[PATCH v4 0/1] Test for clock_nanosleep() with CLOCK_MONOTONIC option
Utkarsh Rai utkarsh.rai60 at gmail.com
Thu Nov 5 16:16:08 UTC 2020
On Thu, Nov 5, 2020 at 12:13 AM Gedare Bloom <gedare at rtems.org> wrote:
> i need to find time to look at this, and try it out.
> Does this compile? e.g., I don't see a definition of OPERATION_COUNT
Yes,  the OPERATION_COUNT is defined in "timesys.h".
> On Wed, Oct 28, 2020 at 7:34 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
> wrote:
> > Ping.
> > On Wed, Oct 21, 2020 at 8:58 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
> wrote:
> >> This patch has the tests for clock_nanosleep with the CLOCK_MONOTONIC
> option.
> >> The psxtests/psxclocknanosleep01/.. tests for valid timeout values as
> well as
> >> for the effect on timeout delay when REALTIME clock is modified(no
> effect).
> >> The timing tests are the similar to that for the REALTIME
> option(yielding and
> >> blocking).
> >> Utkarsh Rai (1):
> >>  .../psxtests/psxclocknanosleep01.yml          |  19 +++
> >>  spec/build/testsuites/psxtmtests/grp.yml      |   4 +
> >>  .../psxtmtests/psxtmclocknanosleep04.yml      |  19 +++
> >>  .../psxtmtests/psxtmclocknanosleep05.yml      |  19 +++
> >>  .../psxtests/psxclocknanosleep01/init.c       | 145 ++++++++++++++++++
> >>  .../psxclocknanosleep01.doc                   |  13 ++
> >>  .../psxclocknanosleep01.scn                   |  50 ++++++
> >>  .../psxtmtests/psxtmclocknanosleep04/init.c   |  70 +++++++++
> >>  .../psxtmtests/psxtmclocknanosleep05/init.c   | 116 ++++++++++++++
> >>  9 files changed, 455 insertions(+)
> >>  create mode 100644
> spec/build/testsuites/psxtests/psxclocknanosleep01.yml
> >>  create mode 100644
> spec/build/testsuites/psxtmtests/psxtmclocknanosleep04.yml
> >>  create mode 100644
> spec/build/testsuites/psxtmtests/psxtmclocknanosleep05.yml
> >>  create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
> >>  create mode 100644
> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> >>  create mode 100644
> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> >>  create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep04/init.c
> >>  create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep05/init.c
> >> 2.25.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201105/0dda7a15/attachment.html>
