GSoC: Porting OFW to RTEMS
Niteesh G. S. niteesh.gs at gmail.com
Mon May 25 09:20:55 UTC 2020
Hello,
I have completed the porting of the OFW code from FreeBSD to RTEMS.
I do acknowledge the fact that we haven't decided on the directory for files
to be placed in. The previous conversation had stopped quite a while ago.
Christian suggested I work on the patch since that would also start the
conversation again and also refactoring the patch to the correct directory
will not be much of work.
cpukit/libfreebsd was suggested as one of the directories to place the
ported
FreeBSD files. It is suggested to place all the source files under this
directory.
Since this will make the sync part easier. But this causes issues when
porting
BSP dependent files. Since RTEMS currently doesn't allow files in cpukit to
reference bsp headers. I faced a similar issue during my porting process
also.
The OFW init function require bsp_fdt_get function to get a reference to
the fdt
blob. But I can't include the bsp/fdt.h header file from a source file
under cpukit.
We must decide the directory quickly because my project will import other
FreeBSD sources like the pinmux driver for beaglebone into RTEMS.
https://github.com/gs-niteesh/rtems/commits/ofw_branch
Please have a look at the last 6 patches for the ported work.
Below is a short summary of the patch.
* The openfirm.h is the OF interface that will provided to the user.
* The openfirm.c contains the function definition for openfirm.h. The
functions
call the respective OFW_* functions which are responsible for choosing the
correct implementation for OF interface.
* ofw_if.h is the replacement for ofw_if.h in FreeBSD. This is an auto
generated
header in FreeBSD which choose the correct OF implementation(ofw_fdt,
ofw_std,
ofw_32bit, ofw_real). In RTEMS we directly map to the FDT implementation as
suggested by Sebastian.
* ofw_fdt.c contains the fdt implementation of OF interface.
Thanks,
Niteesh.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200525/302b1d33/attachment.html>
