GSoC: Porting OFW to RTEMS
Christian Mauderer oss at c-mauderer.de
Tue May 26 17:56:23 UTC 2020
Hello Niteesh,
On 25/05/2020 11:20, Niteesh G. S. wrote:
> Hello,
> I have completed the porting of the OFW code from FreeBSD to RTEMS.
> I do acknowledge the fact that we haven't decided on the directory for files
> to be placed in. The previous conversation had stopped quite a while ago.
> Christian suggested I work on the patch since that would also start the
> conversation again and also refactoring the patch to the correct directory
> will not be much of work.
> cpukit/libfreebsd was suggested as one of the directories to place the
> ported
> FreeBSD files. It is suggested to place all the source files under this
> directory.
> Since this will make the sync part easier. But this causes issues when
> porting
> BSP dependent files. Since RTEMS currently doesn't allow files in cpukit to
> reference bsp headers. I faced a similar issue during my porting process
> also.
> The OFW init function require bsp_fdt_get function to get a reference to
> the fdt
> blob. But I can't include the bsp/fdt.h header file from a source file
> under cpukit.
> We must decide the directory quickly because my project will import other
> FreeBSD sources like the pinmux driver for beaglebone into RTEMS.
Do you have a suggestion for another directory?
If cpukit makes problems (which it clearly does due to the BSP
dependencies) maybe something in bsps/shared?
> https://github.com/gs-niteesh/rtems/commits/ofw_branch
For small patches it would be better to send them to the list using "git
send-email". That allows to comment directly on the patches. But in this
case using a repo is OK because especially the import is quite big.
I'll add comments for small stuff directly on github. I hope that works ;-)
Best regards
Christian
> Please have a look at the last 6 patches for the ported work.
> Below is a short summary of the patch.
> * The openfirm.h is the OF interface that will provided to the user.
> * The openfirm.c contains the function definition for openfirm.h. The
> functions
> call the respective OFW_* functions which are responsible for choosing
> the correct implementation for OF interface.
> * ofw_if.h is the replacement for ofw_if.h in FreeBSD. This is an auto
> generated
> header in FreeBSD which choose the correct OF implementation(ofw_fdt,
> ofw_std,
> ofw_32bit, ofw_real). In RTEMS we directly map to the FDT implementation as
> suggested by Sebastian.
> * ofw_fdt.c contains the fdt implementation of OF interface.
> Thanks,
> Niteesh.
