libbsd fails probe for gethostbyname was Fwd: Build Linux: FAILED 5/bsps/pc on x86_64-linux-gnu (curl-v7.65.1-i386-rtems5-1)
Joel Sherrill
joel at rtems.org
Sat May 23 16:41:51 UTC 2020
Hi
I reported this earlier this week and filed a ticket but wanted to
reiterate that this is a blocker for the release.
---------- Forwarded message ---------
Date: Sat, May 23, 2020 at 7:27 AM
Subject: Build Linux: FAILED 5/bsps/pc on x86_64-linux-gnu
To: <build at rtems.org>
RTEMS Source Builder - Set Builder, 5 (a137ab845165)
Host: Linux-3.10.0-1127.8.2.el7.x86_64-x86_64-with-centos-7.8.2003-Core
Linux devel.oarcorp.com 3.10.0-1127.8.2.el7.x86_64 #1 SMP Tue May 12
16:57:42 UTC 2020 x86_64 x86_64
Build Time: 0:18:47.121874
Output
Build Set: 5/bsps/pc
Build Set: 5/rtems-i386.bset
Build Set: 5/rtems-autotools.bset
Build Set: 5/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-linux-gnu-1
building: autoconf-2.69-x86_64-linux-gnu-1
sizes: autoconf-2.69-x86_64-linux-gnu-1: 7.504MB (installed: 0.000B)
cleaning: autoconf-2.69-x86_64-linux-gnu-1
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-linux-gnu-1
building: automake-1.12.6-x86_64-linux-gnu-1
sizes: automake-1.12.6-x86_64-linux-gnu-1: 8.090MB (installed: 0.000B)
cleaning: automake-1.12.6-x86_64-linux-gnu-1
Build Sizes: usage: 8.090MB total: 828.137MB (sources: 827.746MB, patches:
400.139KB, installed 0.000B)
Build Set: Time 0:00:06.225559
Build Set: 5/rtems-autotools-base.bset
sizes: autoconf-2.69-x86_64-linux-gnu-1: 10.536MB (installed: 3.034MB)
reporting: tools/rtems-autoconf-2.69-1.cfg ->
autoconf-2.69-x86_64-linux-gnu-1.txt
autoconf-2.69-x86_64-linux-gnu-1.xml
sizes: automake-1.12.6-x86_64-linux-gnu-1: 10.353MB (installed: 2.264MB)
reporting: tools/rtems-automake-1.12.6-1.cfg ->
automake-1.12.6-x86_64-linux-gnu-1.txt
automake-1.12.6-x86_64-linux-gnu-1.xml
staging: autoconf-2.69-x86_64-linux-gnu-1 ->
/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/tmp/sb-1001-staging
staging: automake-1.12.6-x86_64-linux-gnu-1 ->
Build Sizes: usage: 15.834MB total: 833.436MB (sources: 827.746MB, patches:
400.139KB, installed 5.298MB)
Build Set: Time 0:00:10.186746
Build Set: Time 0:00:16.415225
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-linux-gnu-1
building: expat-2.1.0-x86_64-linux-gnu-1
sizes: expat-2.1.0-x86_64-linux-gnu-1: 7.457MB (installed: 1.432MB)
cleaning: expat-2.1.0-x86_64-linux-gnu-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-linux-gnu-1.xml
config: tools/rtems-gdb-9.1-1.cfg
package: i386-rtems5-gdb-9.1-x86_64-linux-gnu-1
building: i386-rtems5-gdb-9.1-x86_64-linux-gnu-1
sizes: i386-rtems5-gdb-9.1-x86_64-linux-gnu-1: 739.254MB (installed:
96.313MB)
cleaning: i386-rtems5-gdb-9.1-x86_64-linux-gnu-1
reporting: tools/rtems-gdb-9.1-1.cfg ->
i386-rtems5-gdb-9.1-x86_64-linux-gnu-1.txt
i386-rtems5-gdb-9.1-x86_64-linux-gnu-1.xml
config: tools/rtems-binutils-2.34.cfg
package: i386-rtems5-binutils-2.34-x86_64-linux-gnu-1
building: i386-rtems5-binutils-2.34-x86_64-linux-gnu-1
sizes: i386-rtems5-binutils-2.34-x86_64-linux-gnu-1: 572.211MB (installed:
144.889MB)
cleaning: i386-rtems5-binutils-2.34-x86_64-linux-gnu-1
reporting: tools/rtems-binutils-2.34.cfg ->
i386-rtems5-binutils-2.34-x86_64-linux-gnu-1.txt
i386-rtems5-binutils-2.34-x86_64-linux-gnu-1.xml
config: tools/rtems-gcc-7.5.0-newlib-7947581.cfg
package: i386-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1
building: i386-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1
sizes: i386-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1: 3.230GB
(installed: 643.414MB)
cleaning: i386-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1
reporting: tools/rtems-gcc-7.5.0-newlib-7947581.cfg ->
i386-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1.txt
i386-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1.xml
config: tools/rtems-tools-5-1.cfg
package: rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1
building: rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1
sizes: rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1: 221.032MB
(installed: 58.690MB)
cleaning: rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1
reporting: tools/rtems-tools-5-1.cfg ->
rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1.txt
rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1.xml
