[rtems/rsb]: Adding PTP support to RSB [GSoC 2020]
Mritunjay Sharma mritunjaysharma394 at gmail.com
Fri May 22 18:56:36 UTC 2020
On Thu, May 21, 2020 at 1:07 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> On Wed, May 20, 2020 at 1:46 AM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
>> On Wed, May 20, 2020 at 1:27 AM Mritunjay Sharma
>> <mritunjaysharma394 at gmail.com> wrote:
>> >> Thanks for the log files. From a quick look, there is one obvious
>> >> error, the linker can't find libbsd most probably because it is not
>> >> there. So, you need to remove the -lbsd option from ptpd-2-1.cfg file
>> >> LIBS value. Another thing to be noted is that there are a few errors
>> >> due to failed version checking of the sparc-rtems5-gcc, this can
>> >> probably ignored for now if removing the -lbsd option fixes your
>> >> issue.
>> > Thank you so much! Removing the lbsd from cfg file resloved the earlier
>> > compiler issue but now another error is coming up and it is somewhat
>> like this:
>> >  "Makefile:502: recipe for target 'all-recursive' failed
>> > make[1]: Leaving directory
>> '/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/build-cxc'
>> > make[1]: *** [all-recursive] Error 1
>> > Makefile:412: recipe for target 'all' failed
>> > make: *** [all] Error 2
>> > shell cmd failed: /bin/sh -ex
>> /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-2.3.1-sparc-rtems5-1/do-build
>> > error: building ptpd-2.3.1-sparc-rtems5-1"
>> The error is generally at the end of the log file. In this case, it is:
>> In file included from ../../ptpd-2.3.1/src/arith.c:53:0:
>> ../../ptpd-2.3.1/src/ptpd.h:93:10: fatal error: netinet/ip.h: No such
>> file or directory
>>  #include <netinet/ip.h>
>> compilation terminated.
>> This header file isn't there in the include directory. Is netinet a
>> dependency fo ptpd? If so, you'll have to find the package that
>> provides netinet, and add that to rsb in a similar manner as in ptpd,
>> then you'll have to add it in the ptpd.bset .
Hi, I am attaching netinet/ip.h file, do we need to add entire netinet
package as ptpd?
Or there's way to add just this file. I have tried finding netinet tar
package but have to satisfy myself with
just a github repo? Can it be added as source in cfg file?
Thanks,
Mritunjay
> I have tried in this course. Have to still execute. Chris is telling there
> is a problem with Canadian Cross
> Compiling this. Is it allowed here to implement?
>> > Attaching the log file as well.
>> > - Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200523/4561db7b/attachment-0001.html>
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200523/4561db7b/attachment-0001.bin>
