[PATCH 00/11] Generate some header files
Sebastian Huber
Wed Nov 11 06:51:45 UTC 2020
On 11/11/2020 01:18, Chris Johns wrote:
> On 10/11/20 5:41 pm, Sebastian Huber wrote:
>> On 10/11/2020 00:05, Chris Johns wrote:
>>> On 10/11/20 1:49 am, Sebastian Huber wrote:
>>>> This patch set replaces some hand written header files of the Classic
>>>> API with header files generated from specification items. The main
>>>> parts are the Event Manager and the Partition Manager. The patches for
>>>> the RTEMS Classic API Guide of these two managers is available here:
>>>> https://lists.rtems.org/pipermail/devel/2020-November/063122.html
>>>> I tried to follow the updated Doxygen guidelines:
>>>> https://lists.rtems.org/pipermail/devel/2020-November/063119.html
>>>> Sebastian Huber (11):
>>>> rtems: Include missing header file
>>>> rtems: Generate <rtems/config.h>
>>>> rtems: Generate <rtems/rtems/config.h>
>>>> rtems: Generate <rtems/rtems/status.h>
>>>> rtems: Generate <rtems/rtems/modes.h>
>>>> rtems: Generate <rtems/rtems/options.h>
>>>> rtems: Generate <rtems/rtems/types.h>
>>>> rtems: Generate <rtems/rtems/attr.h>
>>>> rtems: Generate <rtems/rtems/event.h>
>>>> rtems: Generate <rtems/rtems/part.h>
>>>> rtems: Generate <rtems/score/basedefs.h>
>>> Do these files need something that indicates they are generated and part of the
>>> RTEMS Quality Process (RQP?)?
>>> I could not see anything.
>> All the generated files have the standard header and the generated by comments
>> or do you mean something else?
> I was thinking of something like the recent change to the documentation source:
> * This file is part of the RTEMS quality process and was automatically
> * generated. If you find something that needs to be fixed or changed
> * please post a report or patch to an RTEMS mailing list or raise a bug
> * report.
> I do not think we need the links as someone wanting to change an API header file
> should know there are mailing lists and a bug reporting system.
I would keep the links. It is not a lot of text. The header files
contain the directive documentation which is also in the manuals. So,
every user reviewing the API header file has a chance to fix typos,
suggest a better wording, or otherwise improve the documentation.
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
