[PATCH 00/11] Generate some header files
Wed Nov 11 00:18:09 UTC 2020
On 10/11/20 5:41 pm, Sebastian Huber wrote:
> On 10/11/2020 00:05, Chris Johns wrote:
>> On 10/11/20 1:49 am, Sebastian Huber wrote:
>>> This patch set replaces some hand written header files of the Classic
>>> API with header files generated from specification items.  The main
>>> parts are the Event Manager and the Partition Manager.  The patches for
>>> the RTEMS Classic API Guide of these two managers is available here:
>>> https://lists.rtems.org/pipermail/devel/2020-November/063122.html
>>> I tried to follow the updated Doxygen guidelines:
>>> https://lists.rtems.org/pipermail/devel/2020-November/063119.html
>>> Sebastian Huber (11):
>>>    rtems: Include missing header file
>>>    rtems: Generate <rtems/config.h>
>>>    rtems: Generate <rtems/rtems/config.h>
>>>    rtems: Generate <rtems/rtems/status.h>
>>>    rtems: Generate <rtems/rtems/modes.h>
>>>    rtems: Generate <rtems/rtems/options.h>
>>>    rtems: Generate <rtems/rtems/types.h>
>>>    rtems: Generate <rtems/rtems/attr.h>
>>>    rtems: Generate <rtems/rtems/event.h>
>>>    rtems: Generate <rtems/rtems/part.h>
>>>    rtems: Generate <rtems/score/basedefs.h>
>> Do these files need something that indicates they are generated and part of the
>> RTEMS Quality Process (RQP?)?
>> I could not see anything.
> All the generated files have the standard header and the generated by comments
> or do you mean something else?
I was thinking of something like the recent change to the documentation source:
 * This file is part of the RTEMS quality process and was automatically
 * generated. If you find something that needs to be fixed or changed
 * please post a report or patch to an RTEMS mailing list or raise a bug
 * report.
I do not think we need the links as someone wanting to change an API header file
should know there are mailing lists and a bug reporting system.
