[PATCH 06/11] rtems: Generate <rtems/rtems/options.h>
    Sebastian Huber
    Mon Nov  9 14:49:34 UTC 2020
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
 cpukit/include/rtems/rtems/options.h | 132 +++++++++++++++++++--------
 1 file changed, 96 insertions(+), 36 deletions(-)
diff --git a/cpukit/include/rtems/rtems/options.h b/cpukit/include/rtems/rtems/options.h
index e50c4d1429..b7f3692d33 100644
--- a/cpukit/include/rtems/rtems/options.h
+++ b/cpukit/include/rtems/rtems/options.h
@@ -1,80 +1,140 @@
  * @file
- * @ingroup ClassicOptions
+ * @brief This header file provides the Classic API directive options.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 1989, 2008 On-Line Applications Research Corporation (OAR)
+ * are met:
- * This include file contains information which defines the
- * options available on many directives.
-/* COPYRIGHT (c) 1989-2008.
- * On-Line Applications Research Corporation (OAR).
+ * Do not manually edit this file.  It is part of the RTEMS quality process
+ * and was automatically generated.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * If you find something that needs to be fixed or worded better please
+ * post a report to an RTEMS mailing list or raise a bug report:
+ * https://docs.rtems.org/branches/master/user/support/bugs.html
+ * For information on updating and regenerating please refer to:
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+/* Generated from spec:/rtems/option/if/header */
 #ifndef _RTEMS_RTEMS_OPTIONS_H
 #define _RTEMS_RTEMS_OPTIONS_H
-#include <rtems/score/basedefs.h>
+#include <stdint.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
+/* Generated from spec:/rtems/option/if/group */
- * @defgroup ClassicOptions Classic API Options
+ * @defgroup RTEMSAPIClassicOptions Directive Options
  * @ingroup RTEMSAPIClassic
- * This encapsulates functionality related to the options argument
- * to Classic API blocking operations. The primary option is whether
- * or not a task is willing to wait for the operation to complete.
+ * @brief This group contains the Classic API directive options.
+/* Generated from spec:/rtems/option/if/default */
- *  The following type defines the control block used to manage
- *  option sets.
+ * @ingroup RTEMSAPIClassicOptions
+ * @brief This option constant represents the default option set.
-typedef uint32_t   rtems_option;
+#define RTEMS_DEFAULT_OPTIONS 0x00000000
+/* Generated from spec:/rtems/option/if/event-all */
- *  The following constants define the individual options which may
- *  be used to compose an option set.
+ * @brief This option constant indicates that the task wishes to wait until all
+ *   events of interest are available in rtems_event_receive() and
+ *   rtems_event_system_receive().
-#define RTEMS_DEFAULT_OPTIONS   0x00000000
+#define RTEMS_EVENT_ALL 0x00000000
+/* Generated from spec:/rtems/option/if/event-any */
- *  This option constants indicates that the task is to wait on resource.
+ * @brief This option constant indicates that the task wishes to wait until at
+ *   least one of the events of interest is available in rtems_event_receive()
+ *   and rtems_event_system_receive().
-#define RTEMS_WAIT      0x00000000
+#define RTEMS_EVENT_ANY 0x00000002
+/* Generated from spec:/rtems/option/if/no-wait */
- *  This option constants indicates that the task is to not wait on
- *  the resource.  If it is not available, return immediately with
- *  a status to indicate unsatisfied.
+ * @brief This option constant indicates that the task does not want to wait on
+ *   the resource.
+ * If the resource is not available, then the directives shall return
+ * immediately with a status to indicate that the request is unsatisfied.
-#define RTEMS_NO_WAIT   0x00000001
+#define RTEMS_NO_WAIT 0x00000001
+/* Generated from spec:/rtems/option/if/option */
- *  This option constants indicates that the task wishes to wait until
- *  all events of interest are available.
+ * @brief This type represents a Classic API directive option set.
-#define RTEMS_EVENT_ALL 0x00000000
+typedef uint32_t rtems_option;
+/* Generated from spec:/rtems/option/if/wait */
- *  ANY events of interest are available.
+ * @brief This option constant indicates that the task wants to wait on the
+ *   resource.
+ * If the resource is not available, then the task shall block and wait for
+ * request completion.
-#define RTEMS_EVENT_ANY 0x00000002
+#define RTEMS_WAIT 0x00000000
 #ifdef __cplusplus
 #endif
-#endif
-/* end of include file */
+#endif /* _RTEMS_RTEMS_OPTIONS_H */
2.26.2
