegetround.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-fegetround.o] Error 1
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> lib_a-feholdexcept.o `test -f 'feholdexcept.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feholdexcept.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feholdexcept.c:67:5:
>>>>>>>>>>> error: redefinition of 'feholdexcept'
>>>>>>>>>>>  int feholdexcept(fenv_t *envp)
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feholdexcept.c:29:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:206:1:
>>>>>>>>>>> note: previous definition of 'feholdexcept' was here
>>>>>>>>>>> Makefile:377: recipe for target 'lib_a-feholdexcept.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-feholdexcept.o] Error 1
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> lib_a-feraiseexcept.o `test -f 'feraiseexcept.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feraiseexcept.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feraiseexcept.c:64:5:
>>>>>>>>>>> error: redefinition of 'feraiseexcept'
>>>>>>>>>>>  int feraiseexcept(int excepts)
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feraiseexcept.c:29:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:159:1:
>>>>>>>>>>> note: previous definition of 'feraiseexcept' was here
>>>>>>>>>>> Makefile:383: recipe for target 'lib_a-feraiseexcept.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-feraiseexcept.o] Error 1
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> lib_a-fesetenv.o `test -f 'fesetenv.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetenv.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetenv.c:69:5:
>>>>>>>>>>> error: redefinition of 'fesetenv'
>>>>>>>>>>>  int fesetenv(const fenv_t *envp)
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetenv.c:29:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:218:1:
>>>>>>>>>>> note: previous definition of 'fesetenv' was here
>>>>>>>>>>> Makefile:389: recipe for target 'lib_a-fesetenv.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-fesetenv.o] Error 1
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> lib_a-fesetexceptflag.o `test -f 'fesetexceptflag.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetexceptflag.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetexceptflag.c:70:5:
>>>>>>>>>>> error: redefinition of 'fesetexceptflag'
>>>>>>>>>>>  int fesetexceptflag(const fexcept_t *flagp, int excepts)
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetexceptflag.c:29:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:147:1:
>>>>>>>>>>> note: previous definition of 'fesetexceptflag' was here
>>>>>>>>>>> Makefile:395: recipe for target 'lib_a-fesetexceptflag.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-fesetexceptflag.o] Error 1
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> lib_a-fesetround.o `test -f 'fesetround.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fesetround.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetround.c:64:5:
>>>>>>>>>>> error: redefinition of 'fesetround'
>>>>>>>>>>>  int fesetround(int round)
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fesetround.c:29:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:186:1:
>>>>>>>>>>> note: previous definition of 'fesetround' was here
>>>>>>>>>>> Makefile:401: recipe for target 'lib_a-fesetround.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-fesetround.o] Error 1
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> lib_a-fetestexcept.o `test -f 'fetestexcept.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`fetestexcept.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fetestexcept.c:65:5:
>>>>>>>>>>> error: redefinition of 'fetestexcept'
>>>>>>>>>>>  int fetestexcept(int excepts)
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/fetestexcept.c:30:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:168:1:
>>>>>>>>>>> note: previous definition of 'fetestexcept' was here
>>>>>>>>>>> Makefile:407: recipe for target 'lib_a-fetestexcept.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-fetestexcept.o] Error 1
>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>> -isystem
>>>>>>>>>>> lib_a-feupdateenv.o `test -f 'feupdateenv.c' || echo
>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/fenv/'`feupdateenv.c
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feupdateenv.c:69:5:
>>>>>>>>>>> error: redefinition of 'feupdateenv'
>>>>>>>>>>>  int feupdateenv(const fenv_t *envp)
>>>>>>>>>>>                  from
>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/fenv/feupdateenv.c:29:
>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/targ-include/sys/fenv.h:226:1:
>>>>>>>>>>> note: previous definition of 'feupdateenv' was here
>>>>>>>>>>> Makefile:413: recipe for target 'lib_a-feupdateenv.o' failed
>>>>>>>>>>> make[8]: *** [lib_a-feupdateenv.o] Error 1
>>>>>>>>>>> make[8]: Target 'all' not remade because of errors.