staging: expat-2.1.0-x86_64-linux-gnu-1 ->
staging: i386-rtems5-gdb-9.1-x86_64-linux-gnu-1 ->
staging: i386-rtems5-binutils-2.34-x86_64-linux-gnu-1 ->
staging: i386-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1 ->
staging: rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1 ->
Build Sizes: usage: 4.153GB total: 1.731GB (sources: 827.746MB, patches:
400.139KB, installed 944.738MB)
Build Set: Time 0:14:08.572673
Build Set: 5/rtems-kernel.bset
config: tools/rtems-kernel-5.cfg
package: i386-rtems5-kernel-pc686-1
building: i386-rtems5-kernel-pc686-1
sizes: i386-rtems5-kernel-pc686-1: 389.391MB (installed: 41.731MB)
cleaning: i386-rtems5-kernel-pc686-1
reporting: tools/rtems-kernel-5.cfg -> i386-rtems5-kernel-pc686-1.txt
reporting: tools/rtems-kernel-5.cfg -> i386-rtems5-kernel-pc686-1.xml
staging: i386-rtems5-kernel-pc686-1 ->
Build Set: Time 0:01:42.435269
Build Set: 5/rtems-libbsd.bset
config: tools/rtems-libbsd-5.cfg
package:
rtems-libbsd-vd38dbbe18e5315bf69a7c3916d71ef3838d4c20d-x86_64-linux-gnu-1
building:
sizes:
rtems-libbsd-vd38dbbe18e5315bf69a7c3916d71ef3838d4c20d-x86_64-linux-gnu-1:
1.332GB (installed: 106.463MB)
cleaning:
reporting: tools/rtems-libbsd-5.cfg ->
rtems-libbsd-vd38dbbe18e5315bf69a7c3916d71ef3838d4c20d-x86_64-linux-gnu-1.txt
rtems-libbsd-vd38dbbe18e5315bf69a7c3916d71ef3838d4c20d-x86_64-linux-gnu-1.xml
staging:
cleaning:
Build Set: Time 0:01:20.600409
Build Set: 5/rtems-packages.bset
Build Set: databases/sqlite.bset
config: databases/sqlite-3.31.1-1.cfg
package: sqlite-3.31.1-i386-rtems5-1
building: sqlite-3.31.1-i386-rtems5-1
sizes: sqlite-3.31.1-i386-rtems5-1: 33.311MB (installed: 7.708MB)
cleaning: sqlite-3.31.1-i386-rtems5-1
reporting: databases/sqlite-3.31.1-1.cfg -> sqlite-3.31.1-i386-rtems5-1.txt
reporting: databases/sqlite-3.31.1-1.cfg -> sqlite-3.31.1-i386-rtems5-1.xml
staging: sqlite-3.31.1-i386-rtems5-1 ->
Build Set: Time 0:00:31.327884
Build Set: graphics/freetype2.bset
config: graphics/freetype-2.4.10-1.cfg
package: freetype-v2.4.10-i386-rtems5-1
building: freetype-v2.4.10-i386-rtems5-1
sizes: freetype-v2.4.10-i386-rtems5-1: 24.968MB (installed: 5.105MB)
cleaning: freetype-v2.4.10-i386-rtems5-1
reporting: graphics/freetype-2.4.10-1.cfg ->
freetype-v2.4.10-i386-rtems5-1.txt
freetype-v2.4.10-i386-rtems5-1.xml
staging: freetype-v2.4.10-i386-rtems5-1 ->
Build Set: Time 0:00:07.791590
Build Set: graphics/libjpeg.bset
config: graphics/libjpeg-9a-1.cfg
package: libjpeg-v9a-i386-rtems5-1
building: libjpeg-v9a-i386-rtems5-1
sizes: libjpeg-v9a-i386-rtems5-1: 57.150MB (installed: 25.032MB)
cleaning: libjpeg-v9a-i386-rtems5-1
reporting: graphics/libjpeg-9a-1.cfg -> libjpeg-v9a-i386-rtems5-1.txt
reporting: graphics/libjpeg-9a-1.cfg -> libjpeg-v9a-i386-rtems5-1.xml
staging: libjpeg-v9a-i386-rtems5-1 ->
Build Set: Time 0:00:06.358405
Build Set: graphics/libpng.bset
config: graphics/libpng-1.6.37-1.cfg
package: libpng-v1.6.37-i386-rtems5-1
building: libpng-v1.6.37-i386-rtems5-1
sizes: libpng-v1.6.37-i386-rtems5-1: 69.332MB (installed: 11.327MB)
cleaning: libpng-v1.6.37-i386-rtems5-1
reporting: graphics/libpng-1.6.37-1.cfg -> libpng-v1.6.37-i386-rtems5-1.txt
reporting: graphics/libpng-1.6.37-1.cfg -> libpng-v1.6.37-i386-rtems5-1.xml
staging: libpng-v1.6.37-i386-rtems5-1 ->
Build Set: Time 0:00:08.516293
Build Set: graphics/libtiff.bset
config: graphics/libtiff-4.0.10-1.cfg
package: libtiff-v4.0.10-i386-rtems5-1
building: libtiff-v4.0.10-i386-rtems5-1
sizes: libtiff-v4.0.10-i386-rtems5-1: 300.040MB (installed: 123.601MB)
cleaning: libtiff-v4.0.10-i386-rtems5-1
reporting: graphics/libtiff-4.0.10-1.cfg ->
libtiff-v4.0.10-i386-rtems5-1.txt
libtiff-v4.0.10-i386-rtems5-1.xml
staging: libtiff-v4.0.10-i386-rtems5-1 ->
Build Set: Time 0:00:18.289934
Build Set: graphics/t1lib.bset
config: graphics/t1lib-5.1.2-1.cfg
package: t1lib-v5.1.2-i386-rtems5-1
building: t1lib-v5.1.2-i386-rtems5-1
sizes: t1lib-v5.1.2-i386-rtems5-1: 19.594MB (installed: 3.529MB)
cleaning: t1lib-v5.1.2-i386-rtems5-1
reporting: graphics/t1lib-5.1.2-1.cfg -> t1lib-v5.1.2-i386-rtems5-1.txt
reporting: graphics/t1lib-5.1.2-1.cfg -> t1lib-v5.1.2-i386-rtems5-1.xml
staging: t1lib-v5.1.2-i386-rtems5-1 ->
Build Set: Time 0:00:15.516719
Build Set: ftp/curl.bset
config: ftp/curl-7.65.1-1.cfg
