[PATCH v4 0/1] Test for clock_nanosleep() with CLOCK_MONOTONIC option
Utkarsh Rai utkarsh.rai60 at gmail.com
Mon Nov 30 15:40:33 UTC 2020
Hello,
Is there any update on this patch?
On Wed, Oct 28, 2020 at 7:04 PM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> Ping.
> On Wed, Oct 21, 2020 at 8:58 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
> wrote:
>> This patch has the tests for clock_nanosleep with the CLOCK_MONOTONIC
>> option.
>> The psxtests/psxclocknanosleep01/.. tests for valid timeout values as
>> well as
>> for the effect on timeout delay when REALTIME clock is modified(no
>> effect).
>> The timing tests are the similar to that for the REALTIME option(yielding
>> and
>> blocking).
>> Utkarsh Rai (1):
>>  .../psxtests/psxclocknanosleep01.yml          |  19 +++
>>  spec/build/testsuites/psxtmtests/grp.yml      |   4 +
>>  .../psxtmtests/psxtmclocknanosleep04.yml      |  19 +++
>>  .../psxtmtests/psxtmclocknanosleep05.yml      |  19 +++
>>  .../psxtests/psxclocknanosleep01/init.c       | 145 ++++++++++++++++++
>>  .../psxclocknanosleep01.doc                   |  13 ++
>>  .../psxclocknanosleep01.scn                   |  50 ++++++
>>  .../psxtmtests/psxtmclocknanosleep04/init.c   |  70 +++++++++
>>  .../psxtmtests/psxtmclocknanosleep05/init.c   | 116 ++++++++++++++
>>  9 files changed, 455 insertions(+)
>>  create mode 100644 spec/build/testsuites/psxtests/psxclocknanosleep01.yml
>>  create mode 100644
>> spec/build/testsuites/psxtmtests/psxtmclocknanosleep04.yml
>>  create mode 100644
>> spec/build/testsuites/psxtmtests/psxtmclocknanosleep05.yml
>>  create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
>>  create mode 100644
>> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
>>  create mode 100644
>> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
>>  create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep04/init.c
>>  create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep05/init.c
>> 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201130/6af69b48/attachment.html>