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/machine'
>>>>>>>>>>> Making all in arm
>>>>>>>>>>> '/home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/vfp/hard/newlib/libm/machine/arm'
>>>>>>>>>>> Making all in .
>>>>>>>>>>> rm -f libm.a
>>>>>>>>>>> rm -rf tmp
>>>>>>>>>>> mkdir tmp
>>>>>>>>>>> cd tmp; \
>>>>>>>>>>> machine/lib.a; do \
>>>>>>>>>>> done; \
>>>>>>>>>>> arm-rtems5-ar: ../fenv/lib.a: No such file or directory
>>>>>>>>>>> rm -rf tmp
>>>>>>>>>>> make[7]: *** [all-recursive] Error 1
>>>>>>>>>>> make[7]: Target 'all' not remade because of errors.
>>>>>>>>>>> Making all in .
>>>>>>>>>>> rm -f libm.a
>>>>>>>>>>> libm.a
>>>>>>>>>>> mkdir tmp
>>>>>>>>>>> cd tmp; \
>>>>>>>>>>> lib_a-sf_fpclassify.o lib_a-s_isinf.o lib_a-sf_isinf.o lib_a-s_isnan.o
>>>>>>>>>>> lib_a-sf_isnan.o lib_a-s_isinfd.o lib_a-sf_isinff.o lib_a-s_isnand.o
>>>>>>>>>>> lib_a-sf_isnanf.o lib_a-s_nan.o lib_a-sf_nan.o lib_a-s_ldexp.o
>>>>>>>>>>> lib_a-sf_ldexp.o lib_a-s_frexp.o lib_a-sf_frexp.o lib_a-s_modf.o
>>>>>>>>>>> lib_a-sf_modf.o lib_a-s_scalbn.o lib_a-sf_scalbn.o lib_a-s_finite.o
>>>>>>>>>>> lib_a-sf_finite.o lib_a-s_copysign.o lib_a-sf_copysign.o ; \
>>>>>>>>>>> rm -rf tmp
>>>>>>>>>>> rm -f vfp/hard/crt0.o
>>>>>>>>>>> ln libc/crt0.o vfp/hard/crt0.o >/dev/null 2>/dev/null || cp
>>>>>>>>>>> rm -f vfp/hard/libc.a ./vfp/hard/libg.a
>>>>>>>>>>> ln libc.a vfp/hard/libc.a >/dev/null 2>/dev/null || cp libc.a
>>>>>>>>>>> vfp/hard/libc.a
>>>>>>>>>>> ln libg.a ./vfp/hard/libg.a >/dev/null 2>/dev/null || \
>>>>>>>>>>> cp libg.a ./vfp/hard/libg.a
>>>>>>>>>>> rm -f vfp/hard/libm.a
>>>>>>>>>>> ln libm.a vfp/hard/libm.a >/dev/null 2>/dev/null || cp libm.a
>>>>>>>>>>> vfp/hard/libm.a
>>>>>>>>>>> make[6]: *** [all-recursive] Error 1
>>>>>>>>>>> make[5]: *** [all] Error 2
>>>>>>>>>>> Makefile:1260: recipe for target 'multi-do' failed
>>>>>>>>>>> make[4]: *** [multi-do] Error 1
>>>>>>>>>>> Makefile:1176: recipe for target 'all-multi' failed
>>>>>>>>>>> make[3]: *** [all-multi] Error 2
>>>>>>>>>>> make[3]: Target 'all-recursive' not remade because of errors.
>>>>>>>>>>> Thanks
>>>>>>>>>>> -Eshan :)
>>>>>>>>>>> On Sat, May 16, 2020 at 8:09 PM Joel Sherrill <joel at rtems.org>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> On Fri, May 15, 2020, 5:59 PM Eshan Dhawan <
>>>>>>>>>>>>> On Fri, May 15, 2020 at 2:22 AM Eshan Dhawan <
>>>>>>>>>>>>>> On Wed, May 13, 2020 at 7:40 PM Joel Sherrill <joel at rtems.org>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>> National free hint day!!!