package: curl-v7.65.1-i386-rtems5-1
building: curl-v7.65.1-i386-rtems5-1
error: building curl-v7.65.1-i386-rtems5-1
Build FAILED
See error report: rsb-report-curl-v7.65.1-i386-rtems5-1.txt
Build Set: Time 0:00:07.693592
Build Set: Time 0:01:35.507540
Mailing report: build at rtems.org
Report
RTEMS Tools Project <users at rtems.org> Sat May 23 07:08:49 2020
Report: devel/expat-2.1.0-1.cfg
RTEMS Source Builder Repository Status
Remotes:
[ remotes removed, contact sender for details ]
Status:
Clean
Head:
Commit: a137ab845165d87d238a69631b52def24007c91c
Build Set: (1) devel/expat-2.1.0-1.cfg
Build Set: (2) devel/expat-2.1.0-1.cfg
Package: expat-2.1.0-x86_64-linux-gnu-1
Config: devel/expat-2.1.0-1.cfg
Summary:
Expat XML Parser v2.1.0 for target i386-rtems5 on host x86_64-linux-gnu
URL:
http://expat.sourceforge.net/
Version:
2.1.0
Release:
1
Sources: 1
1:
https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz
sha256:
823705472f816df21c8f6aa026dd162b280806838bb55b3432b0fb1fcca7eb86
Patches: 0
Preparation:
build_top=$(pwd)
%setup source expat -q -n expat-2.1.0
%setup patch expat -p1
cd ${build_top}
Build:
build_top=$(pwd)
cd expat-2.1.0
# Host and build flags, Cross build if host and build are different and
# Cxc build if target is deifned and also different.
# Note, gcc is not ready to be compiled with -std=gnu99 (this needs to be
checked).
if test "x86_64-linux-gnu" != "x86_64-linux-gnu" ; then
# Cross build
CC=$(echo "x86_64-linux-gnu-gcc" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "x86_64-linux-gnu-g++" | sed -e 's,-std=gnu99 ,,')
CPPFLAGS="${SB_HOST_CPPFLAGS}"
CFLAGS="${SB_HOST_CFLAGS}"
CXXFLAGS="${SB_HOST_CXXFLAGS}"
LDFLAGS="${SB_HOST_LDFLAGS}"
LDLIBS="${SB_HOST_LIBS}"
# Host
CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
LDLIBS_FOR_HOST="${SB_HOST_LIBS}"
CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
CC_FOR_HOST=$(echo "gcc ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX_FOR_HOST=$(echo "g++ ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99
# Build
CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
LDLIBS_FOR_BUILD="${SB_BUILD_LIBS}"
CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
CC_FOR_BUILD=$(echo "gcc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX_FOR_BUILD=$(echo "g++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99
else
LDFLAGS="${SB_BUILD_LDFLAGS}"
LDLIBS="${SB_BUILD_LIBS}"
CC=$(echo "gcc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "g++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
CC_FOR_BUILD=${CC}
CXX_FOR_BUILD=${CXX}
fi
export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST
CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD
LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
./configure --build=x86_64-linux-gnu --host=x86_64-linux-gnu --verbose
--prefix=/home/joel/rtems-cron-5/tools/5
--bindir=/home/joel/rtems-cron-5/tools/5/bin
--exec-prefix=/home/joel/rtems-cron-5/tools/5
--includedir=/home/joel/rtems-cron-5/tools/5/include
--libdir=/home/joel/rtems-cron-5/tools/5/lib
--mandir=/home/joel/rtems-cron-5/tools/5/share/man
--infodir=/home/joel/rtems-cron-5/tools/5/share/info
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
rm -rf $SB_BUILD_ROOT
cd expat-2.1.0
make DESTDIR=$SB_BUILD_ROOT install
cd ${build_top}
Remotes:
Status:
Clean
Head:
Summary:
URL:
Version:
2.1.0
Release:
1
Sources: 1
1:
sha256:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
cd expat-2.1.0
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd expat-2.1.0
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:10:42 2020
Report: tools/rtems-gdb-9.1-1.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) tools/rtems-gdb-9.1-1.cfg
Build Set: (2) tools/rtems-gdb-9.1-1.cfg
Package: i386-rtems5-gdb-9.1-x86_64-linux-gnu-1
Config: tools/rtems-gdb-9.1-1.cfg
Summary:
GDB v9.1 for target i386-rtems5 on host x86_64-linux-gnu
URL:
http://www.gnu.org/software/gdb/
Version:
9.1
Release:
1
Sources: 1
1: http://ftp.gnu.org/gnu/gdb/gdb-9.1.tar.xz
sha512:
hM3UCNgKP8V3neRZxbJhVNMbMp695+OqeHmfseskXYtkuMjuckI4Kh29lbTm+dhP70HRKgZGqnXT3uRwnqH25w==
Patches: 0
Preparation:
build_top=$(pwd)
gdb_source="gdb-9.1"
source_dir_gdb=${gdb_source}
%setup source gdb -q -n ${gdb_source}
%setup patch gdb -p1
cd ${build_top}
Build:
build_top=$(pwd)
