[PATCH v1 4/9] bsp/pc386: Update context switch and restore
Jan Sommer
jan.sommer at dlr.de
Sun May 31 14:22:54 UTC 2020
Uses similar flow in cpu_asm.S for i386 as for arm.
cpukit/score/cpu/i386/cpu_asm.S | 63 +++++++++++++++++++------
cpukit/score/cpu/i386/include/rtems/score/cpu.h | 4 +-
2 files changed, 51 insertions(+), 16 deletions(-)
diff --git a/cpukit/score/cpu/i386/cpu_asm.S b/cpukit/score/cpu/i386/cpu_asm.S
index 9e1e848bbd..6031f6914e 100644
--- a/cpukit/score/cpu/i386/cpu_asm.S
+++ b/cpukit/score/cpu/i386/cpu_asm.S
@@ -51,6 +51,8 @@
SYM (_CPU_Context_switch):
movl RUNCONTEXT_ARG(esp),eax /* eax = running threads context */
+ GET_SELF_CPU_CONTROL edx /* edx has address for per_CPU information */
+ movl PER_CPU_ISR_DISPATCH_DISABLE(edx),ecx
pushf /* push eflags */
popl REG_EFLAGS(eax) /* save eflags */
movl esp,REG_ESP(eax) /* save stack pointer */
@@ -58,26 +60,29 @@ SYM (_CPU_Context_switch):
movl ebx,REG_EBX(eax) /* save ebx */
movl esi,REG_ESI(eax) /* save source register */
movl edi,REG_EDI(eax) /* save destination register */
+ movl ecx, I386_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE(eax)
-#ifdef RTEMS_SMP
- /* The executing context no longer executes on this processor */
- movb $0, I386_CONTEXT_CONTROL_IS_EXECUTING_OFFSET(eax)
-#endif
+ movl eax,ecx /* ecx = running threads context */
movl HEIRCONTEXT_ARG(esp),eax /* eax = heir threads context */
#ifdef RTEMS_SMP
- /* Wait for heir context to stop execution */
-1:
- movb I386_CONTEXT_CONTROL_IS_EXECUTING_OFFSET(eax), bl
- testb bl, bl
- jne 1b
- /* The heir context executes now on this processor */
- movb $1, I386_CONTEXT_CONTROL_IS_EXECUTING_OFFSET(eax)
+ * The executing thread no longer executes on this processor. Switch
+ * the stack to the temporary interrupt stack of this processor. Mark
+ * the context of the executing thread as not executing.
+ leal PER_CPU_INTERRUPT_FRAME_AREA + CPU_INTERRUPT_FRAME_SIZE(edx),esp
+ movb $0, I386_CONTEXT_CONTROL_IS_EXECUTING_OFFSET(ecx)
+.L_check_is_executing:
+ lock bts $0,I386_CONTEXT_CONTROL_IS_EXECUTING_OFFSET(eax) /* Indicator in carry flag */
+ jc .L_get_potential_new_heir
#endif
-restore:
+/* Start restoring context */
+.L_restore:
+ movl I386_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE(eax),ecx
+ movl ecx,PER_CPU_ISR_DISPATCH_DISABLE(edx)
pushl REG_EFLAGS(eax) /* push eflags */
popf /* restore eflags */
movl REG_ESP(eax),esp /* restore stack pointer */
@@ -110,7 +115,35 @@ restore:
SYM (_CPU_Context_restore):
movl NEWCONTEXT_ARG(esp),eax /* eax = running threads context */
- jmp restore
+ jmp .L_restore
+#ifdef RTEMS_SMP
+.L_get_potential_new_heir:
+ /* We may have a new heir */
+ /* Read the executing and heir */
+ movl PER_CPU_OFFSET_EXECUTING(edx),ebx
+ movl PER_CPU_OFFSET_HEIR(edx),esi
+ * Update the executing only if necessary to avoid cache line
+ * monopolization.
+ cmp esi,ebx
+ je .L_check_is_executing
+ /* Calculate the heir context pointer */
+ addl esi,eax
+ subl ebx,eax
+ /* Update the executing */
+ movl esi,PER_CPU_OFFSET_EXECUTING(edx)
+ jmp .L_check_is_executing
+#endif
/*void _CPU_Context_save_fp_context( &fp_context_ptr )
* void _CPU_Context_restore_fp_context( &fp_context_ptr )
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpu.h b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
index 5d14455563..7669c4a0cf 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
@@ -115,9 +115,10 @@ extern "C" {
#define I386_CONTEXT_CONTROL_EDI_OFFSET 20
#define I386_CONTEXT_CONTROL_GS_0_OFFSET 24
#define I386_CONTEXT_CONTROL_GS_1_OFFSET 28
+#define I386_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 32
#ifdef RTEMS_SMP
- #define I386_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 32
+ #define I386_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 36
#endif
/* structures */
@@ -136,6 +137,7 @@ typedef struct {
uint32_t esi; /* extended source index register */
uint32_t edi; /* extended destination index flags register */
segment_descriptors gs; /* gs segment descriptor */
+ uint32_t isr_dispatch_disable;
#ifdef RTEMS_SMP
volatile bool is_executing;
#endif
2.12.3