>>>>>>>>>>>>>>> Look above the line that is reported. You will see
>>>>>>>>>>>>>>> __BEGIN_DECL. It isn't defined. It is intended to expand to the __cplusplus
>>>>>>>>>>>>>>> wrapper.
>>>>>>>>>>>>>>> After you fix this, you will sequentially find 2 other
>>>>>>>>>>>>>>> things to change in this file.
>>>>>>>>>>>>>>> I have made those changes when a new error occurs from the
>>>>>>>>>>>>>> assembler in arm thumb mode
>>>>>>>>>>>>>> There is no support for vfp instructions in arm thumb.
>>>>>>>>>>>>>> http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html
>>>>>>>>>>>>>> So in which file will the compiler instructions given in the
>>>>>>>>>>>>>> page
>>>>>>>>>>>>>> <http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0471c/BABGHDBB.html>
>>>>>>>>>>>>>> added?
>>>>>>>>>>>>> FreeBSD has added file and architecture-specific flags in
>>>>>>>>>>>>> their makefile.inc
>>>>>>>>>>>>> https://github.com/freebsd/freebsd/blob/master/lib/msun/arm/Makefile.inc
>>>>>>>>>>>>> How will it be added in newlib
>>>>>>>>>>>>> I tried adding the flags -mfpu=vfp -mfloat-abi=softfp (used in
>>>>>>>>>>>>> FreeBSD) to makefile.in but no effect.
>>>>>>>>>>>> This isn't going to work with newlib. They don't specify CPU
>>>>>>>>>>>> flags that way.
>>>>>>>>>>>> The fenv code is going to have to compile for every multilib
>>>>>>>>>>>> variant built by arm-rtems and arm-eabi. You will have to use conditionals
>>>>>>>>>>>> based on the flags gcc uses to indicate the various cpu features. This
>>>>>>>>>>>> command should be close to how you you dump them.
>>>>>>>>>>>> gcc -dM -E - </dev/null
>>>>>>>>>>>> Add a CPU flag and see how the setting change.
>>>>>>>>>>>> You can also look in rtems score cpu arm for examples since the
>>>>>>>>>>>> core arm code will be dealing with these.
>>>>>>>>>>>> --joel
>>>>>>>>>>>>> thanks
>>>>>>>>>>>>> -Eshan
>>>>>>>>>>>>>> Errors :
>>>>>>>>>>>>>> arm-rtems5-gcc
>>>>>>>>>>>>>> -isystem
>>>>>>>>>>>>>>  -mthumb -DPACKAGE_NAME=\"newlib\" -DPACKAGE_TARNAME=\"newlib\"
>>>>>>>>>>>>>> -I../../../../../../../newlib-cygwin/newlib/libm/machine/arm -I
>>>>>>>>>>>>>> ../../../../../../../newlib-cygwin/newlib/libm/machine/arm/../../../../newlib/libm/common
>>>>>>>>>>>>>> -fno-builtin -mfpu=vfpv2 -ffunction-sections -fdata-sections
>>>>>>>>>>>>>>  -D_COMPILING_NEWLIB -DCLOCK_PROVIDED -DMALLOC_PROVIDED -DEXIT_PROVIDED
>>>>>>>>>>>>>> -DSIGNAL_PROVIDED -DGETREENT_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED
>>>>>>>>>>>>>> -DHAVE_NANOSLEEP -DHAVE_BLKSIZE -DHAVE_FCNTL -DHAVE_ASSERT_FUNC
>>>>>>>>>>>>>> -D_NO_GETLOGIN -D_NO_GETPWENT -D_NO_GETUT -D_NO_GETPASS -D_NO_SIGSET
>>>>>>>>>>>>>> -D_NO_WORDEXP -D_NO_POPEN -D_NO_POSIX_SPAWN -DHAVE_INIT_FINI      -g -O2
>>>>>>>>>>>>>>  -mthumb -c -o lib_a-fenv-vfp.o `test -f 'fenv-vfp.c' || echo
>>>>>>>>>>>>>> '../../../../../../../newlib-cygwin/newlib/libm/machine/arm/'`fenv-vfp.c
>>>>>>>>>>>>>> /tmp/ccEHiFws.s: Assembler messages:
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:37: Error: selected processor does not
>>>>>>>>>>>>>> support `vmrs r3,fpscr' in Thumb mode
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:48: Error: selected processor does not
>>>>>>>>>>>>>> support `vmsr fpscr,r3' in Thumb mode
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:81: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:119: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:134: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:169: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:182: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:217: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:251: Error: selected processor does not