# Cross-build (Xc) if no target or the host and target match.
# Canadian-cross (Cxc) if build, host and target are all different.
if test -z "i386-rtems5" -o "x86_64-linux-gnu" == "i386-rtems5" ; then
build_dir="build-xc"
else
build_dir="build-cxc"
fi
else
build_dir="build"
fi
mkdir -p ${build_dir}
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
GDB_LIBS_STATIC="-lexpat"
else
GDB_LIBS="-Xlinker -Bstatic ${LIBS_STATIC} -Xlinker -Bdynamic"
fi
LIBS_STATIC=${GDB_LIBS_STATIC} LIBS=${GDB_LIBS}
../${source_dir_gdb}/configure --build=x86_64-linux-gnu
--host=x86_64-linux-gnu --target=i386-rtems5 --verbose --disable-nls
--disable-gas --disable-binutils --disable-ld --disable-gold
--disable-gprof --without-included-gettext --disable-win32-registry
--disable-werror --enable-sim --without-zlib --with-expat
--with-guile=no --with-python=/usr/bin/python2
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
/bin/rm -rf $SB_BUILD_ROOT
cd ${build_dir}
/bin/rm -rf $SB_BUILD_ROOT/home/joel/rtems-cron-5/tools/5/share/info/
configure.info*
/bin/rm -f $SB_BUILD_ROOT/home/joel/rtems-cron-5/tools/5/share/info/dir
touch $SB_BUILD_ROOT/home/joel/rtems-cron-5/tools/5/share/info/dir
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:10:43 2020
Remotes:
Status:
Clean
Head:
Summary:
URL:
Version:
9.1
Release:
1
Sources: 1
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
else
fi
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
configure.info*
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:11:23 2020
Report: tools/rtems-binutils-2.34.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) tools/rtems-binutils-2.34.cfg
Build Set: (2) tools/rtems-binutils-2.34.cfg
Package: i386-rtems5-binutils-2.34-x86_64-linux-gnu-1
Config: tools/rtems-binutils-2.34.cfg
Summary:
Binutils v2.34 for target i386-rtems5 on host x86_64-linux-gnu
URL:
http://sources.redhat.com/binutils
Version:
2.34
Release:
1
Sources: 1
1: https://ftp.gnu.org/gnu/binutils/binutils-2.34.tar.bz2
sha512:
f47e7304e102c7bbc97958a08093e27796b9051d1567ce4fbb723d39ef3e29efa325ee14a1bdcc462a925a7f9bbbc9aee28294c6dc23850f371030f3835a8067
Patches: 0
Preparation:
build_top=$(pwd)
binutils_source="binutils-2.34"
source_dir_binutils=${binutils_source}
%setup source binutils -q -n ${binutils_source}
%setup patch binutils -p1
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
../${source_dir_binutils}/configure --build=x86_64-linux-gnu
--disable-gdb --disable-libdecnumber --disable-readline --disable-sim
--enable-deterministic-archives --enable-64-bit-bfd --disable-lto
--without-included-gettext --disable-win32-registry --disable-werror
make -j 8 all
cd ${build_top}
Install:
cd ${build_top}
cd ${build_dir}
configure.info*
mkdir -p $SB_BUILD_ROOT/home/joel/rtems-cron-5/tools/5/share/locale
/bin/rm -f ${SB_BUILD_ROOT}/home/joel/rtems-cron-5/tools/5/lib/libiberty*
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5/tools/5/bin/i386-rtems5-dlltool;
then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5/tools/5/share/man/man1/i386-rtems5-dlltool*
fi
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5/tools/5/bin/i386-rtems5-nlmconv;
then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5/tools/5/share/man/man1/i386-rtems5-nlmconv*
fi
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5/tools/5/bin/i386-rtems5-windres;
then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5/tools/5/share/man/man1/i386-rtems5-windres*
fi
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5/tools/5/bin/i386-rtems5-windmc; then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5/tools/5/share/man/man1/i386-rtems5-windmc*
fi
cd ${build_top}
Remotes:
Status:
Clean
Head:
Summary:
URL:
Version:
2.34
Release:
1
Sources: 1
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
make -j 8 all
cd ${build_top}
Install:
cd ${build_top}
cd ${build_dir}
configure.info*
if test ! -f
then
/bin/rm -f
fi
if test ! -f
then
/bin/rm -f
fi
if test ! -f
then
/bin/rm -f
fi
if test ! -f
/bin/rm -f
fi
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:22:09 2020
Report: tools/rtems-gcc-7.5.0-newlib-7947581.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) tools/rtems-gcc-7.5.0-newlib-7947581.cfg
Build Set: (2) tools/rtems-gcc-7.5.0-newlib-7947581.cfg
Package: i386-rtems5-gcc-7.5.0-newlib-7947581-x86_64-linux-gnu-1
Config: tools/rtems-gcc-7.5.0-newlib-7947581.cfg
