Fwd: Build Linux: FAILED 5/bsps/pc on x86_64-linux-gnu (i386-rtems5-kernel-pc686-1)
Chris Johns
chrisj at rtems.org
Thu May 28 23:20:39 UTC 2020
On 29/5/20 7:08 am, Joel Sherrill wrote:
> On Thu, May 28, 2020 at 12:54 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 28/05/2020 18:43, Joel Sherrill wrote:
> > I just did pc on the master and it failed for me.
> Works for me:
> installing: 5/bsps/pc -> /build/rtems/5
> Staging Size: 1.385GB
> Build Set: Time 0:25:50.735059
> Weird.
> I see the problem. If the prefix is somewhere new and clean, it works
> fine. If I keep using the same directory where I previously installed
> tools, it fails.
> Wonder what Chris can say about this?
I suggest taking a look at the logs in detail to see what is happening.
