[PATCH 1/5] bsps/shared/freebsd: Import OFW files from FreeBSD.
Sebastian Huber
Fri May 29 13:19:11 UTC 2020
On 29/05/2020 12:41, Niteesh G. S. wrote:
> Hello,
> On Fri, May 29, 2020 at 12:52 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hello,
> since this code is not BSP-specific it should be located in
> cpukit. How
> many FreeBSD source files do you intend to import within this project?
> This code depends on a bsp that has FDT support. We first imported it to
> cpukit but then decided to move it to bsps/shared since we weren't able to
> import BSP related files (bsp/fdt.h in this case) from cpukit.
Please think about how BSP dependencies can be avoided since this will
also allow us to write unit tests for this infrastructure. One option is
to add an API to register the device tree. BSPs which have a device tree
do this before the API is used. Unit tests override the device tree to
run the test cases.