Summary:
GCC v7.5.0 and Newlib v7947581 for target i386-rtems5 on host
x86_64-linux-gnu
URL:
http://gcc.gnu.org/
Version:
7.5.0
Release:
1
Sources: 6
1: https://ftp.gnu.org/gnu/gcc/gcc-7.5.0/gcc-7.5.0.tar.xz
sha512:
fe716cc19f2e3255d3a8b1b8290777bf769c6d98e6e0b07b81a3d6ad43f8af74cb170dfa18b1555dbfcd3f55ae582b91a286ccef496b9b65c1579902f96a1f60
2: https://ftp.gnu.org/gnu/mpc/mpc-1.0.3.tar.gz
sha512:
0028b76df130720c1fad7de937a0d041224806ce5ef76589f19c7b49d956071a683e2f20d154c192a231e69756b19e48208f2889b0c13950ceb7b3cfaf059a43
3: --rsb-file=newlib-7947581.tar.gz
https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/7947581
No checksum
4: https://gcc.gnu.org/pub/gcc/infrastructure/isl-0.16.1.tar.bz2
sha512:
c188667a84dc5bdddb4ab7c35f89c91bf15a8171f4fcaf41301cf285fb7328846d9a367c096012fec4cc69d244f0bc9e95d84c09ec097394cd4093076f2a041b
5: https://ftp.gnu.org/gnu/gmp/gmp-6.1.0.tar.bz2
sha512:
3c82aeab9c1596d4da8afac2eec38e429e84f3211e1a572cf8fd2b546493c44c039b922a1133eaaa48bd7f3e11dbe795a384e21ed95cbe3ecc58d7ac02246117
6: https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2
sha512:
51066066ff2c12ed2198605ecf68846b0c96b548adafa5b80e0c786d0df488411a5e8973358fce7192dc977ad4e68414cf14500e3c39746de62465eb145bb819
Patches: 0
Preparation:
build_top=$(pwd)
gcc_source="gcc-7.5.0"
source_dir_gcc=${gcc_source}
%setup source gcc -q -n ${gcc_source}
%setup patch gcc -p1
cd ${build_top}
source_dir_newlib=sourceware-mirror-newlib-cygwin-7947581
%setup source newlib -q -D -n ${source_dir_newlib}
%setup patch newlib -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/newlib
ln -s $PWD/${source_dir_newlib}/newlib ${source_dir_gcc}/newlib
source_dir_isl="isl-0.16.1"
%setup source isl -q -D -n isl-0.16.1
%setup patch isl -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/isl
ln -s $PWD/${source_dir_isl} ${source_dir_gcc}/isl
source_dir_mpfr="mpfr-3.1.4"
%setup source mpfr -q -D -n mpfr-3.1.4
%setup patch mpfr -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/mpfr
ln -s $PWD/${source_dir_mpfr} ${source_dir_gcc}/mpfr
source_dir_mpc="mpc-1.0.3"
%setup source mpc -q -D -n mpc-1.0.3
%setup patch mpc -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/mpc
ln -s $PWD/${source_dir_mpc} ${source_dir_gcc}/mpc
source_dir_gmp="gmp-6.1.0"
%setup source gmp -q -D -n gmp-6.1.0
%setup patch gmp -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/gmp
ln -s $PWD/${source_dir_gmp} ${source_dir_gcc}/gmp
echo "RTEMS 5, RSB 5 (a137ab845165), Newlib 7947581" >
${source_dir_gcc}/gcc/DEV-PHASE
cd ${source_dir_gcc}
contrib/gcc_update --touch
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
languages="c"
languages="$languages,c++"
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
../${source_dir_gcc}/configure --prefix=/home/joel/rtems-cron-5/tools/5
--exec_prefix=/home/joel/rtems-cron-5/tools/5
--libexecdir=/home/joel/rtems-cron-5/tools/5/libexec
--datadir=/home/joel/rtems-cron-5/tools/5/share --build=x86_64-linux-gnu
--host=x86_64-linux-gnu --target=i386-rtems5 --disable-libstdcxx-pch
--with-gnu-as --with-gnu-ld --verbose --with-newlib --disable-nls
--enable-version-specific-runtime-libs --disable-lto
--enable-newlib-io-c99-formats --enable-newlib-iconv
--enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,\
cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,\
iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,\
iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,\
iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,\
ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,\
utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,\
win_1253,win_1254,win_1255,win_1256,win_1257,win_1258 --enable-threads
--disable-plugin --enable-libgomp --enable-languages="$languages"
if test "%_host" != "%_build" ; then
mkdir -p gcc/include
cp ../${source_dir_gcc}/gcc/gsyslimits.h gcc/include/syslimits.h
fi
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
/bin/rm -f ${SB_BUILD_ROOT}/home/joel/rtems-cron-5/tools/5/lib/libiberty.a
/bin/rm -f
$SB_BUILD_ROOT/home/joel/rtems-cron-5/tools/5/bin/i386-rtems5-c++filt
/bin/rm -f
$SB_BUILD_ROOT/home/joel/rtems-cron-5/tools/5/share/man/man3/*ffi*
/bin/rm -rf ${source_dir_gcc}/newlib
/bin/rm -rf ${source_dir_gcc}/mpfr
/bin/rm -rf ${source_dir_gcc}/mpc
/bin/rm -rf ${source_dir_gcc}/gmp
Remotes:
Status:
Clean
Head:
Summary:
x86_64-linux-gnu
URL:
