[PATCH 1/2] c-user: Generate Event Manager documentation
Mon Nov 9 14:47:31 UTC 2020
The manager documentation is a consolidation of the comments in Doxygen
markup and the documentation sources in Sphinx markup.  The
documentation was transfered to interface specification items.  This
header file was generated from the items by a script.
Update #3993.
 c-user/event/directives.rst   | 320 +++++++++++++++++++++-------------
 c-user/event/introduction.rst |  31 +++-
 2 files changed, 230 insertions(+), 121 deletions(-)
diff --git a/c-user/event/directives.rst b/c-user/event/directives.rst
index ef94115..95ae456 100644
--- a/c-user/event/directives.rst
+++ b/c-user/event/directives.rst
@@ -1,142 +1,228 @@
 .. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
 .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+.. Do not manually edit this file.  It is part of the RTEMS quality process
+.. and was automatically generated.
+.. If you find something that needs to be fixed or worded better please
+.. post a report to an RTEMS mailing list or raise a bug report:
+.. https://docs.rtems.org/branches/master/user/support/bugs.html
+.. For information on updating and regenerating please refer to:
+.. https://docs.rtems.org/branches/master/eng/req/howto.html
+.. _EventManagerDirectives:
 Directives
-This section details the event manager's directives.  A subsection is dedicated
-to each of this manager's directives and describes the calling sequence,
-related constants, usage, and status codes.
+This section details the directives of the Event Manager. A subsection is
+dedicated to each of this manager's directives and lists the calling sequence,
+parameters, description, return values, and notes of the directive.
+.. Generated from spec:/rtems/event/if/send
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_event_send()
+.. _InterfaceRtemsEventSend:
+rtems_event_send()
+Sends the event set to the task.
+.. rubric:: CALLING SEQUENCE:
+.. code-block:: c
+    rtems_status_code rtems_event_send( rtems_id id, rtems_event_set event_in );
+.. rubric:: PARAMETERS:
+``id``
+    This parameter is the identifier of the target task to receive the event
+    set.
+``event_in``
+    This parameter is the event set to send.
+.. rubric:: DESCRIPTION:
-.. index:: send event set to a task
-.. index:: rtems_event_send
+This directive sends the event set, ``event_in``, to the target task identified
+by ``id``.  Based upon the state of the target task, one of the following
+situations applies:
-.. _rtems_event_send:
+* The target task is blocked waiting for events, then
-EVENT_SEND - Send event set to a task
+  * if the waiting task's input event condition is satisfied, then the task is
+    made ready for execution, or
-CALLING SEQUENCE:
-    .. code-block:: c
+  * otherwise, the event set is posted but left pending and the task remains
+    blocked.
-        rtems_status_code rtems_event_send (
-            rtems_id         id,
-            rtems_event_set  event_in
+* The target task is not waiting for events, then the event set is posted and
+  left pending.
-DIRECTIVE STATUS CODES:
-    .. list-table::
-     :class: rtems-table
+.. rubric:: RETURN VALUES:
-     * - ``RTEMS_SUCCESSFUL``
-       - event set sent successfully
-     * - ``RTEMS_INVALID_ID``
-       - invalid task id
+:c:macro:`RTEMS_SUCCESSFUL`
+    The requested operation was successful.
-DESCRIPTION:
-    This directive sends an event set, event_in, to the task specified by id.
-    If a blocked task's input event condition is satisfied by this directive,
-    then it will be made ready.  If its input event condition is not satisfied,
-    then the events satisfied are updated and the events not satisfied are left
-    pending.  If the task specified by id is not blocked waiting for events,
-    then the events sent are left pending.
+:c:macro:`RTEMS_INVALID_ID`
+    There was no task with the specified identifier.
-NOTES:
-    Specifying ``RTEMS_SELF`` for id results in the event set being sent to the
-    calling task.
+.. rubric:: NOTES:
-    Identical events sent to a task are not queued.  In other words, the
-    second, and subsequent, posting of an event to a task before it can perform
-    an ``rtems_event_receive`` has no effect.
+Events can be sent by tasks or an :term:`ISR`.
-    The calling task will be preempted if it has preemption enabled and a
-    higher priority task is unblocked as the result of this directive.
