Fwd: Build Linux: FAILED 5/bsps/pc on x86_64-linux-gnu (i386-rtems5-kernel-pc686-1)
Joel Sherrill
joel at rtems.org
Thu May 28 23:49:53 UTC 2020
On Thu, May 28, 2020, 6:20 PM Chris Johns <chrisj at rtems.org> wrote:
> On 29/5/20 7:08 am, Joel Sherrill wrote:
> > On Thu, May 28, 2020 at 12:54 PM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 28/05/2020 18:43, Joel Sherrill wrote:
> > > I just did pc on the master and it failed for me.
> > Works for me:
> > installing: 5/bsps/pc -> /build/rtems/5
> > Staging Size: 1.385GB
> > Build Set: Time 0:25:50.735059
> > Weird.
> > I see the problem. If the prefix is somewhere new and clean, it works
> > fine. If I keep using the same directory where I previously installed
> > tools, it fails.
> > Wonder what Chris can say about this?
> I suggest taking a look at the logs in detail to see what is happening
Thanks but I have done that to the mailing list and to a ticket. The probe
for gethostbyname fails
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200528/a432318e/attachment.html>
