[PATCH 05/11] rtems: Generate <rtems/rtems/modes.h>
Mon Nov 9 14:49:33 UTC 2020
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
 cpukit/include/rtems/rtems/modes.h | 259 +++++++++++++++++++++--------
 1 file changed, 192 insertions(+), 67 deletions(-)
diff --git a/cpukit/include/rtems/rtems/modes.h b/cpukit/include/rtems/rtems/modes.h
index ccaef240d7..bfd69715e5 100644
--- a/cpukit/include/rtems/rtems/modes.h
+++ b/cpukit/include/rtems/rtems/modes.h
@@ -1,129 +1,254 @@
  * @file
- * @ingroup ClassicModes
+ * @brief This header file provides the task modes API of the Task Manager.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2008 On-Line Applications Research Corporation (OAR)
- * This include file contains all constants and structures associated
- * with the RTEMS thread and RTEMS_ASR modes.
+ * are met:
-/* COPYRIGHT (c) 1989-2013.
- * On-Line Applications Research Corporation (OAR).
+ * Do not manually edit this file.  It is part of the RTEMS quality process
+ * and was automatically generated.
+ * If you find something that needs to be fixed or worded better please
+ * post a report to an RTEMS mailing list or raise a bug report:
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * https://docs.rtems.org/branches/master/user/support/bugs.html
+ * For information on updating and regenerating please refer to:
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+/* Generated from spec:/rtems/mode/if/header */
 #ifndef _RTEMS_RTEMS_MODES_H
 #define _RTEMS_RTEMS_MODES_H
+#include <stdint.h>
 #include <rtems/score/cpu.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
+/* Generated from spec:/rtems/mode/if/group */
- *  @defgroup ClassicModes Modes
+ * @defgroup RTEMSAPIClassicModes Task Modes
- *  @ingroup RTEMSAPIClassic
+ * @ingroup RTEMSAPIClassic
- *  This encapsulates functionality related to the task modes supported
- *  by the Classic API Task Manager.
+ * @brief This group contains the Classic API task modes.
+/* Generated from spec:/rtems/mode/if/all-mode-masks */
- *  The following type defines the control block used to manage
- *  each a mode set.
+ * @ingroup RTEMSAPIClassicModes
+ * @brief This task mode constant is a bit mask with all mode bits set.
-typedef uint32_t   rtems_mode;
+#define RTEMS_ALL_MODE_MASKS 0x0000ffff
+/* Generated from spec:/rtems/mode/if/asr */
- *  The following constants define the individual modes and masks
- *  which may be used to compose a mode set and to alter modes.
+ * @brief This task mode constant indicates that signal processing is disabled.
-#define RTEMS_ALL_MODE_MASKS     0x0000ffff
+#define RTEMS_ASR 0x00000000
+/* Generated from spec:/rtems/mode/if/asr-mask */
- *  This mode constant is the default mode set.
+ * @brief This mode constant corresponds to the signal enable/disable bit.
-#define RTEMS_DEFAULT_MODES     0x00000000
+#define RTEMS_ASR_MASK 0x00000400
+/* Generated from spec:/rtems/mode/if/current-mode */
- *  This mode constant is used when the user wishes to obtain their
- *  current execution mode.
+ * @brief This task mode constant indicates that the current task mode of the
+ *   executing task shall be returned by rtems_task_mode().
-#define RTEMS_CURRENT_MODE      0
+#define RTEMS_CURRENT_MODE 0
-/** This mode constant corresponds to the timeslice enable/disable bit. */
-#define RTEMS_TIMESLICE_MASK  0x00000200
+/* Generated from spec:/rtems/mode/if/default */
-/** This mode constant corresponds to the preemption enable/disable bit. */
-#define RTEMS_PREEMPT_MASK    0x00000100
+ * @brief This task mode constant represents the default mode set.
+#define RTEMS_DEFAULT_MODES 0x00000000
-/** This mode constant corresponds to the signal enable/disable bit. */
-#define RTEMS_ASR_MASK        0x00000400
+/* Generated from spec:/rtems/mode/if/interrupt-mask */
-/** This mode constant corresponds to the interrupt enable/disable bits. */
-#define RTEMS_INTERRUPT_MASK  CPU_MODES_INTERRUPT_MASK
+ * @brief This task mode constant corresponds to the interrupt enable/disable
+ *   bits.