http://gcc.gnu.org/
Version:
7.5.0
Release:
1
Sources: 6
sha512:
sha512:
No checksum
sha512:
sha512:
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
languages="c"
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
fi
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
/bin/rm -f
/bin/rm -f
RTEMS Tools Project <users at rtems.org> Sat May 23 07:22:25 2020
Report: tools/rtems-tools-5-1.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) tools/rtems-tools-5-1.cfg
Build Set: (2) tools/rtems-tools-5-1.cfg
Package: rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5-1
Config: tools/rtems-tools-5-1.cfg
Summary:
RTEMS Tools ca7b290f94a19238ed068aad229854cf67dee9b5 for host
x86_64-linux-gnu
URL:
http://www.rtems.org/
Version:
Release:
1
Sources: 1
1:
https://git.rtems.org/rtems-tools/snapshot/rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5.tar.bz2
sha512:
XOXag6wO1hlsXZAwWvADQV6TMd5Yt/+udEtJuD196FqdPfkocX0D/dbrXOzrqjThyaJCHZXXx+xs90Vdv/0jtg==
Patches: 0
Preparation:
build_top=$(pwd)
rtems_tools_source=rtems-tools-ca7b290f94a19238ed068aad229854cf67dee9b5
source_dir_rtems_tools=${rtems_tools_source}
%setup source rtems-tools -q -n ${rtems_tools_source}
%setup patch rtems-tools -p1
cd ${build_top}
Build:
build_top=$(pwd)
RT_HOST="--host=x86_64-linux-gnu"
else
RT_HOST=
fi
cd ${source_dir_rtems_tools}
./waf distclean configure ${RT_HOST}
./waf
cd ${build_top}
Install:
build_top=$(pwd)
./waf --destdir=$SB_BUILD_ROOT install
cd ${build_top}
Remotes:
Status:
Clean
Head:
Summary:
x86_64-linux-gnu
URL:
Version:
Release:
1
Sources: 1
1:
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
RT_HOST=
fi
./waf
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:24:15 2020
Report: tools/rtems-kernel-5.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) tools/rtems-kernel-5.cfg
Build Set: (2) tools/rtems-kernel-5.cfg
Package: i386-rtems5-kernel-pc686-1
Config: tools/rtems-kernel-5.cfg
Summary:
RTEMS v01219541289e8081054d4a57924ee169339f1eaf for target i386-rtems5
BSP pc686
URL:
https://www.rtems.org/
Version:
Release:
1
Sources: 1
1:
--rsb-file=rtems-kernel-01219541289e8081054d4a57924ee169339f1eaf.tar.bz2
https://git.rtems.org/rtems/snapshot/rtems-01219541289e8081054d4a57924ee169339f1eaf.tar.bz2
No checksum
Patches: 0
Preparation:
source_dir_rtems="rtems-01219541289e8081054d4a57924ee169339f1eaf"
%setup source rtems_kernel -q -c -n
i386-rtems5-kernel-pc686-1-01219541289e8081054d4a57924ee169339f1eaf
cd ${source_dir_rtems}
%setup patch rtems_kernel -p1
export
PATH="/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/tmp/sb-1001/${SB_PREFIX_CLEAN}/bin:${PATH}"
./bootstrap -c
/home/joel/rtems-cron-5/rtems-source-builder/source-builder/sb-bootstrap
--preinstall
cd ..
Build:
else
build_dir="build"
fi
cd ${build_dir}
../${source_dir_rtems}/configure --build=x86_64-linux-gnu
--host=x86_64-linux-gnu --target=i386-rtems5 --enable-rtemsbsp="pc686"
--enable-posix --disable-networking --enable-cxx
make -j 8 all
cd ..
Install:
cd ${build_dir}
cd ..
RTEMS Tools Project <users at rtems.org> Sat May 23 07:24:16 2020
Remotes:
Status:
Clean
Head:
Summary:
BSP pc686
URL:
Version:
Release:
1
Sources: 1
1:
No checksum
Patches: 0
Preparation:
export
./bootstrap -c
--preinstall
cd ..
Build:
else
build_dir="build"
fi
cd ${build_dir}
make -j 8 all
cd ..
Install:
cd ${build_dir}
cd ..
RTEMS Tools Project <users at rtems.org> Sat May 23 07:25:37 2020
Report: tools/rtems-libbsd-5.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) tools/rtems-libbsd-5.cfg
Build Set: (2) tools/rtems-libbsd-5.cfg
Package:
Config: tools/rtems-libbsd-5.cfg
Summary:
RTEMS LibBSD provides libbsd, a FreeBSD kernel set of
services for RTEMS.
URL:
https://git.rtems.org/rtems-libbsd.git/
Version:
Release:
1
Sources: 2
1:
https://git.rtems.org/rtems_waf/snapshot/rtems_waf-ad08908c452c6a9bbb3bf7bbbcc9fc03fe46cc7f.tar.bz2
No checksum
2:
https://git.rtems.org/rtems-libbsd/snapshot/rtems-libbsd-d38dbbe18e5315bf69a7c3916d71ef3838d4c20d.tar.bz2
sha512:
6+1EkrQ6w/Ks6W3TKijvBGpVPpQFjwKAtpuHp8HH4zCEgyB74oLr0G+J120eK65bPUJl/14EMgYKA+9TKIi/AA==
Patches: 0
Preparation:
build_top=$(pwd)
source_dir_libbsd="rtems-libbsd-d38dbbe18e5315bf69a7c3916d71ef3838d4c20d"
%setup source rtems_libbsd -q -n
%setup source rtems_waf -q -s 1 -c -a -n
rtems-libbsd-d38dbbe18e5315bf69a7c3916d71ef3838d4c20d/rtems_waf
cd ${build_top}
Build:
build_top=$(pwd)
checked).
