[PATCH] Improve automatically generated warning
    Sebastian Huber
    Wed Nov 11 07:21:48 UTC 2020
 c-user/config/bdbuf.rst             | 9 ++++-----
 c-user/config/bsp-related.rst       | 9 ++++-----
 c-user/config/classic-api.rst       | 9 ++++-----
 c-user/config/classic-init-task.rst | 9 ++++-----
 c-user/config/device-driver.rst     | 9 ++++-----
 c-user/config/event-record.rst      | 9 ++++-----
 c-user/config/filesystem.rst        | 9 ++++-----
 c-user/config/general.rst           | 9 ++++-----
 c-user/config/idle-task.rst         | 9 ++++-----
 c-user/config/mpci.rst              | 9 ++++-----
 c-user/config/posix-api.rst         | 9 ++++-----
 c-user/config/posix-init-thread.rst | 9 ++++-----
 c-user/config/scheduler-general.rst | 9 ++++-----
 c-user/config/task-stack-alloc.rst  | 9 ++++-----
 c-user/io/directives.rst            | 9 ++++-----
 c-user/io/introduction.rst          | 9 ++++-----
 eng/req/items.rst                   | 9 ++++-----
 17 files changed, 68 insertions(+), 85 deletions(-)
diff --git a/c-user/config/bdbuf.rst b/c-user/config/bdbuf.rst
index e981f54..06399e0 100644
--- a/c-user/config/bdbuf.rst
+++ b/c-user/config/bdbuf.rst
@@ -3,11 +3,10 @@
 .. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
 .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
-.. Do not manually edit this file.  It is part of the RTEMS quality process
-.. and was automatically generated.
-.. If you find something that needs to be fixed or worded better please
-.. post a report to an RTEMS mailing list or raise a bug report:
+.. This file is part of the RTEMS quality process and was automatically
+.. generated.  If you find something that needs to be fixed or
+.. worded better please post a report or patch to an RTEMS mailing list
+.. or raise a bug report:
 .. https://docs.rtems.org/branches/master/user/support/bugs.html
diff --git a/c-user/config/bsp-related.rst b/c-user/config/bsp-related.rst
index 71bcd58..3d0a3ca 100644
--- a/c-user/config/bsp-related.rst
+++ b/c-user/config/bsp-related.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/config/classic-api.rst b/c-user/config/classic-api.rst
index 90aec72..e44716a 100644
--- a/c-user/config/classic-api.rst
+++ b/c-user/config/classic-api.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/config/classic-init-task.rst b/c-user/config/classic-init-task.rst
index 64a8f9f..4d3bf81 100644
--- a/c-user/config/classic-init-task.rst
+++ b/c-user/config/classic-init-task.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/config/device-driver.rst b/c-user/config/device-driver.rst
index 8915b0b..4fd8c71 100644
--- a/c-user/config/device-driver.rst
+++ b/c-user/config/device-driver.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/config/event-record.rst b/c-user/config/event-record.rst
index 6373e04..48de243 100644
--- a/c-user/config/event-record.rst
+++ b/c-user/config/event-record.rst
@@ -2,11 +2,10 @@
 .. Copyright (C) 2019, 2020 embedded brains GmbH (http://www.embedded-brains.de)
diff --git a/c-user/config/filesystem.rst b/c-user/config/filesystem.rst
index 8ad9085..1daea01 100644
--- a/c-user/config/filesystem.rst
+++ b/c-user/config/filesystem.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/config/general.rst b/c-user/config/general.rst
index 9662506..c2cb349 100644
--- a/c-user/config/general.rst
+++ b/c-user/config/general.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/config/idle-task.rst b/c-user/config/idle-task.rst
index 64a596f..f115dae 100644
--- a/c-user/config/idle-task.rst
+++ b/c-user/config/idle-task.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/config/mpci.rst b/c-user/config/mpci.rst
index dac5cad..e0fbe1d 100644
--- a/c-user/config/mpci.rst
+++ b/c-user/config/mpci.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/config/posix-api.rst b/c-user/config/posix-api.rst
index 886f1e6..aa44467 100644
--- a/c-user/config/posix-api.rst
+++ b/c-user/config/posix-api.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/config/posix-init-thread.rst b/c-user/config/posix-init-thread.rst
index 08215e6..4c49bdd 100644
--- a/c-user/config/posix-init-thread.rst
+++ b/c-user/config/posix-init-thread.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/config/scheduler-general.rst b/c-user/config/scheduler-general.rst
index 2916cf7..5478e84 100644
--- a/c-user/config/scheduler-general.rst
+++ b/c-user/config/scheduler-general.rst
@@ -4,11 +4,10 @@
 .. Copyright (C) 2010 Gedare Bloom
diff --git a/c-user/config/task-stack-alloc.rst b/c-user/config/task-stack-alloc.rst
index 7dd95bb..733ffd3 100644
--- a/c-user/config/task-stack-alloc.rst
+++ b/c-user/config/task-stack-alloc.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/io/directives.rst b/c-user/io/directives.rst
index 2ada7ac..c0a50d4 100644
--- a/c-user/io/directives.rst
+++ b/c-user/io/directives.rst
@@ -3,11 +3,10 @@
diff --git a/c-user/io/introduction.rst b/c-user/io/introduction.rst
index 7368e8a..706c711 100644
--- a/c-user/io/introduction.rst
+++ b/c-user/io/introduction.rst
@@ -3,11 +3,10 @@
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 5f0b8ee..9d3822b 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -2,11 +2,10 @@
2.26.2