+Specifying :c:macro:`RTEMS_SELF` for ``id`` results in the event set being sent
+to the calling task.
-    Sending an event set to a global task which does not reside on the local
-    node will generate a request telling the remote node to send the event set
-    to the appropriate task.
+The event set to send shall be built by a *bitwise or* of the desired events.
+The set of valid events is :c:macro:`RTEMS_EVENT_0` through
+:c:macro:`RTEMS_EVENT_31`.  If an event is not explicitly specified in the set,
+then it is not present.
+Identical events sent to a task are not queued.  In other words, the second,
+and subsequent, posting of an event to a task before it can perform an
+:ref:`InterfaceRtemsEventReceive` has no effect.
+The calling task will be preempted if it has preemption enabled and a higher
+priority task is unblocked as the result of this directive.
+Sending an event set to a global task which does not reside on the local node
+will generate a request telling the remote node to send the event set to the
+appropriate task.
+.. Generated from spec:/rtems/event/if/receive
 .. raw:: latex
-   \clearpage
-.. index:: receive event condition
-.. index:: rtems_event_receive
-.. _rtems_event_receive:
-EVENT_RECEIVE - Receive event condition
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_event_receive (
-            rtems_event_set  event_in,
-            rtems_option     option_set,
-            rtems_interval   ticks,
-            rtems_event_set *event_out
-    .. list-table::
-       - event received successfully
-     * - ``RTEMS_UNSATISFIED``
-       - input event not satisfied (``RTEMS_NO_WAIT``)
-     * - ``RTEMS_INVALID_ADDRESS``
-       - ``event_out`` is NULL
-     * - ``RTEMS_TIMEOUT``
-       - timed out waiting for event
-DESCRIPTION:
-    This directive attempts to receive the event condition specified in
-    event_in.  If event_in is set to ``RTEMS_PENDING_EVENTS``, then the current
-    pending events are returned in event_out and left pending.  The
-    ``RTEMS_WAIT`` and ``RTEMS_NO_WAIT`` options in the option_set parameter
-    are used to specify whether or not the task is willing to wait for the
-    event condition to be satisfied. ``RTEMS_EVENT_ANY`` and
-    ``RTEMS_EVENT_ALL`` are used in the option_set parameter are used to
-    specify whether a single event or the complete event set is necessary to
-    satisfy the event condition.  The event_out parameter is returned to the
-    calling task with the value that corresponds to the events in event_in that
-    were satisfied.
-    If pending events satisfy the event condition, then event_out is set to the
-    satisfied events and the pending events in the event condition are cleared.
-    If the event condition is not satisfied and ``RTEMS_NO_WAIT`` is specified,
-    then event_out is set to the currently satisfied events.  If the calling
-    task chooses to wait, then it will block waiting for the event condition.
-    If the calling task must wait for the event condition to be satisfied, then
-    the timeout parameter is used to specify the maximum interval to wait.  If
-    it is set to ``RTEMS_NO_TIMEOUT``, then the calling task will wait forever.
-NOTES:
-    This directive only affects the events specified in event_in.  Any pending
-    events that do not correspond to any of the events specified in event_in
-    will be left pending.
-    The following event receive option constants are defined by RTEMS:
-    .. list-table::
-     * - ``RTEMS_WAIT``
-       - task will wait for event (default)
-     * - ``RTEMS_NO_WAIT``
-       - task should not wait
-     * - ``RTEMS_EVENT_ALL``
-       - return after all events (default)
-     * - ``RTEMS_EVENT_ANY``
-       - return after any events
-    A clock tick is required to support the functionality of this directive.
+    \clearpage
+.. index:: rtems_event_receive()
+.. _InterfaceRtemsEventReceive:
+rtems_event_receive()
+Receives or gets an event set from the calling task.
+.. code-block:: c
+    rtems_status_code rtems_event_receive(
+      rtems_event_set  event_in,
+      rtems_option     option_set,
+      rtems_interval   ticks,
+      rtems_event_set *event_out
+``event_in``
+    This parameter is the event set of interest.  Use
+    :c:macro:`RTEMS_PENDING_EVENTS` to get the pending events.
+``option_set``
+    This parameter is the option set.
