[PATCH v1 5/9] bsp/pc386: Define interrupt stack frame for smp
Jan Sommer
jan.sommer at dlr.de
Sun May 31 14:22:55 UTC 2020
- Defines CPU_Interrupt_frame in cpu_impl.h
- Updates isq_asm.S to save/restore registers in matching order to
interrupt frame
bsps/i386/shared/irq/irq_asm.S | 102 +++++++++++----------
cpukit/score/cpu/i386/include/rtems/score/cpu.h | 28 +++---
.../score/cpu/i386/include/rtems/score/cpuimpl.h | 2 +
3 files changed, 73 insertions(+), 59 deletions(-)
diff --git a/bsps/i386/shared/irq/irq_asm.S b/bsps/i386/shared/irq/irq_asm.S
index 2d65a79fe2..6a399f0c15 100644
--- a/bsps/i386/shared/irq/irq_asm.S
+++ b/bsps/i386/shared/irq/irq_asm.S
@@ -25,17 +25,19 @@
#endif
/* Stack frame we use for intermediate storage */
-#define ARG_OFF 0
-#define MSK_OFF 4 /* not used any more */
-#define EBX_OFF 8 /* ebx */
-#define EBP_OFF 12 /* code restoring ebp/esp relies on */
-#define ESP_OFF 16 /* esp being on top of ebp! */
+#define ARG_OFF 0
+#define EBX_OFF 4 /* ebx */
+#define EBP_OFF 8 /* code restoring ebp/esp relies on */
+#define ESP_OFF 12 /* esp being on top of ebp! */
#ifdef __SSE__
+#ifdef RTEMS_SMP
+#error SMP with SSE support has not been tested. Use at your own risk.
+#endif
/* need to be on 16 byte boundary for SSE, add 12 to do that */
#define FRM_SIZ (20+12+512)
#define SSE_OFF 32
#else
-#define FRM_SIZ 20
+#define FRM_SIZ 16
#endif
BEGIN_CODE
@@ -59,7 +61,7 @@ SYM (_ISR_Handler):
* NOTE: If the previous values of the segment registers are
* pushed, do not forget to adjust SAVED_REGS.
- * NOTE: Make sure the exit code which restores these
+ * NOTE: Make sure the Lthread_dispatch_done code restores these
* when this type of code is needed.
@@ -72,17 +74,15 @@ SYM (_ISR_Handler):
* Establish an aligned stack frame
* original sp
- * saved ebx
* saved ebp
- * saved irq mask
+ * saved ebx
* vector arg to BSP_dispatch_isr <- aligned SP
movl esp, eax
subl $FRM_SIZ, esp
- andl $ - CPU_STACK_ALIGNMENT, esp
- movl ebx, EBX_OFF(esp)
movl eax, ESP_OFF(esp)
movl ebp, EBP_OFF(esp)
+ movl ebx, EBX_OFF(esp)
* GCC versions starting with 4.3 no longer place the cld
@@ -100,10 +100,10 @@ SYM (_ISR_Handler):
/* We save SSE here (on the task stack) because we possibly
* call other C-code (besides the ISR, namely _Thread_Dispatch())
- /* don't wait here; a possible exception condition will eventually be
- * detected when the task resumes control and executes a FP instruction
+ /* don't wait here; a possible exception condition will eventually be
+ * detected when the task resumes control and executes a FP instruction
fwait
fxsave SSE_OFF(esp)
fninit /* clean-slate FPU */
movl $0x1f80, ARG_OFF(esp) /* use ARG_OFF as scratch space */
@@ -118,15 +118,9 @@ PUBLIC (ISR_STOP)
ISR_STOP:
.check_stack_switch:
movl esp, ebp /* ebp = previous stack pointer */
+ andl $ - CPU_STACK_ALIGNMENT, esp /* Make sure esp is 16 byte aligned */
-#ifdef RTEMS_SMP
- call SYM(_CPU_SMP_Get_current_processor)
- sall $PER_CPU_CONTROL_SIZE_LOG2, eax
- addl $SYM(_Per_CPU_Information), eax
- movl eax, ebx
-#else
- movl $SYM(_Per_CPU_Information), ebx
-#endif
+ GET_SELF_CPU_CONTROL ebx
/* is this the outermost interrupt? */
cmpl $0, PER_CPU_ISR_NEST_LEVEL(ebx)
@@ -161,32 +155,48 @@ nested:
movl ebp, esp
- decl PER_CPU_ISR_NEST_LEVEL(ebx) /* one less ISR nest level */
- /* If interrupts are nested, */
- /* then dispatching is disabled */
- decl PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(ebx)
- /* unnest multitasking */
- /* Is dispatch disabled */
- jne .exit /* Yes, then exit */
- cmpb $0, PER_CPU_DISPATCH_NEEDED(ebx)
- /* Is task switch necessary? */
- jne .schedule /* Yes, then call the scheduler */
- jmp .exit /* No, exit */
-.schedule:
- * the scratch registers have already been saved and we are already
- * back on the thread system stack. So we can call _Thread_Dispatch
- * directly
- call _Thread_Dispatch
- * fall through exit to restore complete contex (scratch registers
- * eip, CS, Flags).