if test "x86_64-linux-gnu" != "i386-rtems5" ; then
# Cross build
CC=$(echo "i386-rtems5-gcc" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "i386-rtems5-g++" | sed -e 's,-std=gnu99 ,,')
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
cd ${source_dir_libbsd}
./waf distclean configure --prefix=/home/joel/rtems-cron-5/tools/5
--rtems-tools=/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/tmp/sb-1001-staging
--rtems=/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/tmp/sb-1001-staging
--rtems-bsp=i386/pc686
./waf build
cd ${build_top}
Install:
build_top=$(pwd)
/bin/rm -rf ${SB_BUILD_ROOT}
cd ${build_top}
Remotes:
Status:
Clean
Head:
Package:
Summary:
services for RTEMS.
URL:
Version:
Release:
1
Sources: 2
1:
No checksum
2:
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
./waf build
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:26:09 2020
Report: databases/sqlite-3.31.1-1.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) databases/sqlite-3.31.1-1.cfg
Build Set: (2) databases/sqlite-3.31.1-1.cfg
Package: sqlite-3.31.1-i386-rtems5-1
Config: databases/sqlite-3.31.1-1.cfg
Summary:
SQLite is an in-process library that implements a
self-contained, serverless, zero-configuration,
transactional SQL database engine.
URL:
http://www.sqlite.org/
Version:
3.31.1
Release:
1
Sources: 1
1: http://www.sqlite.org/2020/sqlite-autoconf-3310100.tar.gz
sha512:
d85250ba5f78f0c918880f663741709aba662192f04888b2324a0df17affdf5b8540e8428c6c7315119806e7adad758ea281c9b403c0ad94ac6a9bd1b93fd617
Patches: 0
Preparation:
build_top=$(pwd)
source_dir_sqlite="sqlite-autoconf-3310100"
%setup source sqlite -q -n sqlite-autoconf-3310100
%setup patch sqlite -p1
cd ${build_top}
Build:
build_top=$(pwd)
if test -z "" -o "i386-rtems5" == "" ; then
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
CFLAGS="${CFLAGS} -DSQLITE_MAX_MMAP_SIZE=0
-DSQLITE_DEFAULT_LOCKING_MODE=1 -DSQLITE_ENABLE_MEMSYS5"
../${source_dir_sqlite}/configure --host=i386-rtems5
--bindir=/home/joel/rtems-cron-5/tools/5/i386-rtems5/pc686/bin
--exec_prefix=/home/joel/rtems-cron-5/tools/5/i386-rtems5/pc686
--includedir=/home/joel/rtems-cron-5/tools/5/i386-rtems5/pc686/lib/include
--libdir=/home/joel/rtems-cron-5/tools/5/i386-rtems5/pc686/lib
--libexecdir=/home/joel/rtems-cron-5/tools/5/i386-rtems5/pc686/libexec
--mandir=/home/joel/rtems-cron-5/tools/5/i386-rtems5/pc686/share/man
--infodir=/home/joel/rtems-cron-5/tools/5/i386-rtems5/pc686/share/info
--datadir=/home/joel/rtems-cron-5/tools/5/i386-rtems5/pc686/share
--disable-largefile --disable-readline
make -j 8 sqlite3.h libsqlite3.la
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
make DESTDIR=$SB_BUILD_ROOT install-data install-libLTLIBRARIES
cd ${build_top}
Remotes:
Status:
Clean
Head:
Summary:
URL:
Version:
3.31.1
Release:
1
Sources: 1
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:26:17 2020
Report: graphics/freetype-2.4.10-1.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) graphics/freetype-2.4.10-1.cfg
Build Set: (2) graphics/freetype-2.4.10-1.cfg
Package: freetype-v2.4.10-i386-rtems5-1
Config: graphics/freetype-2.4.10-1.cfg
Summary:
freetype is for producing high-quality output (glyph images) of most
vector and bitmap font formats.
