[rtems/rsb]: Error while building and Adding Netinet cfg (dependency of PTP) [GSoC 2020]
Mritunjay Sharma mritunjaysharma394 at gmail.com
Tue May 26 18:22:28 UTC 2020
Hello everyone,
As advised I tried adding Netinet package which
is a dependency to add PTP and was causing an error
earlier, I have encountered another error as mentioned below
while testing the build for netinet.
/home/mritunjay/development/rtems/rsb/rtems/build/netinet--sparc-rtems5-1/do-build:
90: cd: can't cd to netinet
shell cmd failed: /bin/sh -ex
error: building netinet--sparc-rtems5-1
  See error report: rsb-report-netinet--sparc-rtems5-1.txt
Build Set: Time 0:00:00.667194
Attaching trace file as well.
Thanks,
Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200526/030dfed8/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200526/030dfed8/attachment-0001.obj>
