[PATCH 1/5] bsps/shared/freebsd: Import OFW files from FreeBSD.
Niteesh G. S.
niteesh.gs at gmail.com
Fri May 29 10:41:40 UTC 2020
Hello,
On Fri, May 29, 2020 at 12:52 PM Sebastian Huber <
> Hello,
> since this code is not BSP-specific it should be located in cpukit. How
> many FreeBSD source files do you intend to import within this project?
This code depends on a bsp that has FDT support. We first imported it to
cpukit but then decided to move it to bsps/shared since we weren't able to
import BSP related files (bsp/fdt.h in this case) from cpukit.
The below is the link to my branch where I imported all this code under
cpukit/libfreebsd.
https://github.com/gs-niteesh/rtems/commits/test_branch
As far as my GSoC project is concerned. I will be importing the Beaglebone
pinmux driver. But in the future, we mostly plan to import drivers so we
switched
to a folder under bsps.
Thanks,
Niteesh.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200529/15c1afd9/attachment.html>