>>>>>>>>>>>>>> support `vmrs r0,fpscr' in Thumb mode
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:288: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:303: Error: selected processor does not
>>>>>>>>>>>>>> support `vmsr fpscr,r0' in Thumb mode
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:340: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:374: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:390: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:424: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:457: Error: selected processor does not
>>>>>>>>>>>>>> support `vmrs r1,fpscr' in Thumb mode
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:466: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:478: Error: selected processor does not
>>>>>>>>>>>>>> support `vmrs r2,fpscr' in Thumb mode
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:503: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:543: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:559: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:595: Error: selected processor does not
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:612: Error: selected processor does not
>>>>>>>>>>>>>> support `vmsr fpscr,r2' in Thumb mode
>>>>>>>>>>>>>> /tmp/ccEHiFws.s:647: Error: selected processor does not
>>>>>>>>>>>>>> make[9]: *** [lib_a-fenv-vfp.o] Error 1
>>>>>>>>>>>>>> make[8]: *** [all-recursive] Error 1
>>>>>>>>>>>>>> -Eshan
>>>>>>>>>>>>>>> Then we need to make a decision whether the static inline
>>>>>>>>>>>>>>> versions of the methods in sys/fenv.h are appropriate for newlib or not.
>>>>>>>>>>>>>>> --joel
>>>>>>>>>>>>>>> On Tue, May 12, 2020 at 5:20 PM Joel Sherrill <
>>>>>>>>>>>>>>>> Gedare is right but one more piece of information is
>>>>>>>>>>>>>>>> needed. When newlib is being built, it lays target dependent files on top
>>>>>>>>>>>>>>>> of generic ones. So the default sys/fenv.h is replaced with something like
>>>>>>>>>>>>>>>> libc/machine/arm/sys/fenv.h. Make sure that
>>>>>>>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h is
>>>>>>>>>>>>>>>> in fact the file you think it should be.
>>>>>>>>>>>>>>>> Also look at what is supposed to be in the generic fenv.h
>>>>>>>>>>>>>>>> and <sys/fenv.h>. You will probably have to tweak it some.
>>>>>>>>>>>>>>>> Check out what is in x86_64/fenv.h and riscv/fenv.h with
>>>>>>>>>>>>>>>> respect to the default environment variable. It looks to be declared
>>>>>>>>>>>>>>>> differently in the other ports so you may have to make it match.
>>>>>>>>>>>>>>>> But more output does help.
>>>>>>>>>>>>>>>> --joel
>>>>>>>>>>>>>>>> On Tue, May 12, 2020 at 4:53 PM Gedare Bloom <
>>>>>>>>>>>>>>>> gedare at rtems.org> wrote:
>>>>>>>>>>>>>>>>> Take the first error reported, and show what is being
>>>>>>>>>>>>>>>>> compiled. You've
>>>>>>>>>>>>>>>>> trimmed off too much preceding this to know what is being
>>>>>>>>>>>>>>>>> compiled and
>>>>>>>>>>>>>>>>> how this might be influencing your error.
>>>>>>>>>>>>>>>>> The specific error you're getting is often due to some
>>>>>>>>>>>>>>>>> syntax errors
>>>>>>>>>>>>>>>>> preceding the line shown.
>>>>>>>>>>>>>>>>> On Tue, May 12, 2020 at 2:59 PM Eshan Dhawan <
>>>>>>>>>>>>>>>>> > Hello everyone,
>>>>>>>>>>>>>>>>> > After adding the files and compiling. I am
>>>>>>>>>>>>>>>>> > getting a few errors which I am not able to rectify.