+#define RTEMS_INTERRUPT_MASK CPU_MODES_INTERRUPT_MASK
-/** This mode constant is used to indicate preemption is enabled. */
-#define RTEMS_PREEMPT      0x00000000
-/** This mode constant is used to indicate preemption is disabled. */
-#define RTEMS_NO_PREEMPT   0x00000100
+/* Generated from spec:/rtems/mode/if/interrupt-level */
-/** This mode constant is used to indicate timeslicing is disabled. */
-#define RTEMS_NO_TIMESLICE 0x00000000
-/** This mode constant is used to indicate timeslicing is enabled. */
-#define RTEMS_TIMESLICE    0x00000200
+ * @brief Maps the interrupt level to the associated processor-dependent task
+ *   mode interrupt level.
+ * The Classic API supports 256 interrupt levels using the least significant
+ * eight bits of the mode set.  On any particular processor variant, fewer than
+ * 256 levels may be supported.  At least level 0 (all interrupts enabled) and
+ * level 1 (interrupts disabled, on most architectures) are supported.
+ * @param _interrupt_level is the interrupt level to map.
+ * @return null Returns the processor-dependent task mode interrupt level
+ *   associated with the interrupt level.
+#define RTEMS_INTERRUPT_LEVEL( _interrupt_level ) \
+  ( ( _interrupt_level ) & RTEMS_INTERRUPT_MASK )
-/** This mode constant is used to indicate signal processing is enabled. */
-#define RTEMS_ASR          0x00000000
-/** This mode constant is used to indicate signal processing is disabled. */
-#define RTEMS_NO_ASR       0x00000400
+/* Generated from spec:/rtems/mode/if/interrupt-mask-constant */
- * @brief RTEMS_INTERRUPT_LEVEL
- * This function returns the processor dependent interrupt
- * level which corresponds to the requested interrupt level.
+ * @brief This task mode constant has the same value as #RTEMS_INTERRUPT_MASK.
- * @note RTEMS supports 256 interrupt levels using the least
- *       significant eight bits of MODES.CONTROL. On any
- *       particular CPU, fewer than 256 levels may be supported.
+ * This task mode constant is used by bindings from languages other than C and
+ * C++.
-#define RTEMS_INTERRUPT_LEVEL( _mode_set ) \
-  ( (_mode_set) & RTEMS_INTERRUPT_MASK )
+extern const uint32_t rtems_interrupt_mask;
+/* Generated from spec:/rtems/mode/if/mode */
- *  @brief Interrupt Mask Variable
- *  This variable is used by bindings from languages other than C and C++.
+ * @brief This type represents a Classic API task mode set.
-extern const uint32_t rtems_interrupt_mask;
+typedef uint32_t rtems_mode;
+/* Generated from spec:/rtems/mode/if/interrupt-level-body */
- * @brief Body for RTEMS_INTERRUPT_LEVEL Macro
- * @param[in] level is the desired interrupt level
- * @retval This methods returns a mode with the desired interrupt
- *         @a level in the proper bitfield location.
+ * This function is used by bindings from languages other than C and C++.
- * @note This variable is used by bindings from languages other than
- *       C and C++.
+ * @param level is the interrupt level to map.
+ * @return Returns RTEMS_INTERRUPT_LEVEL() for the interrupt level.
-rtems_mode rtems_interrupt_level_body(
-  uint32_t   level
+rtems_mode rtems_interrupt_level_body( uint32_t level );
+/* Generated from spec:/rtems/mode/if/no-asr */
+#define RTEMS_NO_ASR 0x00000400
+/* Generated from spec:/rtems/mode/if/no-preempt */
+ * @brief This task mode constant indicates that preemption is disabled.
+#define RTEMS_NO_PREEMPT 0x00000100
+/* Generated from spec:/rtems/mode/if/no-timeslice */
+ * @brief This task mode constant indicates that timeslicing is disabled.
+#define RTEMS_NO_TIMESLICE 0x00000000
+/* Generated from spec:/rtems/mode/if/preempt */
+ * @brief This task mode constant indicates that preemption is enabled.
+#define RTEMS_PREEMPT 0x00000000
+/* Generated from spec:/rtems/mode/if/preempt-mask */
+ * @brief This task mode constant corresponds to the preemption enable/disable
+ *   bit.
+#define RTEMS_PREEMPT_MASK 0x00000100
+/* Generated from spec:/rtems/mode/if/timeslice */
+ * @brief This task mode constant indicates that timeslicing is enabled.
+#define RTEMS_TIMESLICE 0x00000200
+/* Generated from spec:/rtems/mode/if/timeslice-mask */
+ * @brief This task mode constant corresponds to the timeslice enable/disable
+ *   bit.
+#define RTEMS_TIMESLICE_MASK 0x00000200
 #ifdef __cplusplus
 #endif
-#endif
-/* end of include file */
+#endif /* _RTEMS_RTEMS_MODES_H */
2.26.2
