Need help to execute/debug smpschededf02.exe on leon3
Jiri Gaisler
jiri at gaisler.se
Tue May 26 18:28:30 UTC 2020
On 5/26/20 2:55 PM, Richi Dubey wrote:
> Hii,
> Thank you for your replies. I did not load the program before
> executing run on gdb. Now it works fine.
> However, I need your help with one more thing. When I run gdb with
> stepi or nexti to see how the code runs from the beginning to the end,
> gdb always ends up going in an infinite loop in hard_reset () at
> /home/richi/quick-start/src/rtems/c/src/lib/libbsp/sparc/leon3/../../../../../../bsps/sparc/shared/start/start.S:274
> while only executing the following commands:
> 371 std %g0,[%g2]
> (gdb)
> 372 add %g2,8,%g2
> (gdb)
> 373 cmp %g2,%g3
> (gdb)
> 374 bleu,a zerobss
> (gdb)
> 375 nop
> while the code in start.s is:
> zerobss:
> std %g0,[%g2]
> add %g2,8,%g2
> cmp %g2,%g3
> bleu,a zerobss
> nop
> Can someone please tell me why gdb is not going back to the main file
> smpschededf02/init.c? Is it because we keep running start.s during the
> entire time of execution?
zerobss: function is not infinite, it just loops for many thousands (millions) iterations while it clears the bss segment. SIngle-stepping though zerobss: will obviously take a VERY long time, so put a breakpoint on somewhere after it has been called.
> And how do I run gdb while going through
> every instruction that init.c processes without getting stuck in an
> infinite loop like this. I set up a breakpoint at Init and everythings
> work fine but I am stilling missing the commands that were executed
> before Init.c was called. How do I see those?
> Also, If I use step with breakpoint at Init, it again goes into an
> infinite loop inside apbuart_polled.c with the following commands:
> 20 while ( (regs->status & APBUART_STATUS_TE) == 0 ) {
> (gdb)
> 22 __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
> (gdb)
> 23 __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
> (gdb)
> 24 __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
> (gdb)
> 25 __asm__ volatile ("nop"::); __asm__ volatile ("nop"::);
> Why is it running into an infinite loop?(If I use nexti, it does not
> run into an infinite loop as next does get inside functions, and Init
> finishes successfully).
The loop is not infinite, it just loops while waiting for the UART transmitter to send out a character. nexti puts a breakpoint after the loop, that is why it finishes.
Jiri.
> Thanks,
> Richi.
> On Tue, May 26, 2020 at 12:44 AM Jiri Gaisler <jiri at gaisler.se> wrote:
>> On 5/25/20 4:30 PM, Richi Dubey wrote:
>>> Hii everyone,
>>> When I am executing smpschededf02.exe on my leon3 bsp running on
>>> sparc5 with sparc-rtems5-sis with -m 4 -leon3 option, it fails to
>>> execute properly.
>>> I have built leon3 with --enable-smp option and I am guessing the
>>> execution fails because I don not see any output of the test and I can
>>> only see the following output:
>>> ~/quick-start/rtems/5/bin$ ./sparc-rtems5-sis -leon3 -m 4
>>> ~/quick-start/build/leon3/sparc-rtems5/c/leon3/testsuites/smptests/smpschededf02.exe
>>> SIS - SPARC/RISCV instruction simulator 2.21, copyright Jiri Gaisler 2019
>>> Bug-reports to jiri at gaisler.se
>>> LEON3 emulation enabled, 4 cpus online, delta 50 clocks
>>> Loaded /home/richi/quick-start/build/leon3/sparc-rtems5/c/leon3/testsuites/smptests/smpschededf02.exe,
>>> entry 0x40000000
>>> cpu0> run
>>> *** BEGIN OF TEST SMPSCHEDEDF 2 ***
>>> *** TEST VERSION: 5.0.0.20a8361de4724658112ecd33c28fae82a15919f8
>>> *** TEST STATE: EXPECTED_PASS
>>> *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
>>> *** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5 (0b7e87143b76), Newlib fbaa096)
>>> *** END OF TEST SMPSCHEDEDF 2 ***
>>> cpu 1 in error mode (tt = 0x80)
>>> 3491850 40016360: 91d02000 ta 0x0
>> Looks good to me, test passed OK and processor is halted by RTEMS.
>>> On running the program with gdb with extended-remote and debugging
>>> with sis, I am encountering the following error:
>>> (gdb) target extended-remote localhost:1234
>>> Remote debugging using localhost:1234
>>> 0x00000000 in ?? ()
>>> (gdb)
>> This is indeed how you start remote debugging, but then you also have to do:
>> load
>> run
>> Then the program should run as expected ...
>> Jiri.
>> devel mailing list
>> devel at rtems.org
