Need help to execute/debug smpschededf02.exe on leon3
Richi Dubey richidubey at gmail.com
Tue May 26 12:55:18 UTC 2020
Hii,
Thank you for your replies. I did not load the program before
executing run on gdb. Now it works fine.
However, I need your help with one more thing. When I run gdb with
stepi or nexti to see how the code runs from the beginning to the end,
gdb always ends up going in an infinite loop in hard_reset () at
/home/richi/quick-start/src/rtems/c/src/lib/libbsp/sparc/leon3/../../../../../../bsps/sparc/shared/start/start.S:274
while only executing the following commands:
371         std    %g0,[%g2]
(gdb)
372         add    %g2,8,%g2
(gdb)
373         cmp    %g2,%g3
(gdb)
374         bleu,a zerobss
(gdb)
375         nop
while the code in start.s is:
zerobss:
        std    %g0,[%g2]
        add    %g2,8,%g2
        cmp    %g2,%g3
        bleu,a zerobss
        nop
Can someone please tell me why gdb is not going back to the main file
smpschededf02/init.c? Is it because we keep running start.s during the
entire time of execution? And how do I run gdb while going through
every instruction that init.c processes without getting stuck in an
infinite loop like this. I set up a breakpoint at Init and everythings
work fine but I am stilling missing the commands that were executed
before Init.c was called. How do I see those?
Also, If I use step with breakpoint at Init, it again goes into an
infinite loop inside apbuart_polled.c with the following commands:
20   while ( (regs->status & APBUART_STATUS_TE) == 0 ) {
(gdb)
22     __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
(gdb)
23     __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
(gdb)
24     __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
(gdb)
25     __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
Why is it running into an infinite loop?(If I use nexti, it does not
run into an infinite loop as next does get inside functions, and Init
finishes successfully).
Thanks,
Richi.
On Tue, May 26, 2020 at 12:44 AM Jiri Gaisler <jiri at gaisler.se> wrote:
> On 5/25/20 4:30 PM, Richi Dubey wrote:
> > Hii everyone,
> > When I am executing smpschededf02.exe on my leon3 bsp running on
> > sparc5 with  sparc-rtems5-sis with -m 4 -leon3 option, it fails to
> > execute properly.
> > I have built leon3 with --enable-smp option and I am guessing the
> > execution fails because I don not see any output of the test and I can
> > only see the following output:
> > ~/quick-start/rtems/5/bin$ ./sparc-rtems5-sis -leon3 -m 4
> > ~/quick-start/build/leon3/sparc-rtems5/c/leon3/testsuites/smptests/smpschededf02.exe
> >  SIS - SPARC/RISCV instruction simulator 2.21,  copyright Jiri Gaisler 2019
> >  Bug-reports to jiri at gaisler.se
> >  LEON3 emulation enabled, 4 cpus online, delta 50 clocks
> >  Loaded /home/richi/quick-start/build/leon3/sparc-rtems5/c/leon3/testsuites/smptests/smpschededf02.exe,
> > entry 0x40000000
> > cpu0> run
> > *** BEGIN OF TEST SMPSCHEDEDF 2 ***
> > *** TEST VERSION: 5.0.0.20a8361de4724658112ecd33c28fae82a15919f8
> > *** TEST STATE: EXPECTED_PASS
> > *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> > *** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5 (0b7e87143b76), Newlib fbaa096)
> > *** END OF TEST SMPSCHEDEDF 2 ***
> > cpu 1 in error mode (tt = 0x80)
> >   3491850  40016360:  91d02000   ta  0x0
> Looks good to me, test passed OK and processor is halted by RTEMS.
> > On running the program with gdb with extended-remote and debugging
> > with sis, I am encountering the following error:
> > (gdb) target extended-remote localhost:1234
> > Remote debugging using localhost:1234
> > 0x00000000 in ?? ()
> > (gdb)
> This is indeed how you start remote debugging, but then you also have to do:
> load
> run
> Then the program should run as expected ...
> Jiri.
> devel mailing list
> devel at rtems.org
