[PATCH 1/2] c-user: Generate Event Manager documentation
Mon Nov 9 23:03:04 UTC 2020
On 10/11/20 1:47 am, Sebastian Huber wrote:
> The manager documentation is a consolidation of the comments in Doxygen
> markup and the documentation sources in Sphinx markup.  The
> documentation was transfered to interface specification items.  This
> header file was generated from the items by a script.
> Update #3993.
>  c-user/event/directives.rst   | 320 +++++++++++++++++++++-------------
>  c-user/event/introduction.rst |  31 +++-
>  2 files changed, 230 insertions(+), 121 deletions(-)
> diff --git a/c-user/event/directives.rst b/c-user/event/directives.rst
> index ef94115..95ae456 100644
> --- a/c-user/event/directives.rst
> +++ b/c-user/event/directives.rst
> @@ -1,142 +1,228 @@
>  .. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>  .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
> +.. Do not manually edit this file.  It is part of the RTEMS quality process
> +.. and was automatically generated.
I am wondering if we need to pull back a little from "Do not manually edit this
file"? A patch to this file that fixes something may be better than not getting
a fix and being notified of a problem. What about ...
 .. This file has been automatically generated and is under the control of
 .. the RTEMS quality process. Manual edits to the following content may be
 .. lost.
> +.. If you find something that needs to be fixed or worded better please
> +.. post a report to an RTEMS mailing list or raise a bug report:
> +.. https://docs.rtems.org/branches/master/user/support/bugs.html
> +.. For information on updating and regenerating please refer to:
> +.. https://docs.rtems.org/branches/master/eng/req/howto.html