>>>>>>>>>>>>>>>>> > If you could take a look and tell how to sort them.
>>>>>>>>>>>>>>>>> > link to newlib's git repo:
>>>>>>>>>>>>>>>>> > errors :
>>>>>>>>>>>>>>>>> >                  from
>>>>>>>>>>>>>>>>> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include/sys/fenv.h:82:1:
>>>>>>>>>>>>>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'extern'
>>>>>>>>>>>>>>>>> >  extern const fenv_t *_fe_dfl_env;
>>>>>>>>>>>>>>>>> ../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:0:
>>>>>>>>>>>>>>>>> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:22:1:
>>>>>>>>>>>>>>>>> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'int'
>>>>>>>>>>>>>>>>> >  int feclearexcept(int excepts);
>>>>>>>>>>>>>>>>> > thanks
>>>>>>>>>>>>>>>>> > -Eshan
>>>>>>>>>>>>>>>>> > On Sat, May 9, 2020 at 2:53 AM Joel Sherrill <
>>>>>>>>>>>>>>>>> >> On Thu, May 7, 2020 at 1:33 PM Eshan Dhawan <
>>>>>>>>>>>>>>>>> >>> Hello everyone,
>>>>>>>>>>>>>>>>> >>> This the tread to discuss adding fenv support for ARM
>>>>>>>>>>>>>>>>> architecture in newlib.
>>>>>>>>>>>>>>>>> >>> Link to previous thread:
>>>>>>>>>>>>>>>>> https://lists.rtems.org/pipermail/devel/2020-March/058473.html
>>>>>>>>>>>>>>>>> >>> ---FreeBSD Source
>>>>>>>>>>>>>>>>> https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
>>>>>>>>>>>>>>>>> https://github.com/freebsd/freebsd/blob/master/sys/arm/include/ieeefp.h
>>>>>>>>>>>>>>>>> >>> ---NetBSD Source
>>>>>>>>>>>>>>>>> https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
>>>>>>>>>>>>>>>>> >>> --- Musl has no implementation for fenv support for
>>>>>>>>>>>>>>>>> ARM  in it
>>>>>>>>>>>>>>>>> >>> After going through the implementations both FreeBSD
>>>>>>>>>>>>>>>>> and NetBSD have a stub implementation.
>>>>>>>>>>>>>>>>> >>> But then FreeBSD implementation seems to be more
>>>>>>>>>>>>>>>>> portable compared to that in NetBSD.
>>>>>>>>>>>>>>>>> >>> Should I start porting it from FreeBSD?
>>>>>>>>>>>>>>>>> >>> And which ARM BSP should I use for testing the changes?
>>>>>>>>>>>>>>>>> >>> Currently, I have xilinx_zynq_a9_qemu build
>>>>>>>>>>>>>>>>> >> I think the FreeBSD implementation is the one to use.
>>>>>>>>>>>>>>>>> It looks to support hard and soft floating point implementations.
>>>>>>>>>>>>>>>>> >> I think the fenv.h file there will have to be worked on
>>>>>>>>>>>>>>>>> so some of the contents go into sys or machine/fenv.h. There is a portable
>>>>>>>>>>>>>>>>> fenv.h.
>>>>>>>>>>>>>>>>> >>> There would also be a requirement to discuss where to
>>>>>>>>>>>>>>>>> place the files in Newlib.
>>>>>>>>>>>>>>>>> >> Not much to discuss. It should go into
>>>>>>>>>>>>>>>>> newlib-cygwin/newlib/libm/machine/arm.
>>>>>>>>>>>>>>>>> >>> Thanks
>>>>>>>>>>>>>>>>> >>> -Eshan
>>>>>>>>>>>>>>>>> > _______________________________________________
>>>>>>>>>>>>>>>>> > devel mailing list
>>>>>>>>>>>>>>>>> > devel at rtems.org
>>>>>>>>>>>>>>>>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200520/80a5cc72/attachment-0001.html>