+``ticks``
+    This parameter is the timeout in clock ticks if the :c:macro:`RTEMS_WAIT`
+    option is set.  Use :c:macro:`RTEMS_NO_TIMEOUT` to wait potentially
+    forever.
+``event_out``
+    This parameter is the pointer to an event set.  The received or pending
+    events are stored in the referenced event set if the operation was
+    successful.
+This directive can be used to
+* get the pending events of the calling task, or
+* receive events.
+To **get the pending events** use the constant :c:macro:`RTEMS_PENDING_EVENTS`
+for the ``event_in`` parameter.  The pending events are returned to the calling
+task but the event set of the task is left unaltered.  The ``option_set`` and
+``ticks`` parameters are ignored in this case.  The directive returns
+immediately and does not block.
+To **receive events** you have to define an input event condition and some
+options.  The **option set** specified in ``option_set`` defines
+* if the task will wait or poll for the events, and
+* if the task wants to receive all or any of the input events.
+The option set is built through a *bitwise or* of the option constants
+described below.
+The task can **wait** or **poll** for the events.
+* **Waiting** for events is the default and can be emphasized through the use
+  of the :c:macro:`RTEMS_WAIT` option.  The ``ticks`` parameter defines how
+  long the task is willing to wait.  Use :c:macro:`RTEMS_NO_TIMEOUT` to wait
+  potentially forever, otherwise set a timeout interval in clock ticks.
+* Not waiting for events (**polling**) is selected by the
+  :c:macro:`RTEMS_NO_WAIT` option.  If this option is defined, then the
+  ``ticks`` parameter is ignored.
+The task can receive **all** or **any** of the input events specified in
+``event_in``.
+* Receiving **all** input events is the default and can be emphasized through
+  the use of the :c:macro:`RTEMS_EVENT_ALL` option.
+* Receiving **any** of the input events is selected by the
+  :c:macro:`RTEMS_EVENT_ANY` option.
+:c:macro:`RTEMS_INVALID_ADDRESS`
+    The ``event_out`` parameter was `NULL
+    <https://en.cppreference.com/w/c/types/NULL>`_.
+:c:macro:`RTEMS_UNSATISFIED`
+    The events of interest were not immediately available.
+:c:macro:`RTEMS_TIMEOUT`
+    The events of interest were not available within the specified timeout
+    interval.
+.. rubric:: NOTES:
+This directive shall be called by a task.  Calling this directive from
+interrupt context is undefined behaviour.
+This directive only affects the events specified in ``event_in``. Any pending
+events that do not correspond to any of the events specified in ``event_in``
+will be left pending.
+To receive all events use the event set constant :c:macro:`RTEMS_ALL_EVENTS`
+for the ``event_in`` parameter.  Do not confuse this event set constant with
+the directive option :c:macro:`RTEMS_EVENT_ALL`.
+A task can **receive all of the pending events** by calling the directive with
+a value of :c:macro:`RTEMS_ALL_EVENTS` for the ``event_in`` parameter and the
+bitwise or of the :c:macro:`RTEMS_NO_WAIT` and :c:macro:`RTEMS_EVENT_ANY`
+options for the ``option_set`` parameter.  The pending events are returned and
+the event set of the task is cleared.  If no events are pending then the
+:c:macro:`RTEMS_UNSATISFIED` status code will be returned.
diff --git a/c-user/event/introduction.rst b/c-user/event/introduction.rst
index fb63e42..cd7b127 100644
--- a/c-user/event/introduction.rst
+++ b/c-user/event/introduction.rst
@@ -1,13 +1,36 @@
+.. Generated from spec:/rtems/event/if/group
+.. _EventManagerIntroduction:
 Introduction
-The event manager provides a high performance method of intertask communication
-and synchronization.  The directives provided by the event manager are:
+.. The following list was generated from:
+.. spec:/rtems/event/if/send
+.. spec:/rtems/event/if/receive
+The Event Manager provides a high performance method of inter-task
+communication and synchronization. The directives provided by the Event Manager
+are:
-- :ref:`rtems_event_send`
+* :ref:`InterfaceRtemsEventSend` - Sends the event set to the task.
-- :ref:`rtems_event_receive`
+* :ref:`InterfaceRtemsEventReceive` - Receives or gets an event set from the
+  calling task.
2.26.2