+ * Thread dispatching is necessary and allowed if and only if
+ * dispatch_necessary == 1 and
+ * isr_dispatch_disable == 0 and
+ * thread_dispatch_disable_level == 0.
+ * Otherwise, continue with .Lthread_dispatch_done
-.exit:
+ movl PER_CPU_DISPATCH_NEEDED(ebx), eax
+ xorl PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(ebx), eax
+ decl PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(ebx)
+ orl PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(ebx), eax
+ orl PER_CPU_ISR_DISPATCH_DISABLE(ebx), eax
+ decl PER_CPU_ISR_NEST_LEVEL(ebx) /* one less ISR nest level */
+ cmpl $0, eax
+ jne .Lthread_dispatch_done /* Is task switch necessary? */
+.Ldo_thread_dispatch:
+ /* Set ISR dispatch disable and thread dispatch disable level to one */
+ movl $1, PER_CPU_ISR_DISPATCH_DISABLE(ebx)
+ movl $1, PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL(ebx)
+ /* Call Thread_Do_dispatch(), this function will enable interrupts */
+ push $EFLAGS_INTR_ENABLE /* Set interrupt flag manually */
+ push ebx
+ call _Thread_Do_dispatch
+ /* Disable interrupts */
+ cli
+ addl $8, esp
+ /* Sometimes after returning from _Thread_Do_dispatch current CPU and ebx ptr are different */
+ cmpb $0, PER_CPU_DISPATCH_NEEDED(ebx)
+ jne .Ldo_thread_dispatch
+ /* We are done with thread dispatching */
+ movl $0, PER_CPU_ISR_DISPATCH_DISABLE(ebx)
+ * fall through Lthread_dispatch_done to restore complete contex (scratch registers
+ * eip, CS, Flags).
+.Lthread_dispatch_done:
#ifdef __SSE__
fwait
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpu.h b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
index 7669c4a0cf..0145ff8db3 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpu.h
@@ -264,25 +264,27 @@ typedef void (*cpuExcHandlerType) (CPU_Exception_frame*);
extern cpuExcHandlerType _currentExcHandler;
extern void rtems_exception_init_mngt(void);
-#ifdef RTEMS_SMP
- /* Throw compile-time error to indicate incomplete support */
- #error "i386 targets do not support SMP.\
- See: https://devel.rtems.org/ticket/3335"
- * This size must match the size of the CPU_Interrupt_frame, which must be
- * used in the SMP context switch code, which is incomplete at the moment.
- #define CPU_INTERRUPT_FRAME_SIZE 4
-#endif
* This port does not pass any frame info to the
* interrupt handler.
typedef struct {
- uint32_t todo_replace_with_apt_registers;
+/* allow for 16B alignment (worst case 12 Bytes more) and isr right after pushfl */
+ uint32_t reserved[3];
+/* registers saved by _ISR_Handler */
+ uint32_t isr_vector;
+ uint32_t ebx;
+ uint32_t ebp;
+ uint32_t esp;
+/* registers saved by rtems_irq_prologue_##_vector */
+ uint32_t edx;
+ uint32_t ecx;
+ uint32_t eax;
+/* registers saved by CPU */
+ uint32_t eip;
+ uint32_t cs;
+ uint32_t eflags;
} CPU_Interrupt_frame;
typedef enum {
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
index a89b1fedfb..570b5cc167 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
@@ -29,6 +29,8 @@
#define CPU_PER_CPU_CONTROL_SIZE 0
+#define CPU_INTERRUPT_FRAME_SIZE 52
#ifndef ASM
#ifdef __cplusplus
2.12.3