URL:
http://www.freetype.org/
Version:
2.4.10
Release:
1
Sources: 1
1:
http://download.savannah.gnu.org/releases/freetype/freetype-2.4.10.tar.gz
sha512:
507d1c03d394b695b5a96041ad7ee03b375964c89f007678db864a7e5bd2ee69d83e6c638f4aadaf348c921d37c16741a03ef9bee03196bda2b94ceea409b688
Patches: 0
Preparation:
build_top=$(pwd)
source_dir_freetype="freetype-2.4.10"
%setup source freetype -q -n freetype-2.4.10
%setup patch freetype -p1
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
GNUMAKE=
GNUMAKE=${GNUMAKE} ../${source_dir_freetype}/configure
--host=i386-rtems5 --prefix=/home/joel/rtems-cron-5/tools/5
--disable-shared
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
Remotes:
Status:
Clean
Head:
Summary:
URL:
Version:
2.4.10
Release:
1
Sources: 1
1:
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
GNUMAKE=
--disable-shared
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:26:23 2020
Report: graphics/libjpeg-9a-1.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) graphics/libjpeg-9a-1.cfg
Build Set: (2) graphics/libjpeg-9a-1.cfg
Package: libjpeg-v9a-i386-rtems5-1
Config: graphics/libjpeg-9a-1.cfg
Summary:
libjpeg is the Independent JPEG Group jpeg library
URL:
http://www.ijg.org/
Version:
9a
Release:
1
Sources: 1
1: http://www.ijg.org/files/jpegsrc.v9a.tar.gz
sha512:
9b21cc115e22c68bea46db462263c5c7a0d10beb192a919ecccbd801a25982b518ce44d8c301dd582ecaba1850e0e0f20e322be82b0e24ae917b9949b4f10d3b
Patches: 0
Preparation:
build_top=$(pwd)
source_dir_libjpeg="jpeg-9a"
%setup source libjpeg -q -n jpeg-9a
%setup patch libjpeg -p1
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
../${source_dir_libjpeg}/configure --host=i386-rtems5
--disable-shared
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
Remotes:
Status:
Clean
Head:
Summary:
URL:
http://www.ijg.org/
Version:
9a
Release:
1
Sources: 1
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
--disable-shared
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:26:31 2020
Report: graphics/libpng-1.6.37-1.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) graphics/libpng-1.6.37-1.cfg
Build Set: (2) graphics/libpng-1.6.37-1.cfg
Package: libpng-v1.6.37-i386-rtems5-1
Config: graphics/libpng-1.6.37-1.cfg
Summary:
libpng is the official PNG reference library
URL:
http://www.libpng.org/
Version:
1.6.37
Release:
1
Sources: 1
1: --rsb-file=libpng-1.6.37.tar.xz
http://prdownloads.sourceforge.net/libpng/libpng-1.6.37.tar.xz?download
No checksum
Patches: 0
Preparation:
build_top=$(pwd)
source_dir_libpng="libpng-1.6.37"
%setup source libpng -q -n libpng-1.6.37
%setup patch libpng -p1
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
../${source_dir_libpng}/configure --host=i386-rtems5
--disable-shared
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:26:32 2020
Remotes:
Status:
Clean
Head:
Summary:
URL:
Version:
1.6.37
Release:
1
Sources: 1
No checksum
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
--disable-shared
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:26:49 2020
Report: graphics/libtiff-4.0.10-1.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) graphics/libtiff-4.0.10-1.cfg
Build Set: (2) graphics/libtiff-4.0.10-1.cfg
Package: libtiff-v4.0.10-i386-rtems5-1
Config: graphics/libtiff-4.0.10-1.cfg
Summary:
libtiff provides support for the Tag Image File Format (TIFF), a widely
used format for storing image data.
URL:
http://www.libtiff.org/
Version:
4.0.10
Release:
1
Sources: 1
1: http://download.osgeo.org/libtiff/tiff-4.0.10.tar.gz
sha512:
d213e5db09fd56b8977b187c5a756f60d6e3e998be172550c2892dbdb4b2a8e8c750202bc863fe27d0d1c577ab9de1710d15e9f6ed665aadbfd857525a81eea8
Patches: 0
Preparation:
build_top=$(pwd)
source_dir_tiff="tiff-4.0.10"
%setup source libtiff -q -n tiff-4.0.10
%setup patch libtiff -p1
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
../${source_dir_tiff}/configure --host=i386-rtems5
--datarootdir=/home/joel/rtems-cron-5/tools/5/i386-rtems5/pc686/share
--with-docdir=/home/joel/rtems-cron-5/tools/5/i386-rtems5/pc686/share/doc
--disable-shared
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:26:50 2020
Remotes:
Status:
Clean
Head:
Summary:
URL:
Version:
4.0.10
Release:
1
Sources: 1
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
--disable-shared
make -j 8 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:27:05 2020
Report: graphics/t1lib-5.1.2-1.cfg
Remotes:
Status:
Clean
Head:
Build Set: (1) graphics/t1lib-5.1.2-1.cfg
Build Set: (2) graphics/t1lib-5.1.2-1.cfg
Package: t1lib-v5.1.2-i386-rtems5-1
Config: graphics/t1lib-5.1.2-1.cfg
Summary:
t1lib is the official PNG reference library
URL:
http://www.t1lib.org/
Version:
5.1.2
Release:
1
Sources: 1
1: http://ftp.netbsd.org/pub/pkgsrc/distfiles/t1lib-5.1.2.tar.gz
sha512:
9f424b19c6f35cc4f194ff7351a4c2352216462c7d1b1d9650ad3a05cf48c6e90c89ccbcda5ecc47a4169a39a850cf84a1fcbf88b3b15614860c27364b631ae3
Patches: 1
1:
https://raw.githubusercontent.com/yangqiao/rtems-tools/graphics/tools/4.11/t1lib/t1lib-5.1.2.diff
sha512:
1afd18182350d7d2426a910c61537f8532e149bf37c616f3a4a84ae0767c4549a2be857db6fd1b1994ed86f8a2e2d4cdfb2abdf67053c8ca1ee83893f4b56d23
Preparation:
build_top=$(pwd)
source_dir_t1lib="t1lib-5.1.2"
%setup source t1lib -q -n t1lib-5.1.2
%setup patch t1lib -p1
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
cd ${source_dir_t1lib}
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
./configure --host=i386-rtems5
--disable-shared --without-athena --without-x
make -j 8 without_doc
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat May 23 07:27:06 2020
Remotes:
Status:
Clean
Head:
Summary:
URL:
Version:
5.1.2
Release:
1
Sources: 1
sha512:
Patches: 1
1:
sha512:
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
else
fi
else
build_dir="build"
fi
checked).
# Cross build
# Host
# Build
else
CC_FOR_BUILD=${CC}
fi
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_top}
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200523/05b5663f/attachment-0001.html>
