[PATCH] Improve automatically generated warning
Wed Nov 11 07:22:10 UTC 2020
 cpukit/doxygen/appl-config.h                        | 9 ++++-----
 cpukit/include/rtems.h                              | 9 ++++-----
 cpukit/include/rtems/io.h                           | 9 ++++-----
 testsuites/validation/tc-message-construct-errors.c | 9 ++++-----
 testsuites/validation/tc-task-construct-errors.c    | 9 ++++-----
 testsuites/validation/ts-validation-0.c             | 9 ++++-----
 6 files changed, 24 insertions(+), 30 deletions(-)
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index fe567b6e0f..00230ac2d6 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -28,11 +28,10 @@
- * Do not manually edit this file.  It is part of the RTEMS quality process
- * and was automatically generated.
- * If you find something that needs to be fixed or worded better please
- * post a report to an RTEMS mailing list or raise a bug report:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
  * https://docs.rtems.org/branches/master/user/support/bugs.html
diff --git a/cpukit/include/rtems.h b/cpukit/include/rtems.h
index 9b0765efda..d1b1452000 100644
--- a/cpukit/include/rtems.h
+++ b/cpukit/include/rtems.h
@@ -35,11 +35,10 @@
diff --git a/cpukit/include/rtems/io.h b/cpukit/include/rtems/io.h
index bfbad457c4..92ffb6d51b 100644
--- a/cpukit/include/rtems/io.h
+++ b/cpukit/include/rtems/io.h
@@ -35,11 +35,10 @@
diff --git a/testsuites/validation/tc-message-construct-errors.c b/testsuites/validation/tc-message-construct-errors.c
index 2493600312..d71e427b63 100644
--- a/testsuites/validation/tc-message-construct-errors.c
+++ b/testsuites/validation/tc-message-construct-errors.c
@@ -32,11 +32,10 @@
diff --git a/testsuites/validation/tc-task-construct-errors.c b/testsuites/validation/tc-task-construct-errors.c
index 37873ba7d6..4dfd12dbb8 100644
--- a/testsuites/validation/tc-task-construct-errors.c
+++ b/testsuites/validation/tc-task-construct-errors.c
@@ -32,11 +32,10 @@
diff --git a/testsuites/validation/ts-validation-0.c b/testsuites/validation/ts-validation-0.c
index baaa679c05..801023e249 100644
--- a/testsuites/validation/ts-validation-0.c
+++ b/testsuites/validation/ts-validation-0.c
@@ -32,11 +32,10 @@
2.26.2
