[rtems/rsb]: Adding PTP support to RSB [GSoC 2020]
Vijay Kumar Banerjee
vijay at rtems.org
Fri May 22 19:27:32 UTC 2020
On Sat, May 23, 2020, 12:26 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> On Thu, May 21, 2020 at 1:07 AM Mritunjay Sharma <
>> On Wed, May 20, 2020 at 1:46 AM Vijay Kumar Banerjee <vijay at rtems.org>
>> wrote:
>>> On Wed, May 20, 2020 at 1:27 AM Mritunjay Sharma
>>> <mritunjaysharma394 at gmail.com> wrote:
>>> >> Thanks for the log files. From a quick look, there is one obvious
>>> >> error, the linker can't find libbsd most probably because it is not
>>> >> there. So, you need to remove the -lbsd option from ptpd-2-1.cfg file
>>> >> LIBS value. Another thing to be noted is that there are a few errors
>>> >> due to failed version checking of the sparc-rtems5-gcc, this can
>>> >> probably ignored for now if removing the -lbsd option fixes your
>>> >> issue.
>>> > Thank you so much! Removing the lbsd from cfg file resloved the earlier
>>> > compiler issue but now another error is coming up and it is somewhat
>>> like this:
>>> > "Makefile:502: recipe for target 'all-recursive' failed
>>> > make[1]: Leaving directory
>>> '/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/build-cxc'
>>> > make[1]: *** [all-recursive] Error 1
>>> > Makefile:412: recipe for target 'all' failed
>>> > make: *** [all] Error 2
>>> > shell cmd failed: /bin/sh -ex
>>> /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/do-build
>>> > error: building ptpd-2.3.1-sparc-rtems5-1"
>>> The error is generally at the end of the log file. In this case, it is:
>>> In file included from ../../ptpd-2.3.1/src/arith.c:53:0:
>>> ../../ptpd-2.3.1/src/ptpd.h:93:10: fatal error: netinet/ip.h: No such
>>> file or directory
>>> #include <netinet/ip.h>
>>> compilation terminated.
>>> This header file isn't there in the include directory. Is netinet a
>>> dependency fo ptpd? If so, you'll have to find the package that
>>> provides netinet, and add that to rsb in a similar manner as in ptpd,
>>> then you'll have to add it in the ptpd.bset .
> Hi, I am attaching netinet/ip.h file, do we need to add entire netinet
> package as ptpd?
We can't just pull one file and add it to rsb, this will make it almost
impossible to track with the upstream. It would be better to add the whole
package. Did you find the official source?
To add the package, we need to add a separate set of cfg for netinet and
then add a reference in the ptpd cfg so that it builds before ptpd. qemu or
qemu-couverture can be examples of how to add a github repository to rsb
and build it. Please have a look at them and feel free to ask if you don't
understand something (maybe in a separate thread :) )
Also, please post the source of the package that you want to add, so that
there's no objection with the source later.
Chris commented about possible errors in the script, you might have to
follow up with him to fix the issue so that you don't face any problems
later.
Best regards,
Vijay
Or there's way to add just this file. I have tried finding netinet tar
> package but have to satisfy myself with
> just a github repo? Can it be added as source in cfg file?
> Thanks,
> Mritunjay
>> I have tried in this course. Have to still execute. Chris is telling
>> there is a problem with Canadian Cross
>> Compiling this. Is it allowed here to implement?
>>> > Attaching the log file as well.
>>> > - Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200523/940603da/attachment.html>
